almost impossible to change material properties using task panel
A forum to discuss the implementation of a good Materials system in FreeCAD
uwestoehr
Postby uwestoehr » Wed Feb 06, 2019 12:04 am
Word size of FreeCAD: 64-bit, Version: 0.18.15780 (Git)
Hash: f94e76c1116ec3b818961ff65131b3d86fa5b95e
Python version: 2.7.14
OCC version: 7.2.0
Using the option "use this task panel" it is very hard to change or enter values:
- add a material, then check the option "use this task panel"
For example in the density field you have "1250,00 kg/m^3". You want to change it to "1700,00 kg/m^3"
- therefore highlight in the field the numbers "25" and type in "70"
result: you get "170,00 kg/m^30" which is an illegal value.
Now assume you want to change the poisson ratio to "0,48"
- thus highlight the complete field for the poisson ratio and type in "0,48"
result: you get "0,000"
- now set the cursor in the poisson ratio field behind the comma and type in e.g. "48"
result: noting happens
The problem is that FC evaluates the input after every key press. This cannot work. It must allow the user to enter and edit numbers as he likes and first when the user clicked on the checkmark in the field its content is evaluated. if there is a mistake the field should be highlighted red.
bernd
Re: almost impossible to change material properties using task panel
Postby bernd » Fri Feb 08, 2019 10:33 am
Yeah as you have noticed already the whole FEM gui needs love.
The idea is to get totally rid of the FEM material eding task panel and do all edits with the material editor.
uwestoehr
Postby uwestoehr » Fri Feb 08, 2019 11:17 pm
OK. I created now issue #3823 to document the issue and your proposed solution.
bernd
Postby bernd » Tue Feb 19, 2019 8:27 am
uwestoehr
Postby uwestoehr » Wed Feb 20, 2019 1:59 am
git commit a12f4f3
Many thanks, works fine now.
bernd
Postby bernd » Wed Feb 20, 2019 5:23 am
Werner has fixed this ...
