Hi, anyone exported Window or Door to IFC find all the components, including the window/door frame, the solid door panel, all transparent ?
Testing in : [EDIT]
- FreeCAD_0.19-19242-Linux-Conda_Py3Qt5_glibc2.12-x86_64.Appimage
- on Fedora 30
- IFC++ and BIMserver 1.5.181, all show the components as transparent.
Anything needs to set in FC? Any ideas?
Thanks.
BIMserver
IFC++
Window / Door Frame, Solid Panel - All Transparent ?
Re: Window / Door Frame, Solid Panel - All Transparent ?
Hi. I tested with a wall, a window and a door. In IFC++ only the glass is transparent. No special setup was required. maybe you should reset the properties of your installation as default.
OS: Windows 10 (10.0)
Version: 0.19.19358 (Git)
Hash: 9e736095187450812e16ff9b92b6839e578f5506
Python version: 3.6.8
Qt version: 5.12.1
Qt version: 5.12.1
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Thanks for testing, further tested on simple case like yours and a closer look at your image.
[ EDIT ] Result in IFC++
- Simple window has it Frame and Glass Panel all transparent
- Simple Solid Door No problem - All solid
- Need to investigate in what case my previous doors were all transparent ?
Yes. You are right. glass and frame are transparent.
::bitacovir::
