hui today i got the same / very similar problem with the freecad-daily build..
system information:
Operating System: Kubuntu 20.04
KDE Plasma Version: 5.18.5
KDE Frameworks Version: 5.68.0
Qt Version: 5.12.8
Kernel Version: 5.4.0-72-generic
OS Type: 64-bit
Processors: 16 × Intel® Core™ i9-9980HK CPU @ 2.40GHz
Memory: 31,2 GiB of RAM
i worked on a freecad / blender script -
and got some 'PySide' not found messages -
so just thought ok - just install PySide2 with pip and iam fine..:
only after this i found the
FreeCAD PySide wiki page.
so i added this path to my import handling and it worked for my script.
then i wanted to change something in my FreeCAD model and tried to start FreeCAD-Daily:
stefan@stefan-Zen:~$ freecad-daily
FreeCAD 0.19, Libs: 0.19R
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Sheet Metal workbench loaded
Loading Assembly4 WorkBench
Interlocking laser cut workbench loaded
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /usr/share/freecad-daily/Mod/AddonManager/InitGui.py
Please look into the log file for further information
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /usr/share/freecad-daily/Mod/Arch/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /usr/share/freecad-daily/Mod/OpenSCAD/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /usr/share/freecad-daily/Mod/Draft/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /usr/share/freecad-daily/Mod/Tux/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /home/stefan/mydata/freecad/.FreeCAD/Mod/lattice2/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /home/stefan/mydata/freecad/.FreeCAD/Mod/A2plus/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /home/stefan/mydata/freecad/.FreeCAD/Mod/sheetmetal/InitGui.py
File "signature_bootstrap.py", line 106, in bootstrap
File "/home/stefan/.local/lib/python3.8/site-packages/shiboken2/__init__.py", line 30, in <module>
_init_pyside_extension()
NameError: name '_init_pyside_extension' is not defined
Error in sys.excepthook:
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 72, in apport_excepthook
from apport.fileutils import likely_packaged, get_recent_crashes
File "/usr/lib/python3/dist-packages/apport/__init__.py", line 5, in <module>
from apport.report import Report
File "/usr/lib/python3/dist-packages/apport/report.py", line 21, in <module>
from urllib.request import urlopen
ImportError: cannot import name 'urlopen' from partially initialized module 'urllib.request' (most likely due to a circular import) (/usr/lib/python3.8/urllib/request.py)
Original exception was:
Fatal Python error: could not initialize part 2
Python runtime state: initialized
Current thread 0x00007fdccf8fd100 (most recent call first):
File "/usr/lib/python3.8/functools.py", line 51 in update_wrapper
File "/usr/lib/python3.8/locale.py", line 109 in <module>
File "<frozen importlib._bootstrap>", line 219 in _call_with_frames_removed
File "<frozen importlib._bootstrap_external>", line 783 in exec_module
File "<frozen importlib._bootstrap>", line 671 in _load_unlocked
File "<frozen importlib._bootstrap>", line 975 in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 991 in _find_and_load
File "/usr/lib/python3.8/calendar.py", line 10 in <module>
File "/usr/lib/python3.8/email/_parseaddr.py", line 16 in <module>
File "/usr/lib/python3.8/email/utils.py", line 33 in <module>
File "/usr/lib/python3.8/email/_policybase.py", line 9 in <module>
File "/usr/lib/python3.8/email/feedparser.py", line 27 in <module>
File "/usr/lib/python3.8/email/parser.py", line 12 in <module>
File "/usr/lib/python3.8/http/client.py", line 71 in <module>
File "/usr/lib/python3.8/urllib/request.py", line 88 in <module>
File "<frozen importlib._bootstrap>", line 1042 in _handle_fromlist
File "<string>", line 26 in <module>
File "<string>", line 131 in InitApplications
File "<string>", line 201 in <module>
Aborted (core dumped)
so i thought ok - seems there is something getting in chaos with pyside..
lets uninstalled it:
and just to be sure restarted my system.
but the same error comes up.
i also installed the stable version:
stefan@stefan-Zen:~$ sudo apt install freecad
[sudo] password for stefan:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
freecad-common freecad-python3 libfreecad-python3-0.19
Suggested packages:
povray
The following NEW packages will be installed
freecad freecad-common freecad-python3 libfreecad-python3-0.19
0 to upgrade, 4 to newly install, 0 to remove and 0 not to upgrade.
