[SOLVED] AppImage help is gone (was working before)
__Vinz__
Postby __Vinz__ » Tue Nov 26, 2019 10:26 pm
Hi there,
Thanks again for FreeCAD, it is a great tool and I plan on introducing it to people at work. To that end, I was preparing for a workshop tomorrow. I have been using the AppImage as advised by multiple people on the forum (this is Fedora 30) and that has worked great so far.
However, since yesterday, I cannot open the Help anymore, I am only greeted with an error about "Error loading: qthelp://org.freecad.usermanual/doc/Online_Help_Startpage.html" (see attachment).
I don't know what happened, as far as I know it might have been happening after FreeCAD crashed but I am not sure.
Started with logging enabled (full log attached), I can see in particular:
Log: Help file at /tmp/.mount_FreeCA4jhP6z/usr/doc/freecad.qhc
Log: Help view: Could not unregister documentation file
/tmp/.mount_FreeCA4jhP6z/usr/doc/freecad.qch
Reason:
Log: Help view: Could not register documentation file
Reason:
Namespace org.freecad.usermanual already exists.
Log: Help view: XmbTextListToTextProperty result code -2
I am puzzled because I don't know where to look to fix this issue. I have tried removing the ~/.FreeCAD directory without any effect. I have also redownloaded the AppImage without success.
Thanks for your assistance!
OS: Fedora 30 (Workstation Edition)
Version: 0.18.16146 (Git) AppImage
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
FreeCAD.log
(11.49 KiB) Downloaded 4 times
triplus
Re: AppImage help is gone (was working before)
Postby triplus » Tue Nov 26, 2019 10:38 pm
Hi @__Vinz__
Unfortunately previous two attempts didn't yield results, there is still a quirk involved. Will go for a third attempt, when the time permits:
https://github.com/FreeCAD/FreeCAD-AppI ... -527961997
P.S. Currently the only advice i can give you is to delete the following file, before starting the AppImage:
$HOME.local/share/freecad/freecad/freecad.qhc
__Vinz__
Postby __Vinz__ » Wed Nov 27, 2019 9:03 am
Hi triplus,
Thanks for your timely answer and the Github link. The workaround is perfectly fine for me and I confirm the help now shows correctly, that's great!
Let me know if you want me to report this issue on a bug tracker if that helps.
Thanks you also for your work on the AppImage, this is very useful to run the latest FreeCAD easily. I run Fedora and it looks like, while it runs the latest FreeCAD, the OCC kernel is way behind (according to yorik). The AppImage allows to solve this issue.
vocx
Postby vocx » Wed Nov 27, 2019 5:58 pm
...I run Fedora...
If you search around in the forum you'll see that there are some issues with running FreeCAD in Fedora 28 and up. It seems the packagers haven't properly maintained the FreeCAD packages over the years. Now there is a user, hobbes, that is trying to solve this situation in Fedora 31, but it's a complex matter. If you have any way of helping out with the packaging or documentation or testing, you should look into it.
__Vinz__
Re: [SOLVED] AppImage help is gone (was working before)
Postby __Vinz__ » Wed Nov 27, 2019 8:51 pm
Thanks for mentioning that. In my case I was referring to https://forum.freecadweb.org/viewtopic. ... 35#p286806, where NormandC (sorry, not yorik) was mentioning how old the OCC is in the Fedora package. I will see to find the info about the Fedora builds, could it be https://forum.freecadweb.org/viewtopic. ... 3&start=20? I'll chime in the thread.
triplus
Postby triplus » Mon Feb 17, 2020 9:40 pm
AppImage and documentation support:
https://forum.freecadweb.org/viewtopic. ... 24#p369824
