Issue regarding ifc file in FreeCAD
This forum section is only for IFC-related issues
yorik
Site Admin
Re: Issue regarding ifc file in FreeCAD
Postby yorik » Fri Oct 05, 2018 2:35 pm
One difference I can see if in the FreeCAD-generated IFC file, the extrusion profiles are IfcArbitraryClosedProfileDef made from IfcPolyline entities, while in the Revit-generated one they are IfcRectangleProfileDef. An interesting way to test would be to try to replace, for example replace entity #28 in the FreeCAD IFC file from:
#28=IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#27);
to
#28= IFCRECTANGLEPROFILEDEF(.AREA.,'test rectangle',#8,0.05,0.05);
and see if there is any difference?
In any case, IfcArbitraryClosedProfileDef is very common, it is a bad implementation in staad pro if they only support part of the IFC specification
Gurbhej Singh
Postby Gurbhej Singh » Sat Oct 06, 2018 4:59 pm
to
The issue is still the same no properties and material in staad pro.
But one more problem arises after changing the line in IFC
to
Opened new IFC in FREE CAD, I saw the beam disappear from the file,
for reference see screenshot https://drive.google.com/file/d/1sSnlvt ... sp=sharing
link of new IFC https://drive.google.com/file/d/1pNH_Xy ... sp=sharing
Tandy
Postby Tandy » Sat Oct 06, 2018 5:22 pm
to
Sir,
I am also facing the same problem
i am using FreeCAD for making a 3D structure and generating IFC.
Opening that IFC in ETAB (structure design software) as it accepts the IFC format.
The same problem occurs as discussed in this topic above , ETAB only show lines i.e no member property and no material imported in ETAB.
Then i decided to use REVIT as discussed and all properties of REVIT are working well in ETAB without any loss till now.
Thank you
Tandeep singh
hardeeprai
Postby hardeeprai » Sun Oct 07, 2018 2:04 am
yorik wrote:
Thu Oct 04, 2018 2:50 pm
I don't know staad pro
I would try to tell about StaadPro.
A beam or column in StaadPro (or for that matter any other Structural Analysis software (Finite Element or Stiffness method based )), is represented by its end points (called nodes, which are 3D points), like wise slab can be represented by 4 nodes or 3 nodes, and brick can be represented by 8 nodes.
After telling element's (Beam/Column) position in space using 2 points, we need to tell cross-section's geometric properties, which can be Area, Moment of Inertia and more like that (for prismatic members, though it can also handle non-prismatic (tapered) members):
AX = Cross sectional area
IX = Torsional constant
IY = Moment of inertia (MoI) about y-axis.
IZ = Moment of inertia about z-axis.
In addition, the user may choose to specify the following properties:
AY = Effective shear area for shear force parallel to local y-axis.
AZ = Effective shear area for shear force parallel to local z-axis.
YD = Depth of section parallel to local y-axis.
ZD = Depth of section parallel to local z-axis.
One way is give such values directly, and 2nd way is telling the type of section i.e. circular (Give dia), rectangular (give size Depth x Width) or Trapezoidal, T and I section, then programme will calculate Area, MoI and do needful.
Line:
1 PRIS YD 500 ZD 300
which is line no. 134 of https://bitbucket.org/hsrai/staad-pro/s ... ew-default
tells that section 1 is prismatic, with width 300 and depth 500.
three structural elements (one beam and 2 columns, and each of them is made of a 2D polyline that gets extruded to form a volume
It will be nice, if IFC from FreeeCAD can identify such common cases like rectangular (IfcRectangleProfileDef)/ circular / T sections, and for other irregular X-section, IfcArbitraryClosedProfileDef should be OK, but in staad-pro it must translate to AX, IY etc.
each of them has the "Concrete" material associated.