Need to get 49,4 MB of archives.
After this operation, 190 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://ppa.launchpad.net/freecad-maintainers/freecad-stable/ubuntu focal/main amd64 freecad-common all 2:0.19+dfsg1~202103010028~ubuntu20.04.1 [19,1 MB]
Get:2 http://ppa.launchpad.net/freecad-maintainers/freecad-stable/ubuntu focal/main amd64 libfreecad-python3-0.19 amd64 2:0.19+dfsg1~202103010028~ubuntu20.04.1 [30,2 MB]
Get:3 http://ppa.launchpad.net/freecad-maintainers/freecad-stable/ubuntu focal/main amd64 freecad-python3 amd64 2:0.19+dfsg1~202103010028~ubuntu20.04.1 [48,5 kB]
Get:4 http://ppa.launchpad.net/freecad-maintainers/freecad-stable/ubuntu focal/main amd64 freecad all 2:0.19+dfsg1~202103010028~ubuntu20.04.1 [35,0 kB]
Fetched 49,4 MB in 1min 8s (727 kB/s)
Selecting previously unselected package freecad-common.
(Reading database ... 375382 files and directories currently installed.)
Preparing to unpack .../freecad-common_2%3a0.19+dfsg1~202103010028~ubuntu20.04.1_all.deb ...
Unpacking freecad-common (2:0.19+dfsg1~202103010028~ubuntu20.04.1) ...
Selecting previously unselected package libfreecad-python3-0.19.
Preparing to unpack .../libfreecad-python3-0.19_2%3a0.19+dfsg1~202103010028~ubuntu20.04.1_amd64.deb ...
Unpacking libfreecad-python3-0.19 (2:0.19+dfsg1~202103010028~ubuntu20.04.1) ...
Selecting previously unselected package freecad-python3.
Preparing to unpack .../freecad-python3_2%3a0.19+dfsg1~202103010028~ubuntu20.04.1_amd64.deb ...
Unpacking freecad-python3 (2:0.19+dfsg1~202103010028~ubuntu20.04.1) ...
Selecting previously unselected package freecad.
Preparing to unpack .../freecad_2%3a0.19+dfsg1~202103010028~ubuntu20.04.1_all.deb ...
Unpacking freecad (2:0.19+dfsg1~202103010028~ubuntu20.04.1) ...
Setting up libfreecad-python3-0.19 (2:0.19+dfsg1~202103010028~ubuntu20.04.1) ...
Setting up freecad-common (2:0.19+dfsg1~202103010028~ubuntu20.04.1) ...
Setting up freecad-python3 (2:0.19+dfsg1~202103010028~ubuntu20.04.1) ...
update-alternatives: using /usr/lib/freecad/bin/freecad-python3 to provide /usr/bin/freecad (freecad) in auto mode
Setting up freecad (2:0.19+dfsg1~202103010028~ubuntu20.04.1) ...
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for shared-mime-info (1.15-1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
and the same error happens:
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /usr/share/freecad/Mod/AddonManager/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /usr/share/freecad/Mod/Arch/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /usr/share/freecad/Mod/Draft/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /usr/share/freecad/Mod/Tux/InitGui.py
Current thread 0x00007f4df8b23100 (most recent call first):
then i tried with the current
appimage FreeCAD_0.19-24276-Linux-Conda_glibc2.12-x86_64.AppImage
it starts up but shows the following errors -
and the gui seems very brocken....
