[PR] Arch Wall - Based on Sketch Issues
This forum section is only for IFC-related issues
paullee
Postby paullee » Sat Sep 29, 2018 12:12 am
[EDIT] - See post on 27.10.2019
Extract from a post in original thread below :)
https://forum.freecadweb.org/viewtopic. ... 10#p257347
ArchWall based on Sketch with following Shape has problem:-
  1. A closed wire with multiple edges
  2. A random edge attach in above edge
  3. Resulted IFC shape is only a tiny bit as shown
  4. Without the 'random edge', the IFC seem fine - see next post
Original *.fcstd / *.ifc in original post/thread above, not further duplicating here
Test_ ArchWall_ To_ IFC_ 3c_ Pure Sketch.fcstd
(11.42 KiB) Downloaded 1 time
Test_ Arch Wall _3c_ Pure Sketch_ Linux_ IfcOpenShell_ Python_ 0.17.ifc
(6.42 KiB) Downloaded 1 time
EDIT:
Ifc Export / Viewer Setup
  1. OS - Fedora 27 64bit
  2. FC: Appimage - FreeCAD_0.17_13541.9948ee4.glibc2.17-x86_64 (Not really sure if it was this version then)
  3. IfcOpenShell Python - http://ifcopenshell.org/python.html
  4. IfcOpenShell Python - not compiled from latest source, just use 'pre-compiled' from above link (same 1 or 2 years not updated)
  5. Ifc Viewer - Ifc++, compiled from Bernd's repo
Screenshot from 2018-09-20 01-12-28.png (220.41 KiB) Viewed 1721 times
Screenshot from 2018-09-20 01-13-32.png (58.11 KiB) Viewed 1721 times
(11.42 KiB) Downloaded 44 times
paullee
Re: Arch Wall - Based on Sketch Issues
Postby paullee » Sat Sep 29, 2018 12:37 am
Extract from original post/thread below:
https://forum.freecadweb.org/viewtopic. ... 10#p257348
ArchWall based on Sketch with following Shape is OK:-
See screencaptures & files below
Original *.fcstd / *.ifc in above link not duplicated here again
Test_ ArchWall_ To_ IFC_ 3b_ Pure Sketch.fcstd
(8.1 KiB) Downloaded 2 times
Test_ Arch Wall _3b_ Pure Sketch_ Linux_ IfcOpenShell_ Python_ 0.17.ifc
(3.33 KiB) Downloaded 1 time
Screenshot from 2018-09-20 01-37-54.png (156.33 KiB) Viewed 1717 times
Screenshot from 2018-09-20 01-38-29.png (122.03 KiB) Viewed 1717 times
cadgiru
Postby cadgiru » Sat Sep 29, 2018 5:58 am
Is this really an issue, believe one would generally classify walls by wall type.
In this example I would think it was natural that this was at least two walls.
paullee
Postby paullee » Sat Sep 29, 2018 6:15 am
You mean if the rectangular wall and the 'dialognal' wall are 2 Arch Wall object s, it would be ok?
Just FreeCad make it correctly; but when it export to IFC it is not correct.
So, not sure if it is IFC problem (it doesn't support this configuration of walls), FC IfcExport's problem, IfcOpenShell- Python (bwing version too old) or else?
paullee
Postby paullee » Wed Nov 14, 2018 5:50 pm
Hi, I try IFCexport (FC 0.17 in Win) Joyas's model and it looks good.
https://forum.freecadweb.org/viewtopic. ... 10#p268883
(Can't export Roof though )
Each Wall object is built on a sketch with simple edge, then hosted into a 'Master' Wall Object. (Each 'Slave Sketch' contains only simple edge referencing to a 'Master Sketch')
Seem then these Walls exports okay.
Downside is need more works and wall objects if the layout / sketch is 'complex'.
Screenshot from 2018-11-15 01-32-35.png (275.62 KiB) Viewed 1636 times
Screenshot from 2018-11-15 01-32-49.png (443.54 KiB) Viewed 1636 times
Wall Structure Stairs_ Win7_ FC-0.17.ifc
(365.58 KiB) Downloaded 58 times
paullee
Postby paullee » Sat Nov 17, 2018 1:23 pm
Just notice the multi-layer wall is not exported all correctly - just look at the image closely.
In fact, I note the problem of multi-layer wall when I tried importing back the ifc file into FC.
Do not jog down all info but should be FC 0.17 release on Win 7.
Screenshot from 2018-11-17 21-22-20.png (265.01 KiB) Viewed 1590 times
Casita_FreeCAD_amarilla_08_comprimir_ IFC export and import.FCStd
(390.38 KiB) Downloaded 45 times
paullee
Postby paullee » Tue Oct 22, 2019 6:24 pm
Hi, trying to dig into export.py to see why this is so...
Some observation:-
  1. getProfile() only use 1st wire if the shape contain only straight edge (polyline)
    w = Part.Wire(Part.__sortEdges__(p.Wires[0].Edges))
  2. createCurve() (for shape contain curve edge) has used Part.__sortEdges__() which only return 1st wire constructed from the wire.Edges - though there might be a numbers of wire
    edges = Part.__sortEdges__(wire.Edges)
  3. This seem to be the reason why multiple wall created from a sketch base only have portion of it created in the ifc file
Questions about ifc:-
I am not familiar with ifc standards at all, trying to check but it is huge for me to understand.
  1. Any limitation in ifc standards how many profile in a single ifcwall object?
  2. If above is yes, any other ifc object suitable for this case
Thanks for any idea
def getRepresentation(ifcfile,context,obj,forcebrep=False,subtraction=False,tessellation=1,colors=None,preferences=None):
            if (not shapes) and hasattr(obj.Proxy,"getExtrusionData"):
                extdata = obj.Proxy.getExtrusionData(obj)
                if extdata:
                            profile = getProfile(ifcfile,pi)
def getProfile(ifcfile,p):
    else:
        if DraftGeomUtils.hasCurves(p):
            # extruded composite curve
            pol = createCurve(ifcfile,p)
        else:
            # extruded polyline
def createCurve(ifcfile,wire):
    "creates an IfcCompositeCurve from a shape"
    segments = []
    pol = None
    last = None
    if wire.ShapeType == "edge":
        edges = [wire]
    else:
paullee
[PR] Re: Arch Wall - Based on Sketch Issues
Postby paullee » Sun Oct 27, 2019 3:53 am
Turn out making ArchWall ( if there are multiple wires thus multiples faces in a sketch ) to add each face in the compound rather than fusing them.
This avoid the need to revise ifcExport.py, which check only the 1st face / wire only, to check if there are multiple faces in a shape.
Proposed ArchWall.py attached, see if anyone want to try.
The only problem now is, as the basefaces are not fused, solids may appears 'overlapped' in ifc - whilst in FC, the solids are fused and appear 'correctly' contiguous.
Screenshot from 2019-10-27 11-43-21.png (132.89 KiB) Viewed 1047 times
Appearance in FC (fused)
Screenshot from 2019-10-27 11-54-38.png (149.65 KiB) Viewed 1045 times
Test_ ArchWall_ To_ IFC_ 3c_ Pure Sketch_ 2018.10.27.ifc
(3.15 KiB) Downloaded 26 times
ArchWall.py
(52.55 KiB) Downloaded 24 times
yorik
Site Admin
Re: [PR] Arch Wall - Based on Sketch Issues
Postby yorik » Mon Oct 28, 2019 5:02 pm
I'm not sure we should always fuse. A wall could be made of different components that we would want to keep as distinct solids.
