[ Solved ][ Ticket #4141: Multi-solid walls are not correctly exported to IFC ] Brep IFC export should be ON by default?
This forum section is only for IFC-related issues
paullee
Re: Brep IFC export should be ON by default?
Post by paullee »
Roy_043 wrote: Sat Sep 21, 2019 9:53 am IMO it is wise to add this to the Bug Tracker. Which category should I use: Arch or File Formats?
I just have a look at bug tracker, I have not put my previous found bug about exporting ArchWall based on Sketch
https://forum.freecadweb.org/viewtopic.php?f=39&t=31235
Do you want to report it together with the discussion about Brep IFC export together?
I think it should be Arch.
paullee
Post by paullee »
Just for info, PR submitted.
See if you can test if it fix your problem.
https://forum.freecadweb.org/memberlist ... le&u=8738
Roy_043
Re: [ Ticket #4141: Multi-solid walls are not correctly exported to IFC ] Brep IFC export should be ON by default?
Post by Roy_043 »
Thanks @paullee. I'll check when a new 0.19_pre has become available.
Roy_043
Post by Roy_043 »
@paullee: Thanks again for the fix. I confirm that it works.
OS: Windows 8.1 (6.3)
Version: 0.19.18811 (Git)
Hash: b809867021deb37be1039dab37b9fe1cafab254e
Python version: 3.6.7
Qt version: 5.12.1
Post by Kunda1 »
Please notate the ticket and also mark this thread [Solved] . Thanks
Roy_043
Post by Roy_043 »
I can't change the status of the ticket to solved. Probably only paullee can do that?
Roy_043 wrote: Mon Dec 09, 2019 10:09 am I can't change the status of the ticket to solved. Probably only paullee can do that?
Not the ticket, just this topic: prepend [Solved] to the subject of the first post in this topic. It's the title of the topic.
Roy_043
Re: [ Solved ][ Ticket #4141: Multi-solid walls are not correctly exported to IFC ] Brep IFC export should be ON by defa
Post by Roy_043 »
@chrisb: That was already done well before you posted your message.
