problems with IFC import
This forum section is only for IFC-related issues
Renato
Postby Renato » Tue Jan 07, 2020 10:12 am
Good morning
I tried to import an IFC file into Freecad but the results are not good
With Freecad 0.18 32 bitThe file is imported but some parts are not visible (for example the columns)
With Freecad 0.19 I have an error message and the file is not imported (the program crashes)
I tried to import the same file on another program (pCon Planner) and the file is imported correctly.
The versions i use:
Word size of FreeCAD: 32-bit
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 2.7.14
OCC version: 7.2.0
Locale: Italian/Italy (it_IT)
OS: Windows 10 (10.0)
Version: 0.19.19127 (Git)
Hash: ec18f070d13b195d946c3d955d8c21b2e60550e2
Python version: 3.6.8
Qt version: 5.12.1
version 0.19 64 bit
import ifc with 0.19.JPG (215.7 KiB) Viewed 423 times
version 0.18 32 bit
import ifc with 0.18 32bit.JPG (213.66 KiB) Viewed 423 times
import with other program
import ifc with p.JPG (214.77 KiB) Viewed 423 times
bernd
Re: problems with IFC import
Postby bernd » Tue Jan 07, 2020 10:53 am
It seams some geographical values are zero and thus a zero devision makes the programm crash.
Without the file it is nearly impossible to debug this.
bernd
Postby bernd » Tue Jan 07, 2020 10:59 am
If you can not post the file for some restrictions ...
Close FreeCAD. In FreeCAD 0.19 in Mod/Arch/importIFC.py comment these lines ... https://github.com/FreeCAD/FreeCAD/blob ... #L839-L842
like this
                if modelRC and modelRC.TrueNorth:
                    obj.Declination = -math.degrees(math.atan(modelRC.TrueNorth.DirectionRatios[0] / modelRC.TrueNorth.DirectionRatios[1]))
                    if(FreeCAD.GuiUp):
                        obj.ViewObject.CompassRotation.Value = obj.Declination
restart FreeCAD and import the file.
Renato
Postby Renato » Tue Jan 07, 2020 3:17 pm
Ok
This is the file ifc
struttura uffici.ifc
This is the file
(137.49 KiB) Downloaded 15 times
bernd
Postby bernd » Tue Jan 07, 2020 3:39 pm
bernd
Postby bernd » Tue Jan 07, 2020 4:39 pm
BTW: welcome back after 4.5 years forum break.
hlg
Postby hlg » Tue Jan 07, 2020 7:03 pm
I think the fix could be improved: https://github.com/FreeCAD/FreeCAD/comm ... t-36696448. Shall I make a pull request?
bernd
Postby bernd » Tue Jan 07, 2020 8:09 pm
great. I did not dig into the details just fixed the division by zero problem.
go for a PR :)
bernd
Postby bernd » Tue Jan 07, 2020 8:13 pm
may be even add the value informations you gave as a comment on the commit as some comment in the source code in the PR.
Renato
Postby Renato » Wed Jan 08, 2020 8:59 am
thank you
But sorry I didn't understand anything …
How does Freecad work to open this file correctly?
