[solved] what is wrong with or before the export?
- thomas-neemann
An error occurs when exported as equipment.
everything is correct when exported as a structure.
thomas
OS: Ubuntu 18.04.5 LTS (ubuntu:GNOME/xubuntu)
Version: 0.19.23463 (Git) AppImage
Hash: adc6db8f32c17e9f67cb82aa7962d1e42ce061c6
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
thomas
Qt version: 5.12.5
OCC version: 7.4.0
Last edited by thomas-neemann on Thu Jan 07, 2021 5:45 am, edited 1 time in total.
- thomas-neemann
Re: what is wrong with or before the export?
the problem does not exist via sketcher and part extrusion
thomas
thomas
- thomas-neemann
if you make a simple copy (part) the problem does not arise either
I can not see any error in your video. You are creating geometry, exporting importing, once as equipment, once as structure. No error at all, you did not even show the report console to see the errors.
- thomas-neemann
the geometry changes.
this is what it looks like before export.
and so after the import
would you provide the FreeCAD file?
- thomas-neemann
- ifc-test.FCStd
- (13.23 KiB) Downloaded 102 times
- test.ifc
- (2.7 KiB) Downloaded 119 times
Wenn das objekt in der FreeCAD-datei exportiere und in einem externen programm viewe oder wieder reimportiere ist alle ok.
Wenn ich dein ifc importiere stimmt das wie in Deinen Screens nicht mit obigen überein.
Ich bin aber nicht in der lage durch export der FreeCAD datei das fehlerhafte ifc zu erzeugen.
upps we are in the english forum ...
If I export the objekt to ifc and reimport it everything works fine. If I import your ifc I have the same wrong geometry after import. But I am not able to create the broken ifc on export.
found it. As said before. Use in export prefs force exprot as brep. If this is used the geometry in the ifc is correct exported.
- thomas-neemann
1000 thanks. that is the solution. does it make sense to use this setting and the import setting: allow invalid shapes to set as default out of the box?
