ifc mapping
This forum section is only for IFC-related issues
hardeeprai
ifc mapping
Postby hardeeprai » Tue May 08, 2018 3:31 pm
Is ifc4 import/export works in FreeCAD, as IfcOpenShell has support for ifc4.
Which files (in source code repository) maps FreeCAD data to IfcOpenShell?
H.S.Rai
bernd
Re: ifc mapping
Postby bernd » Tue May 08, 2018 4:15 pm
hardeeprai
Re: ifc mapping
Postby hardeeprai » Wed May 09, 2018 12:19 am
Thank you.
Will go through, try to understand, and if there is any query, will come back.
In the mean time, if anyone has any suggestion, can give me some direction, pointer to other information available elsewhere, which could be useful.
I wanted to see "capacity of structural members" in ifc files. Is that possible?
I will calculate Moment carrying capacity of I-section used as beam or Reinforced Beam, and that should become property of structural member. Like wise a column will be having equivalent of P-M Load-Moment interaction Curve.
H.S.Rai
yorik
Site Admin
Re: ifc mapping
Postby yorik » Thu May 10, 2018 1:44 pm
At the top of the importIFC.py file you'll see a "conversion table" that maps FreeCAD types <-> IFC types.
One of the things I'll do soon (in fact, doing this right now) is to allow all Arch/BIM objects to have any IFC type, so you can draw a wall and make it export as a column.
Regarding structural properties, the IFC format itself allows you to export just any custom properties with any object. You can group these properties into a property set that you define yourself. At the moment, FreeCAD will export everything it finds in the IfcAttributes property that all Arch/BIM objects have. So to have something exported automatically, just add to any object's IfcAttribute, for example like this:
myDict = myObject.IfcAttributes
myDict["MyNewPropertyName":"IfcText(Hello, world!)"]
myObject.IfcAttributes = myDict
When exported to IFC, an IfcPropertySingleValue of name MyNewPropertyName and type IfcText will be added automatically. The syntax is still a bit cumberstone and this system doesn't support custom property sets yet, but I'm working on it.
Now, of course, the whole thing is that other applications won't be aware of the custom properties you add. In the best case, they will read it and keep its value stored somewhere. So one has to look at the IFC specs if there is something "standard" to deal with such structural properties, or analyze the IFC file produced by other structural BIM apps to see how they do it, and we can try doing the same.
cnirbhay
Re: ifc mapping
Postby cnirbhay » Sat May 12, 2018 2:30 pm
I agree. I did some workout for this on Revit. I tried custom mapping but it is very limited. Revit performs mapping only to those IFC entities which it recognises. For eg: A column could be mapped to IfcBeam or IfcFurniture, etc but when I tried mapping it to IfcStructuraItem or IfcStructuralAnalysisModel, the export turned out into IfcBuildingElementProxy. I'm doubtful there must be some other mapping table that Revit uses somewhere in its hidden backend other than the 'exportlayers-ifc-IAI' file.
Please see the below attached screenshots.
[img
Screenshot (355)_LI.jpg (874.71 KiB) Viewed 1005 times
][/img]
Thanks.
Regards.
Screenshot (360)_LI.jpg (441.63 KiB) Viewed 1005 times
Screenshot (359)_LI.jpg (890.74 KiB) Viewed 1005 times
Screenshot (358)_LI.jpg (379.41 KiB) Viewed 1005 times
Screenshot (357)_LI.jpg (404.63 KiB) Viewed 1005 times
yorik
Site Admin
Re: ifc mapping
Postby yorik » Sun May 13, 2018 6:36 pm
I just changed things in FreeCAD yesterday, now each BIM/Arch object has an IfcRole property, instead of its former Role property. This IfcRole can be any IFC entity derived from IfcProduct, which are the ones that can have a Representation. I think this will make things clearer and more universal (ie. any FreeCAD Arch object can be exported to any IFC entity). In the BIM WB there is now a new "Ifc Element Manager" tool to manage IFC mappings all at once.
bitacovir
Re: ifc mapping
Postby bitacovir » Tue May 15, 2018 3:24 am
These changes are for V0.17 or 0.18?
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
chakkree
Re: ifc mapping
Postby chakkree » Tue May 15, 2018 4:42 am
Version: 0.18.13705+
Version: 0.18.13705 (Git)
Hash: 891682a41220943af114f1312b57e04401c4cefb
Python version: 2.7.14
OCC version: 7.2.0
bernd
Re: ifc mapping
Postby bernd » Wed May 16, 2018 8:24 pm
Thank you.
are you talking about StructuralAnalysisView (import supported by FreeCAD, https://github.com/berndhahnebach/Ifc_S ... alysisView ) or CoordinationView ( standard ifc import or export supported by FreeCAD) ?
hardeeprai
Re: ifc mapping
Postby hardeeprai » Sun May 20, 2018 2:27 pm
CoordinationView
Final outcome of structural analysis. What load a slab can take, so load carrying capacity (in UDL and/or concentrated load), how much load a beam or column can take. I mean, rated capacity of structural members.
H.S.Rai
