Fix for creating/changing colors in material card
A forum to discuss the implementation of a good Materials system in FreeCAD
Nocturnial
Postby Nocturnial » Mon Sep 02, 2019 10:29 am
Changing the diffuse color and creating specular, emissive,... colors didn't work in the material card dialog. The patch below should fix that. If those changes are ok do I issue a PR or should I create a tracking issue first?
https://github.com/FreeCAD/FreeCAD/comp ... e:matcolor
Re: Fix for creating/changing colors in material card
Postby Kunda1 » Mon Sep 02, 2019 9:04 pm
Lets ping some of the Material folks to review your code.
yorik wrote:
moult wrote:
bernd
Postby bernd » Wed Sep 04, 2019 4:06 pm
No need to make a PR. I will have a look and merge if it is ok
bernd
Postby bernd » Wed Sep 04, 2019 8:00 pm
What exactly does not work with the integer color representation? I could not find anything wrong. Would it be possible to give some step by step example.
Nocturnial
Postby Nocturnial » Thu Sep 05, 2019 12:29 am
These steps are for the 0.19 pre-release (exact details below) but they are also present in the master branch (HEAD github)
Can't edit diffuse color:
1) Run freecad
2) (menu) File->New
3) Switch to arch workbench
4) (menu) Arch->Material tools->Material
5) in combo view in the tab tasks, you see the where you can enter things like name, Description, color, etc.. of the material
6) Next to name click the clipboard icon to bring up the material card editor
7) Scroll to diffuse color and double click the value to edit
=> Nothing happens but in report view I see:
  File "E:\work\programs\FreeCAD_0.19.17515_x64_Conda_Py3QT5-WinVS2015\Mod\Material\MaterialEditor.py", line 526, in createEditor
    editor = matProperWidget(parent, matproperty, Type, Value)
  File "E:\work\programs\FreeCAD_0.19.17515_x64_Conda_Py3QT5-WinVS2015\Mod\Material\MaterialEditor.py", line 624, in matProperWidget
    value = string2tuple(Value)
  File "E:\work\programs\FreeCAD_0.19.17515_x64_Conda_Py3QT5-WinVS2015\Mod\Material\MaterialEditor.py", line 653, in string2tuple
    value = [int(v) for v in value]
  File "E:\work\programs\FreeCAD_0.19.17515_x64_Conda_Py3QT5-WinVS2015\Mod\Material\MaterialEditor.py", line 653, in <listcomp>
ValueError: invalid literal for int() with base 10: '0.5019607843137255'
I can't seem to reproduce the exact steps that caused me troubles for the other colors (emissive,...). Maybe it was caused because at the time I was experimenting with mixed c++, python debugging. I don't know.
In any case, the diffuse color is stored as three floats and it would make things easier if the other colors for rendering in the material card are stored in the same format. If you're worried about compatibility issues let me know.
Version: 0.19.17505 (Git)
Hash: 755536e9df94d2d39da1468420f1fd333c35da7a
Python version: 3.6.6
Qt version: 5.6.2
yorik
Site Admin
Postby yorik » Thu Sep 05, 2019 8:55 pm
Indeed inside FreeCAD float-based colors are used everywhere and if I'm not mistaken, int-based (1->255) colors are never used anywhere except inside FCStd files, but that is invisible to the user. For me the patch looks good
bernd
Postby bernd » Wed Sep 11, 2019 10:20 am
But editing the mat files by "Hand" is nearly impossible. Since the color has lots of diggits with the float it is not easy to use exact the same color. IT might be a different because of the last diggit to be different because of numerical problems.
It is difficault to describe my concerns about the use of floats in the mat cards.
Ahh the int based colors are used in the gui! This is what the user sees. And the color numbers in the mat files ist what the user sees too.
Means any no code API, no matter if it is the GUI, the FCStd file or the mat cards uses the int based system.
bernd
Postby bernd » Thu Oct 03, 2019 1:30 pm
Nocturnial
Postby Nocturnial » Thu Oct 03, 2019 2:41 pm
may be related https://forum.freecadweb.org/viewtopic.php?f=23&t=39802
I really doubt it, but I could be wrong. The infinite loop and stack overflow problem sounds like a 0.18 problem which was fixed in 0.19(pre). I had the same problem and either searched the forum or github, but in any case IIRC someone reported this and it was fixed. Let them try master or a 0.19(pre) package for their distro. I'm using 0.19(pre) for windows for this specific reason.
The problem of floats vs ints is rather benign. As far as I know it only results in not displaying the qt color picker instead of crashing.
petit_chat_noir
Postby petit_chat_noir » Thu Oct 03, 2019 3:42 pm
Yes, I've compiled 0.19pre and the problem is solved. So this bug is 0.18.3 related...
