(solved) crash with ifc import?
- thomas-neemann
what can you do to prevent the freecad crashes during import e.g. this ifc file?
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.26720 (Git) AppImage
Branch: (HEAD detached at 7bca26e)
Hash: 7bca26e7c14d4d43374ff7e0c8582735b249cbfd
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
edit
usbim.viewer+ can view it
Qt version: 5.12.9
OCC version: 7.5.3
edit
Last edited by thomas-neemann on Tue Feb 01, 2022 8:01 am, edited 4 times in total.
- thomas-neemann
Re: Workaround for crash with ifc import?
if you create a compound with upgrade or part compound, it works. in my opinion that is enough to take part in a bim process based on geometry without any attributes.
Re: [solved] Workaround for crash with ifc import?
To the best of my knowledge I'm using the default IFC Import settings and using the build below, the original file imports error free:thomas-neemann wrote: ↑Tue Jan 04, 2022 8:31 am what can you do to prevent the freecad crashes during import e.g. this ifc file?
923.ifc
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.26858 (Git)
Hash: e209bc706d35121098f9bac779bc6b09c24ddd95
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Tree:
- thomas-neemann
thank you for your cooperation. I also tested it with 0.19-3 and 0.18. apparently it works better on windows than on linux.
Greetings Thomas
- thomas-neemann
next problem (crash by import)
http://openifcmodel.cs.auckland.ac.nz/Model/Details/377
Qt version: 5.12.9
OCC version: 7.5.3
Version: 0.19.24366 (Git) AppImage
Branch: (HEAD detached at 0f9259c)
Hash: 0f9259cda103ae1824ac16c68ac9b4a0d54b05fc
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
Confirmed crash on below AppImages on Fedora and Settings :-
OS: Fedora 34 (Workstation Edition) (GNOME/gnome)
Version: 0.19.24367 (Git) AppImage
Branch: (HEAD detached at c403473)
Hash: c4034739c472bf07fab55ca8f9225a52d4b88cf5
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
Extract of log in AppImage 26306
Log: Init: Initializing /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/Mod/Web... done
Msg: Opening '/home/paullee/Documents/Doc/00_ FreeCAD Test_ COPY/0_ FreeCAD__ Forum/FreeCAD_ thomas-neemann/923.ifc'... Msg: done.
Msg: Building types and relationships table...
Msg: done.
Msg: Parsing 13 BIM objects...
Log: Loading GUI of Part module... done
Msg: 1Msg: Msg: /Msg: Msg: 13Msg: Msg: object #60Msg: Msg: :Msg: Msg: IfcWallMsg: Msg: no layer foundMsg: Msg: IfcWallMsg: Msg: (arch)Msg: Err: Program received signal SIGSEGV, Segmentation fault.
Err: #0 /lib64/libc.so.6(+0x3d320) [0x7fb2b4d04320]
Err: #1 0x7fb27b6623f5 in Standard_Transient::DecrementRefCounter() const from /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/lib/./libTKernel.so.7+0x5
Err: #2 /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/lib/python3.9/site-packages/ifcopenshell/_ifcopenshell_wrapper.so(+0x23d5432) [0x7fb1df5e5432]
Err: #3 /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/lib/python3.9/site-packages/ifcopenshell/_ifcopenshell_wrapper.so(+0x23e6a25) [0x7fb1df5f6a25]
Err: #4 /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/lib/python3.9/site-packages/ifcopenshell/_ifcopenshell_wrapper.so(+0x23e6b01) [0x7fb1df5f6b01]
Err: #5 0x7fb1dff1d5e0 in vtable for NCollection_BaseMap from /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/lib/python3.9/site-packages/ifcopenshell/_ifcopenshell_wrapper.so+0x10
- thomas-neemann
thank you for testing
workaround:
works very quickly (in a few minutes)
linux-shell:
./IfcConvert --no-normals 1.ifc 1.dae
IfcOpenShell IfcConvert 0.6.0b0 (OCC 7.3.0)
Scanning file...
Done scanning file
Parsing input file took 6 seconds
Creating geometry...
Done creating geometry (16881 objects)
Log:
[Error] {2_uJNkuoDEcAk5Hec1nPUQ} Opening subtraction failed for 1 openings
#659652=IfcWallStandardCase('2_uJNkuoDEcAk5Hec1nPUQ',#41,'Basic Wall:_H-BW-1:2272912',$,'Basic Wall:_H-BW-1',#659615,#659650,'2272912')
Conversion took 3 minutes 30 seconds
Cool ! Did you compile the ifcopenshell ? Or some way to use the "built-in" in the AppImage?thomas-neemann wrote: ↑Fri Jan 07, 2022 8:00 pm workaround:
linux-shell:
./IfcConvert --no-normals 1.ifc 1.dae IfcOpenShell IfcConvert 0.6.0b0 (OCC 7.3.0) Scanning file... Done scanning file Parsing input file took 6 seconds Creating geometry... Done creating geometry (16881 objects) Log: [Error] {2_uJNkuoDEcAk5Hec1nPUQ} Opening subtraction failed for 1 openings #659652=IfcWallStandardCase('2_uJNkuoDEcAk5Hec1nPUQ',#41,'Basic Wall:_H-BW-1:2272912',$,'Basic Wall:_H-BW-1',#659615,#659650,'2272912') Conversion took 3 minutes 30 seconds
Can you report it in the Mantis BugTracker ?
Thanks
- thomas-neemann
i can't remember compiling it. i compile very little because i often have problems with it.
I think it's from here
http://ifcopenshell.org/ifcconvert
how do i report it in the bug tracer?
is there an instruction?
