[solved] problems with boost Library 61
Manja
Postby Manja » Wed May 15, 2019 6:43 am
Hello,
i have following problem with compiling actual version 0.19 from FreeCAD:
/home/myhome/free-cad-code-0.18/src/Gui/GestureNavigationStyle.cpp: In member function ‘boost::statechart::result Gui::GestureNavigationStyle::IdleState::react(const Gui::GestureNavigationStyle::Event&)’:
/home/myhome/free-cad-code-0.18/src/Gui/GestureNavigationStyle.cpp:275:24: error: ‘no_reaction’ is not a member of ‘boost::statechart::result {aka boost::statechart::detail::safe_reaction_result}’
                 return sc::result::no_reaction;
i think, the boost Library v. 61 from SuSE Leap 42.3 ist to old.
SuSE Leap 42.3 64 Bit
with kind regards, Berthold
Linux SuSE leap 15.1 , 64Bit
fjullien
Re: problems with boost Library 61
Postby fjullien » Wed May 15, 2019 7:15 am
I had the same problem yesterday. After I contacted DeepSOIC in PM, he told me there is a mistake in his code:
Can you please replace all occurences of
... with ...
forward_event()
... in GestureNavigationStyle.cpp, and see if it compiles?
And indeed it works after that. I think he'll do a PR for that.
Franck.
Manja
Re: [solved] problems with boost Library 61
Postby Manja » Wed May 15, 2019 8:49 am
Hello Franck,
thank you !!!! :)
DeepSOIC
Postby DeepSOIC » Wed May 15, 2019 10:13 am
