git problem on push
HoWil
git problem on push
Postby HoWil » Sat May 23, 2020 5:45 pm
Good afternoon,
Hope this is the right place to ask questions regarding the use of git.
I get the following error when trying to push a commit to my github repo:
w@c:~/bin/FreeCAD/FreeCAD_Elmer_howil/20200521_FC_Elmer_howil/freecad-source$ git push origin femelmeresforce2
Username for 'https://github.com': HoWilgh
Password for 'https://HoWilgh@github.com':
To https://github.com/HoWilgh/FreeCAD.git
 ! [rejected]            femelmeresforce2 -> femelmeresforce2 (non-fast-forward)
error: failed to push some refs to 'https://github.com/HoWilgh/FreeCAD.git'
hint: Updates were rejected because the tip of your current branch is behind
hint: its remote counterpart. Integrate the remote changes (e.g.
hint: 'git pull ...') before pushing again.
hint: See the 'Note about fast-forwards' in 'git push --help' for details.
I tried to "pull --rebase" and "push origin master" but everything seams to be okay :?:
w@c:~/bin/FreeCAD/FreeCAD_Elmer_howil/20200521_FC_Elmer_howil/freecad-source$ git pull --rebase origin master
From https://github.com/HoWilgh/FreeCAD
 * branch                master     -> FETCH_HEAD
Current branch femelmeresforce2 is up to date.
w@c:~/bin/FreeCAD/FreeCAD_Elmer_howil/20200521_FC_Elmer_howil/freecad-source$ git push origin master
Everything up-to-date
Some other infos:
w@c:~/bin/FreeCAD/FreeCAD_Elmer_howil/20200521_FC_Elmer_howil/freecad-source$ git branch
  femelmeresforce
* femelmeresforce2
  master
"git show" gives me the commit I can not push:
commit 7368680eb805229a7990208412fe93c97616dd8e (HEAD -> femelmeresforce2)
Author: HoWil <HoWilgh@users.noreply.github.com>
Date:   Sat May 23 09:26:38 2020 +0200
    Change 'FEM::EquationElmerElectricforce' to 'Fem::EquationElectricforce'
diff --git a/src/Mod/Fem/femsolver/elmer/equations/electricforce.py b/src/Mod/Fem/femsolver/elmer/equations/electricforce.py
index 79eb2c065..9d2eb6a76 100644
--- a/src/Mod/Fem/femsolver/elmer/equations/electricforce.py
+++ b/src/Mod/Fem/femsolver/elmer/equations/electricforce.py
@@ -40,7 +40,7 @@ def create(doc, name="Electricforce"):
 class Proxy(linear.Proxy, equationbase.ElectricforceProxy):
-    Type = "Fem::EquationElmerElectricforce"
+    Type = "Fem::EquationElectricforce"
     def __init__(self, obj):
         super(Proxy, self).__init__(obj)
Thanks in advance,
HoWil
openBrain
Re: git problem on push
Postby openBrain » Sat May 23, 2020 6:05 pm
The important information is that your commit isn't fast-forward.
It is generally enough to 'push --force-with-lease'.
If not, 'push --force' will push.
But it would be interesting to know why your commit isn't fast-forward (based on former index HEAD, commit message rewrite,...).
vocx
Postby vocx » Sat May 23, 2020 6:41 pm
This error about "fast-forward" is a bit cryptic but it basically means your commit was modified (rebased, squashed, edited, etc.), and it's not the original one.
You can solve the problem in most cases by "forcing" the push.
git push -f origin femelmeresforce2
What this means is that your commit no longer follows "directly" from the previous commit.
a -> b -> base_branch -> c -> d  # new branch
a -> b -> base_branch -> e  # new branch, squash the two commits into one
You can push directly the c and d commits in the branch because they follow directly from the base_branch. But if you squash the commits, you need to force push the branch because the commit e is no longer the original commit.
HoWil
Postby HoWil » Sat May 23, 2020 6:43 pm
Thanks, it did the trick.
I dont know :? Still on beginner-level... using git only from time to time and always see only errors :D
HoWil
Postby HoWil » Sat May 23, 2020 6:46 pm
Dear vocx, Thanks for the detailed explanation. BR, HoWil
vocx
Postby vocx » Sat May 23, 2020 6:55 pm
In Git everything that you do creates a new commit, so often force pushing is the normal thing to do when you want to update your online branches.
a -> b -> base -> c -> d  # original branch
a -> b -> base -> c -> e  # amended message of old commit d, but contents stay the same
a -> b -> base -> f -> g  # interactive rebase, changed contents of old commit c; e stays the same but now it's called g
a -> b -> base -> h  # squashed both commits
a -> b -> base -> j  # amended commit message, but contents stay the same
The original branch is the only one you can push normally, all the other cases you need to force push.
