IFC Viewer ifcplusplus
Re: IFC Viewer ifcplusplus
The normal vector of a face bound (IfcFaceBound) follows the "right hand rule".
That means, if the points are in counter-clockwise order, the normal vector points up.
If the attribute "Orientation" in IfcFaceBound is FALSE, the "left-hand-rule" is applied instead, so the face is flipped.
In a closed polyhedron (or closed mesh), all normal vectors point outward.
You can see the winding order here (also for openings): http://www.buildingsmart-tech.org/ifc/I ... edbrep.htm
Ah that must be it. Thanks a lot!!
Fabian, welcome to FreeCAD community and thanks for specify the problem.
BTW: Fabian is the maintainer of ifcplusplus library.
Oh, great! Nice to meet you Fabian, thanks for making that app, it's a great asset and the first solid IFC viewer for linux, thanks to Bernd too!
Victory!!!
That was it indeed. Thanks for the help Fabian!
Thanks for the information. My fault, external Carve uses a smal "c" for the library name internal Carve uses a big "C". I mixed it up. Wonder why it worked for me. Changed all CMakelists.txt to small "c" for internal Carve as well.yorik wrote:Ah I managed to compile. There was a caps problem, when it tries to link to the carve lib, it uses -lcarve (which looks for a libcarve.a or libcarve.so file) but the compiled carve lib is Release/libCarve.so (big C). So I did a simlink named libcarve.so in the same folder and things worked.
May be somwone has tried the file parking-halfspace.ifc I posted in the halfspace forum here http://www.forum.freecadweb.org/viewtop ... =20#p51685 in Ifc++ and found like me Ifc++ has Problems to display.
Thanks to the fast respond of Fabian the bug is allready fixed in windows build of Ifc++ on google code. Since my linuxbuild depends on the MacOSX build of Vtreem on github it seams we need to wait a bit.
I should find a possibility to directly use the Code of Fabian. A start would be to import his snvrepo to git using git-snv. Does someone know a good resource how to do that?
Hi Bernd,bernd wrote:A start would be to import his snvrepo to git using git-snv. Does someone know a good resource how to do that?
When I first read that I thought Git can read svn but I see we have to install another package "git-svn" to make it work in Debian/Ubuntu etc.....Now re-reading your post, I think you knew that already...
Here is a link that might help...its a quick run through on integrating SVN and git.
http://viget.com/extend/effectively-usi ... subversion
Jim
Thanks Jimjmaustpc wrote:... Here is a link that might help...its a quick run through on integrating SVN and git...
Find R42 of IFCPlusPlus for Linux on https://github.com/berndhahnebach/IfcPlusPlus
Changes:
- It is based on R42 of Fabian Gerold which fixes the halfspace bug
- parking-halfspace.ifc from viewtopic.php?f=8&t=6371&hilit=halfspac ... =20#p51685 is displayed the way it should be
- The repo is no longer a clone from vtreems repo. It now depends directly on Fabian Gerolds repo. Thus it is a new Repo.
- The old repo has been moved to IFCPlusPlus-Vtreem
Info:
- The internal Carve is used
- Cmake still needs the path of internal Carve. See README
Great! Ah, I solved the problem of the horizontal extrusions. The problem was that all 2D profiles in IFC must lie on the XY plane. Then, you can apply a placement to it to rotate it to the correct position, but it must first be defined on the XY plane, I wasn't aware of that...
I'm starting a new testfile here, which now uses the units system: https://dl.dropboxusercontent.com/u/754 ... use2.fcstd
And the corresponding ifc file: https://dl.dropboxusercontent.com/u/754 ... house2.ifc
The horizontal extrusions now work correctly in all apps I tested (Ifc++, Revit, ArchiCAD), but the circular columns still don't work in Revit (But well in the others, though). Still some detail I'm missing probably.
