import, read Autodesk Layer
This forum section is only for IFC-related issues
1D_Inc
Re: import, read Autodesk Layer
Postby 1D_Inc » Wed Jun 05, 2019 12:39 pm
Wow, here is some hierarchical discussion!
Well, here is a topic I made for Blender 2.8 considering hierarchical navigation, such as layers, groups, etc,
can be useful as entire problem overview (with pictures and descriptions)
https://devtalk.blender.org/t/layers-maniphest/6578
yorik
Site Admin
Postby yorik » Wed Jun 05, 2019 9:58 pm
I tweaked a bit the Draft VisGroup today, and bingo, we have a layers system in FreeCAD!
Screenshot from 2019-06-05 18-42-49.png (227.33 KiB) Viewed 272 times
It is now in master in git commit 5ee99ca4e
It's basically just an extension of the former Draft VisGroup tool, that has been renamed to Layer, since it's not a group anymore.
- You can add objects to/from layers by dragging them to/from the layers in the tree
- It doesn't remove objects from their groups, so an object can be both in a group and a layer. The layers system is fully independent
- Layers have an "OverrideChildren" property that you can set to False if you don't want to apply the layer colors to children
- If you turn a layer on/off, everything inside is turned on/off too
- Layers live in a special "Layers" group
- Brand new experimental feature: layer icons take the color of the layer! I'm not sure if this won't make things heavy, so let's keep an eye on it!
I had never played before with drag and drop support in python objects... Pretty cool, lots of possibilities...
I'lll let it live its life a little bit, if all goes well we can add support to it to the IFC and DXF importers.
1D_Inc
Postby 1D_Inc » Wed Jun 05, 2019 11:27 pm
Sounds gorgeous!
Layers are always needed in any CAD program on my mind.
Thank you))