stefan@stefan-Zen:~/mydata/tools/FreeCAD$ ./FreeCAD_0.19-24276-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD 0.19, Libs: 0.19R24276 (Git)
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /tmp/.mount_FreeCAoenS7D/usr/Mod/AddonManager/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /tmp/.mount_FreeCAoenS7D/usr/Mod/Arch/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /tmp/.mount_FreeCAoenS7D/usr/Mod/Draft/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /tmp/.mount_FreeCAoenS7D/usr/Mod/Tux/InitGui.py
During initialization the error "<method-wrapper '__get__' of getset_descriptor object at 0x7fbbf2ed2200> returned a result with an error set" occurred in /home/stefan/mydata/freecad/.FreeCAD/Mod/kicadStepUpMod/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in freecad.appimage
File "<string>", line 156, in InitApplications
File "/tmp/.mount_FreeCAoenS7D/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/tmp/.mount_FreeCAoenS7D/usr/lib/python3.8/site-packages/freecad/appimage/init_gui.py", line 4, in <module>
from PySide2 import QtWidgets, QtGui, QtCore
File "/tmp/.mount_FreeCAoenS7D/usr/lib/python3.8/site-packages/PySide2/__init__.py", line 51, in <module>
_setupQtDirectories()
File "/tmp/.mount_FreeCAoenS7D/usr/lib/python3.8/site-packages/PySide2/__init__.py", line 21, in _setupQtDirectories
import shiboken2
- FreeCAD_AppImage_Crash__Screenshot_20210419_155442.png (147.82 KiB) Viewed 1443 times
then i tried with renaming my user-config folder and starting the appimage again -
this lead to a starting freecad - juche -
the logs still very error heavy:
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /tmp/.mount_FreeCAqWZ6G4/usr/Mod/AddonManager/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /tmp/.mount_FreeCAqWZ6G4/usr/Mod/Arch/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /tmp/.mount_FreeCAqWZ6G4/usr/Mod/Draft/InitGui.py
During initialization the error "name '_init_pyside_extension' is not defined" occurred in /tmp/.mount_FreeCAqWZ6G4/usr/Mod/Tux/InitGui.py
File "/tmp/.mount_FreeCAqWZ6G4/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
File "/tmp/.mount_FreeCAqWZ6G4/usr/lib/python3.8/site-packages/freecad/appimage/init_gui.py", line 4, in <module>
File "/tmp/.mount_FreeCAqWZ6G4/usr/lib/python3.8/site-packages/PySide2/__init__.py", line 51, in <module>
File "/tmp/.mount_FreeCAqWZ6G4/usr/lib/python3.8/site-packages/PySide2/__init__.py", line 21, in _setupQtDirectories
import shiboken2
Unknown command 'Std_AddonMgr'
File "<string>", line 2, in <module>
File "/tmp/.mount_FreeCAqWZ6G4/usr/Mod/Start/StartPage/StartPage.py", line 27, in <module>
import six
File "/home/stefan/.local/lib/python3.8/site-packages/six.py", line 320, in <module>
moves = _MovedItems(__name__ + ".moves")
File "/home/stefan/.local/lib/python3.8/site-packages/six.py", line 128, in __init__
self.__doc__ = self.__class__.__doc__
<class 'SystemError'>: <method-wrapper '__get__' of getset_descriptor object at 0x7fcc9ec29dc0> returned a result with an error set
File "<string>", line 43, in Initialize
File "/tmp/.mount_FreeCAqWZ6G4/usr/Mod/PartDesign/WizardShaft/WizardShaft.py", line 26, in <module>
from PySide import QtCore, QtGui
File "/tmp/.mount_FreeCAqWZ6G4/usr/Ext/PySide/__init__.py", line 2, in <module>
from PySide2 import __version__
import shiboken2
and if i try to switch to the Part Design Workbench i get
hm so not usable anyway..
does anybody have any idea how to get this back to working?
i thought that the app-image version is fully isolated....
seems that is not really the case.
sunny greetings
stefan
