Proposal for a bim workflow
This forum section is only for IFC-related issues
thomas-neemann
Post by thomas-neemann »
here is a proposal for a bim workflow.
first created e.g. the surveying office a master ifc file for the same origin and orientation of all following ifc files.
the architect creates a 3d sketch for the structural engineer as an ifc with reference to the master ifc.
https://www.youtube.com/watch?v=EJsbsIc4MFk
phpBB [video]
Suggestions for improvement are welcome
Greetings Thomas
Last edited by thomas-neemann on Tue Feb 08, 2022 2:31 pm, edited 1 time in total.
thomas-neemann
Re: Proposal for a bim workflow
in this video you will see how the architect creates a modell from the static information, which he sends to the electrician as an ifc. the electrician creates an ifc file with the cables, sockets, etc.
then the two ifc files (from the architect and from the electrician) are merged into an ifc-bim model. for approval meetings, collision checks, etc
https://www.youtube.com/watch?v=tY333B0yzho
phpBB [video]
thomas-neemann
here is the ifc bim model for download
ifc-bim-modell.zip
(10.59 KiB) Downloaded 90 times
thomas-neemann
because it is very complicated to work together on a bim with many frequently changing companies with attributes, i suggest working with colors. that is very compatible and intuitive
here the difference between 220v blue and 380v red
https://www.youtube.com/watch?v=vq46rUttHy0
phpBB [video]
ifc-elektro-color.ifc
(247.7 KiB) Downloaded 83 times
thomas-neemann
here is an example of heating planning in the bim process. if you have skilfully saved the heating models (at the right height, standing and in the middle above the origin) you can quickly place the heating "hanging on the mouse" with move.
https://www.youtube.com/watch?v=95s7k5cCVlA
phpBB [video]
thomas-neemann
for tendering and billing, e.g. door lists are required.
in the bim process, however, you don't want separate files that could be mixed up or contain old information. everything should be contained in the ifc file.
instead of working with ifc attributes, which are often incompatible, one could write the required information in the part names.
here's an example
https://www.youtube.com/watch?v=K1wMhG6H74E
phpBB [video]
ifc-tuerenliste.ifc
(304.9 KiB) Downloaded 81 times
thomas-neemann
here is an example of using freecad to calculate volumes and areas and then creating an ifc file with the results (without attributes in the part names)
https://www.youtube.com/watch?v=wotlH68lg5o
phpBB [video]
thomas-neemann
here is an example of a slot/breakthrough test with ifc
https://www.youtube.com/watch?v=PvuntXCoErA
phpBB [video]
edit
4D BIM
https://www.ganttproject.biz/download/free#win
https://www.ganttproject.biz/download/free#linux
thomas-neemann
here is an example of room designations and room information (you can add more to the part name). very compatible. should work 100%
https://www.youtube.com/watch?v=HG4rsZ0U_1k
phpBB [video]
thomas-neemann
paper plans are often required. e.g. for a building application or the construction site. here is a way to print 2d and 3d plans with labeling and dimensions from the ifc model
https://www.youtube.com/watch?v=ZnZfmrjWLbI
phpBB [video]
also bcf
https://www.youtube.com/watch?v=20p3ZRh15Hw
phpBB [video]
and as a special case, editing an ifc file is possible
https://www.youtube.com/watch?v=20tgnbMG0xA
phpBB [video]
