IFC Viewer ifcplusplus
This forum section is only for IFC-related issues
bernd
Re: IFC Viewer ifcplusplus
Postby bernd » Sun Sep 08, 2019 9:27 pm
Cyril
Postby Cyril » Mon Sep 09, 2019 5:19 pm
updated https://github.com/berndhahnebach/ifcpl ... its/master
Thanks Bernd !
The AUR recipe I updated few months ago still works like a charm.
I blog about HVAC / BIM / Energy : pythoncvc.net. If you like you can follow the RSS feed.
bernd
Postby bernd » Tue Sep 10, 2019 2:01 pm
bernd
Postby bernd » Wed Sep 11, 2019 10:04 am
PR accepted, means upstream head does compile on Linux too :-) ATM my repo only fixes the icons ands an example and some informations.
paullee
Postby paullee » Mon Oct 07, 2019 6:23 pm
Previous build (on Fedora 29?) seem does not run on Fedora 30... trying to rebuild have following errors, no idea yet what is/are missing.
Any idea? Thanks!
paullee@localhost build]$ cmake ../
-- Build type: Release
-- Boost version: 1.69.0
-- Qt5 is used
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
OSGDB_LIBRARY_DEBUG (ADVANCED)
    linked by target "SimpleViewerExample" in directory /run/media/paullee/Data_40G_EXT3/Temp_Download/ifcplusplus_bernd/ifcplusplus-master/examples/SimpleViewerExampleQt
OSGFX_LIBRARY_DEBUG (ADVANCED)
OSGGA_LIBRARY_DEBUG (ADVANCED)
OSGTEXT_LIBRARY_DEBUG (ADVANCED)
OSGUTIL_LIBRARY_DEBUG (ADVANCED)
OSGVIEWER_LIBRARY_DEBUG (ADVANCED)
OSG_LIBRARY_DEBUG (ADVANCED)
-- Configuring incomplete, errors occurred!
bernd
Postby bernd » Mon Oct 07, 2019 7:06 pm
which code are you trying to compile. This has been fixed in ifcquery upstream ... https://github.com/ifcquery/ifcplusplus ... 50360ece94
paullee
Postby paullee » Mon Oct 07, 2019 11:25 pm
Thanks for the hint and fix, downloaded and cmake is good now, make is in progress....
which code are you trying to compile/11a41e6f4e1bfb195e2d3e6356197f50360ece94
I am afraid I do not understand what is it mean by 'code', I have minimal knowledge in compiling... python version?
paullee
Postby paullee » Tue Oct 08, 2019 12:01 am
Unfortunately, when it comes to end of 99%, it fails with errors I have no idea about :)
[ 99%] Building CXX object examples/SimpleViewerExampleQt/CMakeFiles/SimpleViewerExample.dir/src/viewer/moc_ViewerWidget.cpp.o
[ 99%] Building CXX object examples/SimpleViewerExampleQt/CMakeFiles/SimpleViewerExample.dir/src/IfcPlusPlusSystem.cpp.o
[ 99%] Building CXX object examples/SimpleViewerExampleQt/CMakeFiles/SimpleViewerExample.dir/src/main.cpp.o
[ 99%] Building CXX object examples/SimpleViewerExampleQt/CMakeFiles/SimpleViewerExample.dir/src/cmd/CmdRemoveSelectedObjects.cpp.o
In file included from /run/media/paullee/Data_40G_EXT3/Temp_Download/ifcplusplus_bernd/ifcplusplus-master/IfcPlusPlus/src/ifcpp/geometry/Carve/GeometryConverter.h:34,
                 from /run/media/paullee/Data_40G_EXT3/Temp_Download/ifcplusplus_bernd/ifcplusplus-master/examples/SimpleViewerExampleQt/src/IncludeGeometryHeaders.h:29,
                 from /run/media/paullee/Data_40G_EXT3/Temp_Download/ifcplusplus_bernd/ifcplusplus-master/examples/SimpleViewerExampleQt/src/IfcPlusPlusSystem.cpp:38:
