IfcOpenShell experimental serializer: how to use it?
This forum section is only for IFC-related issues
alafr
Postby alafr » Sun Feb 16, 2020 3:24 pm
I can't get the IfcOpenShell serializer to work for IFC export.
According to the wiki:
However, IfcOpenShell v0.5 or above feature a serializer, which must be enabled in the Import/Export → IFC preferences. If enabled, this serializer is able to export very complex curved objects such as those based on NURBS, and thus avoid triangulated faces.
I have IfcOpenShell version 0.6.0b0 in my FreeCAD installation but if I activate the setting "Use IfcOpenShell serializer if available" in the IFC export preferences, and try to export a shape, I get this python exception:
  File "<string>", line 4, in <module>
  File "C:\Users\user\Downloads\FreeCAD_0.19.19591_x64_Conda_Py3QT5-WinVS2015\Mod\Arch\exportIFC.py", line 375, in export
    preferences=preferences
  File "C:\Users\user\Downloads\FreeCAD_0.19.19591_x64_Conda_Py3QT5-WinVS2015\Mod\Arch\exportIFC.py", line 1911, in getRepresentation
    p = geom.serialise(sh.exportBrepToString())
<class 'TypeError'>: _() missing 1 required positional argument: 'string'
I first ran into the issue when testing my pull request for fixing Arch Structure IFC export (see this other thread), but the problem is more general: I get the same exception even if I only select a simple Part Sphere primitive.
Is this IFC export broken or do I miss some kind of dependency/wrong setting?
OS: Windows 10 (10.0)
Version: 0.19.19591 (Git)
Hash: 27771fc6ee93170b6ecb978ff4da438a5b9cfe97
Python version: 3.7.3
Qt version: 5.12.5
Locale: Greek/Greece (el_GR)
bernd
Re: IfcOpenShell experimental serializer: how to use it?
Postby bernd » Sun Feb 16, 2020 6:34 pm
would you test ...
import ifcopenshell
ifcopenshell.version
should give 0.6 !
bernd
Postby bernd » Sun Feb 16, 2020 6:42 pm
I can confirm ...
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Arch/exportIFC.py", line 375, in export
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Arch/exportIFC.py", line 1906, in getRepresentation
on
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.19.19609 (Git)
Build type: Unknown
Branch: femtmp
Hash: a2eecf30596fdb9d9c16e18574279e67023c6c80
Qt version: 5.11.3
Locale: German/Switzerland (de_CH)
bernd
Postby bernd » Sun Feb 16, 2020 6:55 pm
test in Python ...
# make a new document
doc = App.ActiveDocument
co = doc.addObject("Part::Cone","Cone")
co.Radius1 = 200
co.Radius2 = 600
co.Height = 1000
doc.recompute()
sh = co.Shape.copy()
sh.Placement = co.getGlobalPlacement()
sh.scale(1000) # to meters
from ifcopenshell import geom
>>> co.Radius1 = 200
>>> co.Radius2 = 600
>>> co.Height = 1000
>>> doc.recompute()
1
<Solid object at 0x55a5c0e33c80>
TypeError: _() missing 1 required positional argument: 'string'
https://github.com/FreeCAD/FreeCAD/blob ... C.py#L1906
alafr
Postby alafr » Tue Feb 18, 2020 7:16 am
bernd wrote: Sun Feb 16, 2020 6:34 pm would you test ...
This is what I get for the version:
>>> import ifcopenshell
'0.6.0b0'
And I get the exact same exception with your python test.
Apparently to syntax is geom.serialise(schema, string). I can't find any documentation however.
>>> geom.serialise()
TypeError: _() missing 2 required positional arguments: 'schema' and 'string'
I installed Freecad 0.18 with ifcopenshell '0.5.0-dev' and it doesn't throw any exception. However, if I export the cone, the faces are triangulated. The option "Use IfcOpenShell serializer if available" doesn't seem to do anything...
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
bernd
Postby bernd » Tue Feb 18, 2020 8:09 pm
I have no idea how this serializer works. We need yorik or we need to ask at ifcopenshell forums directly.
yorik
Site Admin
Postby yorik » Tue Mar 03, 2020 2:05 pm
Sorry for the blackout guys!
The serializer normally works simply with giving it a Part shape, and it decides alone how to encode it in IFC. From what I have seen, it simply chooses between 2D geometry if there are no faces, IfcFacetedBrep if there are no NURBS surfaces (all flat faces with linear boundaries) or IfcAdvancedBrep in all other cases.
There is a long time I didn't test though, and I don't think many people use it outside of FreeCAD. By the look of the error, and the fact that IfcOpenShell 0.6 now works with multiple schemas, probably we now need to provide not only the Part shape but also the schema to use, that would make sense...
jahwobble
Postby jahwobble » Sat Oct 10, 2020 10:53 pm
I'm getting the same error (<class 'TypeError'>: _() missing 1 required positional argument: 'string') when trying to export pipes to IFC. Walls work fine. Strangely, it worked fine with pipes a few days ago and I haven't installed any updates.
Postby Kunda1 » Sat Oct 10, 2020 10:59 pm
jahwobble wrote: Sat Oct 10, 2020 10:53 pm FCver.jpg
Please don't paste your About info, instead use the Copy to clipboard function that was intended just for this reason.
OS: Manjaro Linux (KDE//usr/share/xsessions/plasma)
Version: 0.19.22665 (Git) AppImage
Hash: b0d7850406e046f3b7a8cd5da261e7d54df6bd99
Python version: 3.8.6
Qt version: 5.12.9
OCC version: 7.4.0
Notice that you are behind, please update and report back if you can still recreate the issue. Thanks
jahwobble
Postby jahwobble » Sun Oct 11, 2020 12:00 am
Sorry! Downloading...
Update: It works!
