Hello to everyone,
when exporting walls to IFC I noticed a strange behaviour that I can't explain myself.
Wall_001 created by extruding a horizotal line along the z-axis and manipulated by a cut operation is OK but Wall_002 created by extruding a vertical wire along the x-axis seems to have problems (see below rapresentation in IFC++ and Blender). Is this a bug or is there a reason for it?
bernd wrote: ↑Tue Oct 06, 2020 10:38 am
I can not confirm the problem ... I used the conda build
Hi @Bernd,
Mmmh .. that's very strange. I used the conda build too. To be sure I downloaded and installed right now the latest conda build on my windows machine again and exported my above model one more time to a IFC-file ... same result
Can it depend on some wrong export parameter ???
Damn the preferences. I should have know this is the problem ...
I ever time use "force export as Brep". All solids will be exported as a bound of faces instead as extrusions. This way the export is much much better. But one can not get back a wall or column object wich is based on a line or face.
bernd wrote: ↑Tue Oct 06, 2020 8:24 pm
We might change the standard pref to "force export as BREP"
This is different from what you said a year ago:
https://forum.freecadweb.org/viewtopic.php?f=39&t=39423#p335358 wrote:If a solid is exported as brep it is just a bunch of faces. This is not smart because no one knows the thickness and the height of the wall later on. [...] We should not change the default export shape type to brep
wow good find. Mhh at least I did say and still say it is not smart.
I would for sure prefere the extrusion export if it would work. Lately the users who work with FreeCAD and ifc export has extended and thus the people posting their findings on this forum. We had a few cases where the extusion export did not export the geometry correct last year. ATM there is noone who fixes all these bugs in the extrusion export a short period of time after the finding.
IMHO the most important is to export the correct geometry no matter if smart or not. Thus I changed my mind in this regard or at least I would start a disscussion about this.
