[Mostly Solved] Debug with MacOS VScode
edwilliams16
Post by edwilliams16 »
13:00:25  Could not connect to 127.0.0.1: 51390
13:00:25  Traceback (most recent call last):
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/_vendored/pydevd/_pydevd_bundle/pydevd_comm.py", line 464, in start_client
    s.connect((host, port))
13:00:25  ConnectionRefusedError: [Errno 61] Connection refused
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/../debugpy/server/attach_pid_injected.py", line 79, in attach
    debugpy.connect(
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/common/compat.py", line 210, in kwonly_f
    return f(*args, **kwargs)
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/__init__.py", line 135, in connect
    return api.connect(address, access_token=access_token)
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/server/api.py", line 143, in debug
    log.reraise_exception("{0}() failed:", func.__name__, level="info")
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/server/api.py", line 141, in debug
    return func(address, settrace_kwargs, **kwargs)
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/server/api.py", line 276, in connect
    _settrace(host=host, port=port, client_access_token=access_token, **settrace_kwargs)
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/server/api.py", line 47, in _settrace
    return pydevd.settrace(*args, **kwargs)
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/_vendored/pydevd/pydevd.py", line 2607, in settrace
    _locked_settrace(
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/_vendored/pydevd/pydevd.py", line 2688, in _locked_settrace
    py_db.connect(host, port)  # Note: connect can raise error.
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/_vendored/pydevd/pydevd.py", line 1262, in connect
    s = start_client(host, port)
13:00:25  E+03560.975: Traceback (most recent call last):
                 debugpy.connect(
                 _locked_settrace(
             Stack where logged:
               File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/../debugpy/server/attach_pid_injected.py", line 92, in attach
                 log.reraise_exception()
               File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/common/log.py", line 226, in reraise_exception
                 _exception(format_string, *args, **kwargs)
13:00:25    File "<string>", line 1, in <module>
13:00:25    File "/Users/ed/.vscode/extensions/ms-python.python-2021.3.680753044/pythonFiles/lib/python/debugpy/../debugpy/server/attach_pid_injected.py", line 92, in attach
13:00:25      log.reraise_exception()
13:00:25      debugpy.connect(
13:00:25      return f(*args, **kwargs)
13:00:25      return api.connect(address, access_token=access_token)
13:00:25      log.reraise_exception("{0}() failed:", func.__name__, level="info")
13:00:25      return func(address, settrace_kwargs, **kwargs)
13:00:25      _settrace(host=host, port=port, client_access_token=access_token, **settrace_kwargs)
13:00:25      return pydevd.settrace(*args, **kwargs)
13:00:25      _locked_settrace(
13:00:25      py_db.connect(host, port)  # Note: connect can raise error.
13:00:25      s = start_client(host, port)
13:00:25      s.connect((host, port))
OS: macOS High Sierra (10.13)
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
Locale: C/Default (C)
VSCode
Version: 1.55.1 (Universal)
Commit: 08a217c4d27a02a5bcde898fd7981bda5b49391b
Date: 2021-04-07T18:22:52.186Z
Electron: 11.3.0
Chrome: 87.0.4280.141
Node.js: 12.18.3
V8: 8.7.220.31-electron.0
OS: Darwin x64 17.7.0
I'm following https://forum.freecadweb.org/viewtopic.php?f=22&t=28901 and optimistically hoping that by 2021 I can debug Macros on a Mac with Visual Studio.
When I try to attach the debugger to the FreeCAD process, I get the above errors in the report console, which appear to say that the connection was refused. Is there a way around this? Give permissions, somewhere?
I think I got the right Python executable in VSCODE: /Applications/FreeCAD.app/Contents/Resources/bin/python
It has a path
>>> sys.path
['', '/Applications/FreeCAD.app/Contents/Resources/lib/python38.zip', '/Applications/FreeCAD.app/Contents/Resources/lib/python3.8', '/Applications/FreeCAD.app/Contents/Resources/lib/python3.8/lib-dynload', '/Applications/FreeCAD.app/Contents/Resources/lib/python3.8/site-packages']
which has package stuff I assume, but maybe I have to add Macro folders at some point which are under ~/Library/Preferences/FreeCAD/ or does FreeCAD set its own python path somewhere?
I'm lost here...
edwilliams16
Re: Debug with MacOS VScode
The wiki has some instructions using the now-deprecated ptvsd https://wiki.freecadweb.org/Debugging
With some minor modifications, I got it working. First problem was even using FreeCAD"s own packaged python pip install ptvsd installed off FreeCAD's python path. I fixed this by appending to the path at the beginning of the macro. Output to the debug console gave deprecation warnings, which I got rid of by moving the instruction to the launch.json file.
So here's a working configuration:
Test macro file with necessary preamble
from sys import path
sys.path.append('/Users/ed/opt/anaconda3/lib/python3.7/site-packages')
import ptvsd
print("Waiting for debugger attach")
ptvsd.enable_attach(address=('localhost', 5678))
ptvsd.wait_for_attach()
#end preamble
import FreeCAD
import Part
x,y,z = 3,5,7
print('x=' + str(x)) # to debug console
box = Part.makeBox(x,y,z)
Part.show(box)
And a launch.json (Couldn't find an Add Configuration, so changed an existing one. Changing the "name" attribute seems to work to make a new configuration, not clobbering the old one.)
    // Use IntelliSense to learn about possible attributes.
    // Hover to view descriptions of existing attributes.
    // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
    "version": "0.2.0",
    "configurations": [
            "name": "Python: FreeCAD Attacher",
            "type": "python",
            "request": "attach",
            "port": 5678,
            "host": "localhost",
            "redirectOutput": true,
            "pathMappings": [
                    "localRoot": "${workspaceFolder}",
                    "remoteRoot": "."
The re-direction only seems to work the first time you run the macro - haven't figured that out. It would also seem desirable to switch to ptvsd's successor debugpy https://pypi.org/project/debugpy/ - but that's for another day.
Finding where your system python installed ptvsd:
>>> import ptvsd
>>> print(ptvsd.__file__)
/Users/ed/opt/anaconda3/lib/python3.7/site-packages/ptvsd/__init__.py
So it lives in /Users/ed/opt/anaconda3/lib/python3.7/site-packages/
edwilliams16
Re: [Mostly Solved] Debug with MacOS VScode
I found a way to use Macro|Attach to Remote Debugger without having to modify the Macro you are debugging or typing into FreeCAD's python console . This gets around the bug that FreeCAD can't find ptvsd the debugger module.
Load the Macro to be debugged into VSCode's editor.
Edit a launch.json to read
    "version": "0.2.0",
    "configurations": [
            "type": "python",
            "port": 5678,
            "pathMappings": [
                    "remoteRoot": "."
pip install ptvsd
If you are lucky, typing
import ptvsd
into FreeCAD's python console meets with success. If so skip the next step.
Create a new Macro import_ptvsd.FCMacro
path.append('/path/to/where/ptvsd/was installed')
import ptvsd
then run the Macro.
  • Go to Macro|Attach to Remote Debugger choose VSCode and the default arguments. Clicking OK will freeze FreeCAD.
  • Go to VSCode and press F5 (Run). FreeCAD will unfreeze.
  • Set breakpoints, whatever in your Macro in VSCode.
  • Run the Macro in FreeCAD.
You can now step through, watch your variables etc.
The output is NOT as yet redirected from the Report View to the debug console.
