Macro Texture Objects
A forum to discuss the implementation of a good Materials system in FreeCAD
yorik
Site Admin
Re: Macro Texture Objects
Postby yorik » Mon Sep 15, 2014 6:32 pm
At the moment not right out of the box, but it should become possible at some point in time. At the moment your only solution would be to program a custom python object that supports textures.
bernd
Postby bernd » Thu Sep 18, 2014 9:09 pm
yorik wrote: Since all objects are internally in millimeters, it would be quite easy to maintain an accurate scale...
Is really in FreeCAD core everything changed to mm, even if one uses unit system for meter or imperial units ?
yorik
Site Admin
Postby yorik » Thu Sep 18, 2014 9:57 pm
bernd wrote:Is really in FreeCAD core everything changed to mm, even if one uses unit system for meter or imperial units ?
Yes
bernd
Postby bernd » Sat May 19, 2018 7:39 am
paullee
Postby paullee » Sun May 20, 2018 9:06 pm
bernd wrote:
Fri Aug 01, 2014 8:14 am
Found the Macro Texture Objects and tested with imported material from ifc-file. I could'nt helpt to post the screens. I still need to clean and post the code for importing materials and properties. :oops:
def textureMaterial():
  """ Texturen nach Material setzen
  import FreeCADGui
  from PyQt4 import QtGui
  from pivy import coin
  print "Texturen"
  texturefilepath = '/home/hugo/Documents/projekte--ifc/freecad/BIM--IFC/Texturen--Vorlageproj/'
  material2texture = { 'noMaterial'          : texturefilepath+'noMaterial.jpg',
                       'Beton'               : texturefilepath+'beton_bewehrt.jpg',
                       'Backstein'           : texturefilepath+'backstein.jpg',
                       'Kalksandstein'       : texturefilepath+'kalksandstein.jpg',
                       'Baustahl'            : texturefilepath+'stahl.jpg',
                       'Eindeckung'          : texturefilepath+'dachziegel.jpg'
  for o in FreeCAD.ActiveDocument.Objects:
    if '_FreeCAD_shape_body' not in o.Name:    # es waere cooler ein eigenes PythonFeature
      if hasattr(o,'Shape'):
        o.ViewObject.Visibility = True
        if hasattr(o,'IfcObjectType') and hasattr(o,'IfcMaterial'):
          o.ViewObject.Transparency = 0
          o.ViewObject.ShapeColor = (1.0,1.0,1.0)
          rootnode = o.ViewObject.RootNode
          tex =  coin.SoTexture2()
          tex.filename = material2texture['noMaterial']  # weisse textur
          if o.IfcMaterial in material2texture:
            #print material2texture[o.IfcMaterial]
            tex.filename = material2texture[o.IfcMaterial]
          else:
            print (o.Name + ' --> ' + o.IfcObjectType + ' --> ' + o.IfcMaterial)
          rootnode.insertChild(tex,1)
        else:
          o.ViewObject.ShapeColor = (0.0,0.0,0.0)   # black
          #print ("  Object " + o.Name + " has no IfcObjectType or no IfcMaterial")
Thanks bringing this up - never know there had been discussion and macro available!
Wonder why this had not been improved, merged in Arch Module (or other general use) and widely used since so many year?