/run/media/paullee/Data_40G_EXT3/Temp_Download/ifcplusplus_bernd/ifcplusplus-master/IfcPlusPlus/src/ifcpp/geometry/Carve/RepresentationConverter.h: In member function ‘void RepresentationConverter::subtractOpenings(const std::shared_ptr<IfcElement>&, std::shared_ptr<ProductShapeData>&)’:
/run/media/paullee/Data_40G_EXT3/Temp_Download/ifcplusplus_bernd/ifcplusplus-master/IfcPlusPlus/src/ifcpp/geometry/Carve/RepresentationConverter.h:1076:127: error: invalid initialization of reference of type ‘const std::shared_ptr<BuildingEntity>&’ from expression of type ‘std::__shared_ptr<IfcElement, __gnu_cxx::_S_atomic>::element_type*’ {aka ‘IfcElement*’}
 1076 |           CSG_Adapter::computeCSG( product_meshset, opening_meshset, carve::csg::CSG::A_MINUS_B, result, this, ifc_element.get() );
In file included from /run/media/paullee/Data_40G_EXT3/Temp_Download/ifcplusplus_bernd/ifcplusplus-master/IfcPlusPlus/src/ifcpp/geometry/Carve/Sweeper.h:26,
                 from /run/media/paullee/Data_40G_EXT3/Temp_Download/ifcplusplus_bernd/ifcplusplus-master/IfcPlusPlus/src/ifcpp/geometry/Carve/RepresentationConverter.h:59,
/run/media/paullee/Data_40G_EXT3/Temp_Download/ifcplusplus_bernd/ifcplusplus-master/IfcPlusPlus/src/ifcpp/geometry/Carve/CSG_Adapter.h:785:102: note: in passing argument 6 of ‘void CSG_Adapter::computeCSG(std::shared_ptr<carve::mesh::MeshSet<3> >&, std::shared_ptr<carve::mesh::MeshSet<3> >&, carve::csg::CSG::OP, std::shared_ptr<carve::mesh::MeshSet<3> >&, StatusCallback*, const std::shared_ptr<BuildingEntity>&)’
  785 |   shared_ptr<meshset_t >& result, StatusCallback* report_callback, const shared_ptr<BuildingEntity>& entity )
                 from /run/media/paullee/Data_40G_EXT3/Temp_Download/ifcplusplus_bernd/ifcplusplus-master/examples/SimpleViewerExampleQt/src/main.cpp:36:
                 from /run/media/paullee/Data_40G_EXT3/Temp_Download/ifcplusplus_bernd/ifcplusplus-master/examples/SimpleViewerExampleQt/src/cmd/CmdRemoveSelectedObjects.cpp:24:
make[2]: *** [examples/SimpleViewerExampleQt/CMakeFiles/SimpleViewerExample.dir/build.make:165: examples/SimpleViewerExampleQt/CMakeFiles/SimpleViewerExample.dir/src/IfcPlusPlusSystem.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [examples/SimpleViewerExampleQt/CMakeFiles/SimpleViewerExample.dir/build.make:178: examples/SimpleViewerExampleQt/CMakeFiles/SimpleViewerExample.dir/src/main.cpp.o] Error 1
make[2]: *** [examples/SimpleViewerExampleQt/CMakeFiles/SimpleViewerExample.dir/build.make:191: examples/SimpleViewerExampleQt/CMakeFiles/SimpleViewerExample.dir/src/cmd/CmdRemoveSelectedObjects.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:202: examples/SimpleViewerExampleQt/CMakeFiles/SimpleViewerExample.dir/all] Error 2
make: *** [Makefile:130: all] Error 2
[paullee@localhost build]$
bernd
Postby bernd » Tue Oct 08, 2019 4:59 am
which code do you use? My repo or the original repo or another one? How do you get the code? Download zip by the use of git, or however?
paullee
Postby paullee » Tue Oct 08, 2019 10:27 am
Thanks, I download the Zip from your repo.
