Should be in >= 0.16.6214, please test.bernd wrote:@sgrogan: would you update the win builds?
https://github.com/freecad/freecad/releases
64bit works very well, thanks sgrogan! Did you update 32bit as well?sgrogan wrote:Should be in >= 0.16.6214, please test.bernd wrote:@sgrogan: would you update the win builds?
Yes I built and unpdated both versions.bernd wrote:64bit works very well, thanks sgrogan! Did you update 32bit as well?
I will try tonight. I will first try without updating the dependencies, in case this is the problem.bernd wrote:Would you try the windows build script if you have success?
Thanks. It is what I have should done too , but just deleted them before I started to compile ...sgrogan wrote:I will try tonight. I will first try without updating the dependencies, in case this is the problem.bernd wrote:Would you try the windows build script if you have success?
<type 'exceptions.SyntaxError'>: ('invalid syntax', ('C:\\Users\\Chris\\GitHub\\FCAutoBuild\\var\\build_x86_VC9\\Mod\\Arch\\importIFC.py', 124, 59, ' global DEBUG, PREFIX_NUMBERS, SKIP, SEPARATE_OPENINGS,\n'))