In StaadPro, material is defined as:
DEFINE MATERIAL START
ISOTROPIC M25CONC
E 22000
POISSON 0.15
END DEFINE MATERIAL
Lines 116 - 125 of https://bitbucket.org/hsrai/staad-pro/s ... ew-default
H.S.Rai
hardeeprai
Postby hardeeprai » Sun Oct 07, 2018 2:16 am
One need to give XDim and YDim, in place of Area, refer:
http://www.buildingsmart-tech.org/ifc/I ... iledef.htm
Let us we support IfcArbitraryClosedProfileDef, IfcRectangleProfileDef. Rather all (total 12 in number) as given at: http://www.buildingsmart-tech.org/ifc/I ... iledef.htm
H.S.Rai
cnirbhay
Postby cnirbhay » Sun Oct 07, 2018 11:14 am
Rather, there are shortcuts being adopted by ETABS, ISM or other for the mapping purposes. Moreover, the mapping is done in a way considering the 'family' approach of Revit. For eg: In ETABS, section name is mapped to the 'ObjectType' of 'IfcColumn' and section dimensions are mapped to 'XDim' and 'YDim' of 'IfcRectangleProfileDef'.
Suppose if the dimension parameters of a column family are shifted to instances from its family parameters in Revit, then the exported IFC file will have all column types of that family with a common name but the dimensions will be different. In such case, ETABS will take any one dimensions set from the IFC for the mapping purpose of the section types with the common name, resulting in all members with the same dimensions. This proves it to be a bad approach for mapping the section name and section dimensions separately. The section name should be generated itself in a way by reading the section dimensions.
In this case, FreeCAD has a rather straightforward approach of considering the section as a closed curve or polygon and its corner points in the form of cartesian points that is by the entity name 'IfcArbitraryClosedProfileDef'. The good thing is FreeCAD is able to read it accurately when imported back. ETABS or ISM is not able to map this entity, whereas Revit or other BIM software can import it but only as a dead geometry with no functionality to edit or modify the parameters.
Gurbhej Singh
Postby Gurbhej Singh » Fri Oct 12, 2018 5:28 pm
I was expecting some answers, Meanwhile i searched and found an alternative to this problem. I modeled a structure in FreeCAD and exported the IFC to Robot structure analysis (By Autodesk). After performing analysis and design I exported the new IFC file to FreeCAD and I got the results showing the cross-sectional properties and materials which were initially provided in FreeCAD in addition to it reinforcement is also present.
This was the result which I was expecting when I use Staad Pro for analysis and design purpose.
Please provide us any other alternatives for the purpose of analysis and design.
Link for FreeCAD final model (Concrete Visibility is set to 80):-
https://drive.google.com/file/d/10VGlA8 ... RcEIE/view
Link for the file of Solibiri Viewer(with transparency to show steel bar):-
Link for the IFC file:-
https://drive.google.com/file/d/1Z5jDl- ... _oFqz/view
Tandy
Postby Tandy » Fri Oct 12, 2018 5:34 pm
In this case, FreeCAD has a rather straightforward approach of considering the section as a closed curve or polygon and its corner points in the form of cartesian points that is by the entity name 'IfcArbitraryClosedProfileDef'. The good thing is FreeCAD is able to read it accurately when imported back. ETABS or ISM is not able to map this entity, Revit or other BIM software can import it but only as a dead geometry with no functionality to edit or modify the parameters.
The main issue is this only.
Tell us any suggestion that how to improve this IFC file so that we can make changes in other BIM software.
And also we can work in other BIM software.
Tandeep singh
Tandy
Postby Tandy » Tue Oct 16, 2018 7:43 pm
to
Sir i had worked on your suggestion and Results were good i,e section properties are transfer to staad pro. i have change the #8 to #32 for the execution of this file,
now please help to change this line automatically in freecad because for large project / buildings it is difficult to change this line for each member separately.
Thank you
Tandeep singh
Gurbhej Singh
Postby Gurbhej Singh » Tue Oct 16, 2018 8:25 pm
to
Thank you
I have also done the same changes (#8 to #32) and make the ifc file to execute in the staad pro and it work properly giving me the desired results. Now please give suggestion how to change it automatically without manual input.
Thank you.
