Workbench BOLTSFC installed but no menue
wbeppler
Postby wbeppler » Wed May 16, 2018 12:15 pm
hello,
i installed in fc 0.18 using tne addon-manager the workbench extesion "boltsfc" but i can not find any more workbench. what am i doing wrong ? how to use boltsfc ?? in the addonmanager the green check is set.
thanks a lot
w
Re: Workbench BOLTSFC installed but no menue
Postby chrisb » Wed May 16, 2018 1:26 pm
Did you restart FreeCAD? Additional workbenches are not visible before restarting.
wbeppler
Postby wbeppler » Wed May 16, 2018 1:32 pm
yes, i restarted
Postby chrisb » Wed May 16, 2018 5:07 pm
Do you have some other additional workbench that works? If not, can you try installing Fasteners?
And please add your full FreeCAD info.
wbeppler
Postby wbeppler » Wed May 16, 2018 5:13 pm
thanks for tip with fasteners, i installed, restarted and the new workbench in there, now i have a first look to this....
best regards
my version:
OS: Ubuntu 16.04.4 LTS
Version: 0.18.13712 (Git)
Build type: None
Hash: 57b7f3389a846454d01c2abea509b8394099735c
Python version: 2.7.12
OCC version: 7.2.0
Postby bernd » Fri May 18, 2018 5:15 am
BOLTSFC is not a wb it is a macro. You should have a macro called start bolts.
wbeppler
Postby wbeppler » Fri May 18, 2018 10:42 am
hi bernd,
thanks for info but...
i searched start bolts macro but could not find. not in the macro menu in the list and not in addonmanager in the macro tab see pictures (system-tab is empty)
today my preview is out of order, i can see more than my 2 attached pictures but i removed in the textbox...
Postby bernd » Sat Sep 15, 2018 8:50 pm
A bit late but since you get an email you may read this anyway.
If you install BOLTSFC by the addon manager wait some time ... may be 5 minutes. It will not tell you it is successful installed, but it will copy it anyway. Open a Python Console in FreeCAD and put in
import BOLTS
If you get no error message BOLTS is installed.
Afterwards go to your FreeCAD Mod directory. There should be a file called "start_bolts.FCMacro inside the BOLTSFC directory. Move this file into your macro folder. Run this macro to start BOLTS.
for reference: https://github.com/FreeCAD/FreeCAD-addons/issues/102
