Exporting block and stud walls - how should it export?
This forum section is only for IFC-related issues
Moult
Post by Moult »
The current behaviour is that a block wall, when exported to an IFC, is exported as whatever you choose it to be, but it loses its individual block geometry in the process.
I am unsure what is the more "correct" approach and what has the most "benefit" for various usecases. The questions are:
1. Should it be an IfcWallStandardCase? It certainly can be simplified as such, and this is what Revit does. This is not, however, a true representation. This limits the benefit of the IFC for purposes such as lighting simulation, and block setouts. It may lose valuable QS information in terms of number of blocks.
2. How do you export it as an IfcWallElementedCase?
Similarly, has anybody built a stud wall yet which exports as a correctly defined IfcWallElementedCase?
yorik
Founder
Re: Exporting block and stud walls - how should it export?
Post by yorik »
The blocks system is pretty new, I haven't looked yet as how to export it correctly to IFC. I actually don't think IFC has proper support for that... One easy "workaroud" is to right-click the wall in the tree view, edit its IFC properties, and there check the option to export it as Brep (or menu utils -> Toggle brep flag). The will make the IFC exporter discard the extrusion information of the wall, and export its geometry "as is" (as an IfcFacetedBrep geometry). This should export the blocks.
Moult
Post by Moult »
I see, the workaround of forcing a BREP is great! However, it is not necessarily semantically correct, as I believe it should be a IfcWallElementedCase made up of something, uh, else that I'm also not quite sure. I'll go ask on the BSi forums and see what they believe.
yorik
Founder
Post by yorik »
If we have a clear view of how such an object should be handled (stud walls too), it should not be hard to adapt the IFC exporter to export it the proper way...
Moult
Post by Moult »
I've just asked on the BSi forums on how to properly export a block wall. Even after reading the IfcWallElementedCase page, I am not sure.
However, I believe the IfcWallElementedCase page does describe how to deal with stud walls quite well. Do you mind reading through it? Can you put together a quick test in FreeCAD demonstrating the export of a stud wall?
yorik
Founder
Post by yorik »
Can you give the link to your buildingsmart post?
yorik
Founder
Post by yorik »
Link to IfcWallElementedCase http://www.buildingsmart-tech.org/ifc/I ... edcase.htm
Indeed this is pretty much what we want...
yorik
Founder
Post by yorik »
So the way i see it:
1) We need a solid, reliable way to identify in FreeCAD walls that are such elemented wall. One thing is easy, the IFC role/type of an object can already be set as such. Maybe that's the only rule we need, actually.
2) When exporting to IFC, if an object is set to IfcElementedWall, then we should look at a) its explicit components (either additions, or it is made from a compound) b) implicit components (blocks, or, in the future, if we extend the wall tool to be able to make its own studs)
3) We need to decide how to export the components that have no IFC type explicitly defined, but we can export them as IfcBuildingElementPart for now.
Moult
Post by Moult »
This is the BSI post:
https://forums.buildingsmart.org/t/how- ... k-wall/872
No replies yet, it is a pretty small community currently. Maybe there is no answer.
paullee
[EDIT] Re: Exporting block and stud walls - how should it export?
Post by paullee »
yorik wrote: Mon Jan 14, 2019 4:09 pm The blocks system is pretty new, I haven't looked yet as how to export it correctly to IFC. I actually don't think IFC has proper support for that... One easy "workaroud" is to right-click the wall in the tree view, edit its IFC properties, and there check the option to export it as Brep (or menu utils -> Toggle brep flag). The will make the IFC exporter discard the extrusion information of the wall, and export its geometry "as is" (as an IfcFacetedBrep geometry). This should export the blocks.
Hi, just re-visit this thread and playing around this Toggle brep flag feature... whilst it works, can't find anything about things below yet:-
[EDIT]
- can't find the IFC properties upon Right-click and the option... Utils / Toggle Brep Flag works though
- Is this Brep Flag 'per Object' based ?
- Can't find anywhere to see what is the current status of the Flag
(as no IFC properties?)
- Found Double-click to show Edit IFC Properties in Task Panel
- Should Export Brep Flag / Export Full Parametric... be in Data Tab for ease of use?
Thanks.
FreeCAD_0.19.16207_Conda_Py3Qt5_glibc2.12-x86_64.AppImage on Fedora 29
- Same at Arch or BIM wb
Screenshot from 2019-04-20 11-13-15.png (301.24 KiB) Viewed 1368 times
