Issue regarding ifc file in FreeCAD
This forum section is only for IFC-related issues
Gurbhej Singh
Postby Gurbhej Singh » Thu Sep 27, 2018 12:05 pm
I have created an ifc file using FreeCAD and tried to import it to the Staad Pro.
In Staad Pro it shows only nodes and lines. It does not have any cross-section properties and material information, which were assigned in FreeCAD.
Please help me to identify the cause of the issue.
MY system specifications are
Version: 0.18.14779 (Git)
Hash: 50ab6e292cc83cada4a5b071531a76f5a2580f60
Python version: 2.7.14
OCC version: 7.2.0
Locale: English/India (en_IN)
Gurbhej Singh
hardeeprai
Re: Issue regarding ifc file in FreeCAD
Postby hardeeprai » Thu Sep 27, 2018 12:12 pm
How are you importing ifc to Staad Pro software?
H.S.Rai
Gurbhej Singh
Postby Gurbhej Singh » Thu Sep 27, 2018 4:29 pm
I had converted the ifc file to ism file using software of Bantley. Then i had opened that ism file in Staad Pro.
Gurbhej Singh
cnirbhay
Postby cnirbhay » Fri Sep 28, 2018 6:08 pm
Firstly, you are importing an ISM file into Staad, not the original IFC. Secondly, when you convert the IFC to ISM, make sure you do proper mapping of the elements and their respective parameters.
yorik
Site Admin
Postby yorik » Fri Sep 28, 2018 11:16 pm
It's best to always check your IFC file in a standalone IFC viewer such as ifcPlusPlus, bimvision or solibri viewer... Then you can deduce if the problem is in the application that exported the IFC file, or in the one that imports it.
In case the IFC file doesn't contain what you want, can you attach the freecad file here so we can have a look?
hardeeprai
Postby hardeeprai » Sat Sep 29, 2018 7:40 am
I suggest to make exported ifc file (from FreeCAD) available to us (may be from DropBox or GoogleDrive), along with .fcstd file.
Also tell, what you are looking in staad-pro, which, in your opinion, you have supplied in FreCAD.
Convey us your precise problem.
H.S.Rai
Gurbhej Singh
Postby Gurbhej Singh » Thu Oct 04, 2018 9:01 am
IFC file works correctly when checked using Solibiri viewer.
link for Freecad file :- https://drive.google.com/file/d/1lMlRj0 ... sp=sharing
link for IFC file :- https://drive.google.com/file/d/1ZQHnzw ... sp=sharing
Screenshort of Solibiri viewer :- https://drive.google.com/file/d/1xe9rSN ... sp=sharing
Gurbhej Singh
Postby Gurbhej Singh » Thu Oct 04, 2018 9:42 am
When I imported the file in Staad Pro it does not show any cross-section properties and material information which was provided in FreeCAD. It only shows lines and nodes.
link for Staad file :- https://drive.google.com/file/d/1xw0mRN ... sp=sharing
link for Screenshort of Staad file :- https://drive.google.com/file/d/1BjHZ7c ... sp=sharing
yorik
Site Admin
Postby yorik » Thu Oct 04, 2018 2:50 pm
Thanks for sharing the files.
I don't know staad pro so I am not sure what it expects to find in an IFC file, but one thing I can tell you, what's in the IFC file are three structural elements (one beam and 2 columns, and each of them is made of a 2D polyline that gets extruded to form a volume, and each of them has the "Concrete" material associated. So as far as I can see the IFC file is correct.
Can you maybe produce with another software a similar IFC file that works in staad pro? So we can compare and see if it needs something that FreeCAD doesn't provide...
Gurbhej Singh
Postby Gurbhej Singh » Thu Oct 04, 2018 5:05 pm
Sir,
Using another software (Revit), I generated a similar model and exported it to IFC file.
Then Imported that IFC in staad pro I got a good model with all cross-section properties and material information which were assigned in Revit.
link of Revit file:- https://drive.google.com/file/d/10GmrDm ... sp=sharing
link of IFC generated by Revit:- https://drive.google.com/file/d/1v-GMs7 ... sp=sharing
screenshot of solibiri:- https://drive.google.com/file/d/161e0x5 ... sp=sharing
screenshot of staad showing properties:- https://drive.google.com/file/d/1A-nk66 ... sp=sharing
file of staad pro:- https://drive.google.com/file/d/18PCNlA ... sp=sharing
