I try to make a simple model, with a site, a building, two levels, with a material and simple walls.
How do you fix all the things so that the Bim is correct and then pass the Bim test?
How do you set all these missing things in particular that of the attached image Bim 3?
Bim test
Bim test
- bim 5.JPG (62.57 KiB) Viewed 1072 times
- bim 4.JPG (86.09 KiB) Viewed 1072 times
- how can I do?
- bim 3.JPG (105.69 KiB) Viewed 1072 times
- bim 2.JPG (377.44 KiB) Viewed 1072 times
- bim 1.JPG (336.26 KiB) Viewed 1072 times
