This forum section is only for IFC-related issues
paullee
Posts: 5098 Joined: Wed May 04, 2016 3:58 pm
Post
by paullee » Mon Mar 09, 2020 6:17 pm
Hi, continue testing
IFC export functions with the Villa Savoye model.
Have below findings:-
Have created a numbers of Windows w/ louvers
The transparency of the glass panes some time becomes opaque
So created a few Window objects w/o louvers and create another series of Window Objects w/ Louvers only
So far still good in FC
When, export to IFC and viewed in BIMserver, the louver seems disappear for the Window integrated w/ Louver
Model +
IFC at :-
https://github.com/paullee0/FreeCAD_Villa-Savoye
FreeCAD_0.19-19443-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
on
Fedora 30
BIMserver View of the FC Model - Window w/ Louver seem disappeared
Screenshot from 2020-03-10 01-47-58.png (323.42 KiB) Viewed 1280 times
FC Model View - Window Object Integrated w/ Louvers
Screenshot from 2020-03-10 01-49-10.png (345.6 KiB) Viewed 1280 times
Another Window Object w/ Louver Only - OK
Screenshot from 2020-03-10 01-49-48.png (346.19 KiB) Viewed 1280 times
Another Window Object w/o Louver, Superimposed at Same Location - OK
Screenshot from 2020-03-10 01-49-52.png (340.83 KiB) Viewed 1280 times
paullee
Post
by paullee » Mon Mar 09, 2020 6:24 pm
More findings :-
Whilst the concerned Window has the integrated Louver disappeared... when viewed from outside
When viewed from Inside, the Louvers are shown
BIMserver / BIMsurfer problem ? Exported w/ face normal inverted ?
...Other problems to be reported in BIMserver rather than here?
And when viewed in IFC ++, the integrated Louvers are shown whether from Outside or Inside...
Louvers are shown in BIMserver when viewed from Inside (not from Outside)
Screenshot from 2020-03-10 02-17-22.png (305.7 KiB) Viewed 1277 times
Louvers are shown in IFC ++ whether viewed from Inside or Outside
Screenshot from 2020-03-10 02-08-25.png (373.15 KiB) Viewed 1277 times
yorik
Founder
Posts: 13640 Joined: Tue Feb 17, 2009 9:16 pm
Post
by yorik » Thu Mar 19, 2020 3:51 pm
Then clearly a bimsurfer problem... But normals are not exported in IFC . So not sure what the problem would be... Maybe something to do with transparency...
