Uninstalling FreeCAD Ubuntu 20.04
anvoice
Post by anvoice »
Hello, I am trying to uninstall FreeCAD .18.4 from my Ubuntu 20.04 machine in order to upgrade to .19. I found no way to upgrade directly, and so would like to resort to the uninstall. I originally installed FreeCAD using
sudo apt install freecad
which loaded the older version. However, after running
sudo apt remove freecad
FreeCAD persists, and opens as normal with version 0.18.4. Subsequent calls to
say it's not installed and thus do nothing. Could anyone help me with the uninstall, or point me to a wiki that addresses this? Thanks in advance.
PrzemoF
Re: Uninstalling FreeCAD Ubuntu 20.04
Post by PrzemoF »
Welcome to the forum!
It's rather a linux question, but I'm happy to help. After removing FreeCAD check what "which freecad" produces. To be sure also check "which FreeCAD" - some systems use different file name (e.g. my fedora)
[1] https://linux.die.net/man/1/which
anvoice
Post by anvoice »
Hi, thanks for the welcome and for your response! Didn't realize it's off-topic here, so really appreciate the help. "which freecad" produces "usr/bin/freecad" after the uninstall. Not sure how to proceed from here.
openBrain
Post by openBrain »
Could you give output of
dpkg -l | grep freecad
PrzemoF
Post by PrzemoF »
No, it's not off-topic - we're easy going :D But for me it was more linux administration question.
I don't know how ubuntu packaged FreeCAD, but from a quick test you also need to remove freecad-common
anvoice
Post by anvoice »
The output of the dpkg command:
ii  freecad-common                             0.18.4+dfsg2-1ubuntu4                 all          Extensible Open Source CAx program - common files
ii  freecad-python3                            0.18.4+dfsg2-1ubuntu4                 amd64        Extensible Open Source CAx program - Python 3 binaries
ii  freecad-runtime                            0.18.4+dfsg2-1ubuntu4                 all          Extensible Open Source CAx program - runtime files
ii  libfreecad-python3-0.18                    0.18.4+dfsg2-1ubuntu4                 amd64        Extensible Open Source CAx program - Python 3 library files
So I should remove freecad-common using "sudo apt remove freecad-common"? What about "freecad-python3" and the rest?
openBrain
Post by openBrain »
sudo apt-get purge freecad*
sudo apt-get autoremove
heda
Post by heda »
should something like this be on the wiki?
openBrain
Post by openBrain »
heda wrote: Fri Jul 23, 2021 3:53 pm should something like this be on the wiki?
IMO nope. This is just how Debian and derivatives manage the packages. :)
anvoice
Post by anvoice »
Many thanks! The purge command worked, and after adding the appropriate ppa I successfully installed 0.19.
