IfcOpenShell packages available in Community Extras PPA
This forum section is only for IFC-related issues
kkremitzki
Postby kkremitzki » Sun Sep 30, 2018 5:58 am
Howdy,
An experimental IfcOpenShell package is now available in the Community Extras PPA for Ubuntu 16.04/18.04. Please test it out and report any issues here so this package can be integrated into Debian and future versions of Ubuntu.
https://launchpad.net/~freecad-communit ... ubuntu/ppa
bernd
Re: IfcOpenShell packages available in Community Extras PPA
Postby bernd » Sun Sep 30, 2018 9:18 am
based on Python2 or Python3?
kkremitzki
Postby kkremitzki » Sun Sep 30, 2018 11:44 am
Python 3.
kkremitzki
Postby kkremitzki » Sun Sep 30, 2018 6:38 pm
I updated the package to build Python 2 only instead, and as a result it now builds on Ubuntu 14.04 as well.
cadgiru
Postby cadgiru » Mon Oct 01, 2018 5:25 am
OS: Ubuntu 18.04.1 LTS
Version: 0.18.14855 (Git)
Hash: 496df34369330174b4e35067f7843308e50310b5
Python version: 2.7.15rc1
Have a persistent problem with importing ifc
Enclosed pls find exported from fc a simple wall. When importing, this or any other ifc file FC hangs. Believe Paullee experiences the same.
My hunch is this has something to do with UTF8 character encoding or maybe some locale settings. Experienced the same on all ubuntu setups.
Works on Win.
Import from console gives
freecadcmd
FreeCAD 0.17, Libs: 0.17R13541 (Git)
(c) Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
[FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>]
>>> import importIFC
>>> importIFC.open("/home/peter/2018_06FreecadArtigas/IfcTesting/wall01.ifc")
Importing IFC objects......
Reading BREP file......
Geometry...
Geometry...
Geometry...
Geometry...
Geometry...
Geometry...
Shapes...
  File "<stdin>", line 1, in <module>
  File "/usr/lib/freecad/Mod/Arch/importIFC.py", line 336, in open
    doc = insert(filename,doc.Name,skip,only,root)
  File "/usr/lib/freecad/Mod/Arch/importIFC.py", line 692, in insert
    a["IfcUID"] = str(guid)
UnicodeEncodeError: 'ascii' codec can't encode characters in position 0-10: ordinal not in range(128)
Related to https://forum.freecadweb.org/viewtopic. ... 1&start=10 and https://forum.freecadweb.org/viewtopic.php?f=39&t=31163
regards
Wall01.fcstd
(7.43 KiB) Downloaded 16 times
wall01.ifc
(2.51 KiB) Downloaded 18 times
kkremitzki
Postby kkremitzki » Mon Oct 01, 2018 6:20 am
Works on Win.
Can you try going to the folder you have wall01.ifc at, opening a Python interpreter and doing:
import ifcopenshell
f = ifcopenshell.open("wall01.ifc")
cadgiru
Postby cadgiru » Mon Oct 01, 2018 7:08 am
peter@peter-Inspiron-7720:~/2018_06FreecadArtigas/IfcTesting$ python
Python 2.7.15rc1 (default, Apr 15 2018, 21:51:34)
[GCC 7.3.0] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import ifcopenshell
yorik
Site Admin
Postby yorik » Mon Oct 01, 2018 8:11 pm
There is some bug in Arch (the Normal property of that wall doesn't work correctly), I'll try to find out what's wrong, but the problem is most certainly not in ifcopenshell...
cadgiru
Postby cadgiru » Mon Oct 01, 2018 8:56 pm
Believe this is definitely an encoding issue..
https://stackoverflow.com/questions/483 ... sition-0-o
Paullee has the same issue https://forum.freecadweb.org/viewtopic.php?f=39&t=31163
regards
Giovanni_Longo
Postby Giovanni_Longo » Tue Jul 02, 2019 6:34 pm
I've installed IfcOpenShell via the Community Extras PPA on my Ubuntu 18.04, but FreeCAD (v.0.18.1) can't find it so IFC import and export are not working at all. I've installed FreeCAD with freecad-python3 dependency, not freecad-python2.
If it can be useful these are the commands I launched by terminal:
sudo add-apt-repository ppa:freecad-community/ppa
sudo apt update
sudo apt install ifcopenshell0
Thanks for your help :)
