[HELP] How to export a equipment model to IFC
This forum section is only for IFC-related issues
pablogil
Post by pablogil »
I would like to design simple equipment models to create a IFC library (furniture, electric machinery, etc.).
I can't figure out how to correctly export it to IFC, even a simple WB Part cube... I always get:
wstring_convert: to_bytes error
This is the report log:
10:41:35  Traceback (most recent call last):
  File "<string>", line 7, in <module>
  File "/Applications/FreeCAD-asm3-Daily-20210615.app/Contents/Resources/Mod/Arch/exportIFC.py", line 1550, in export
    ifcfile.write(filename)
  File "/Applications/FreeCAD-asm3-Daily-20210615.app/Contents/Resources/lib/python3.9/site-packages/ifcopenshell/ifcopenshell_wrapper.py", line 1595, in write
    return _ifcopenshell_wrapper.file_write(self, fn)
<class 'RuntimeError'>: wstring_convert: to_bytes error
If I test @Yorik house in his FreeCAD manual, everything goes fine and I get a IFC, but not if I try to model something by myself.
Is there any tutorial about how to create this simple components and successfully export them as IFC?
This is my cube test:
Thanks
cube_v01.FCStd
(23.32 KiB) Downloaded 123 times
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
Roy_043
Re: [HELP] How to export a equipment model to IFC
Post by Roy_043 »
I am able to export the Site in your file after entering a value for the Address property and the Postal Code property.
OS: Windows 8.1 (6.3)
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
pablogil
Post by pablogil »
Roy_043 wrote: Thu Jul 08, 2021 1:31 pm I am able to export the Site in your file after entering a value for the Address property and the Postal Code property.
Any value in Address and Postal Code property or should it be formatted somehow?
You select the Site element and then export?
Do you have any special setup in Preferences/Import-Export/IFC export panel?
Could I get your modified FCstd file to test it here?
Thanks
Roy_043
Post by Roy_043 »
pablogil wrote: Thu Jul 08, 2021 2:36 pm Any value in Address and Postal Code property or should it be formatted somehow?
Just random input.
pablogil wrote: Thu Jul 08, 2021 2:36 pm You select the Site element and then export?
Yes.
pablogil wrote: Thu Jul 08, 2021 2:36 pm Do you have any special setup in Preferences/Import-Export/IFC export panel?
See image.
cube_v01_roy.FCStd
(21.57 KiB) Downloaded 129 times
pablogil
Post by pablogil »
Error persists here with your file and same exporting Preferences as you...
Here is my setup:
OS: macOS Mojave (10.14)
Version: 2021.615.24301 +3747 (Git)
Branch: LinkDaily
Hash: ecbfba008c481db4cb17bf8bd514b2d12690a8e5
Python version: 3.9.4
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
Locale: C/Default (C)
Also tried with:
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
and same error:
09:07:07  Traceback (most recent call last):
  File "<string>", line 4, in <module>
  File "/Applications/FreeCAD_0.19-24276.app/Contents/Resources/Mod/Arch/exportIFC.py", line 1550, in export
  File "/Applications/FreeCAD_0.19-24276.app/Contents/Resources/lib/python3.8/site-packages/ifcopenshell/ifcopenshell_wrapper.py", line 1458, in write
Any other ideas?
yorik wrote: ping
Thanks
bernd
Post by bernd »
works without any problem. file from the first post
doc = FreeCAD.openDocument('C:/Users/BHA/Desktop/cube_v01.FCStd')
import exportIFC
prefs = {
    "DEBUG": True,
    "CREATE_CLONES": False,
    "FORCE_BREP": False,
    "STORE_UID": True,
    "SERIALIZE": False,
    "EXPORT_2D": True,
    "FULL_PARAMETRIC": False,
    "ADD_DEFAULT_SITE": False,
    "ADD_DEFAULT_BUILDING": True,
    "ADD_DEFAULT_STOREY": False,
    "IFC_UNIT": "metre",
    "SCALE_FACTOR": 0.001,
    "GET_STANDARD": False,
    "EXPORT_MODEL": "arch",
    "SCHEMA": "IFC2X3",
exportIFC.export([doc.Project], "C:/Users/BHA/Desktop/cube_v01.ifc", preferences=prefs)
OS: Windows 10 (10.0)
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Qt version: 5.12.9
OCC version: 7.5.2
Locale: German/Switzerland (de_CH)
bernd
Post by bernd »
bernd
Post by bernd »
BTW: us the pref "FORCE_BREP" set to False could lead to corrupt geometry. We have seen various problems with this setting. If set to True you should not get any problem if your geometry has no errors in FreeCAD.
pablogil
Post by pablogil »
I still get the same error, even with the build you share with me...
16:42:50  Traceback (most recent call last):
  File "/Applications/FreeCAD_weekly-builds-25220.app/Contents/Resources/Mod/Arch/exportIFC.py", line 1550, in export
  File "/Applications/FreeCAD_weekly-builds-25220.app/Contents/Resources/lib/python3.9/site-packages/ifcopenshell/ifcopenshell_wrapper.py", line 1595, in write
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
pablogil
Post by pablogil »
I have tried in a fresh Windows 10 FreeCAD 0.19 build and it worked fine without errors:
OS: Windows 10 Version 1909
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Spanish/Spain (es_ES)
It has to be something related with macOS...
