Stable parametric model of a bridge, export as ifc in the bim process for the structural engineer
This forum section is only for IFC-related issues
thomas-neemann
Post by thomas-neemann »
1120-fin.FCStd
(16.58 KiB) Downloaded 60 times
1120-fin.ifc
(7.82 KiB) Downloaded 65 times
making of video
https://forum.freecadweb.org/viewtopic. ... 25#p597575
yorik
Founder
Re: Stable parametric model of a bridge, export as ifc in the bim process for the structural engineer
Post by yorik »
Very cool! At some point I'd like to have a kind of back-and-forth workflow between proper volumetric structural objects and wire diagram... So you could model with, say, your design intent, export the wire schema for structural calculation, then adapt back your design instantly or even automatically
thomas-neemann
yorik wrote: Fri May 27, 2022 9:52 am
yes, that is already partly possible with your frame
https://www.youtube.com/watch?v=p7o6Zxh9rmk
phpBB [video]
