If I save an empty document, all is fine. If I add e.g. cube to the document and save, then FreeCAD crashed. I do not know if it is a bug (e.g. serialization) or is it trouble with some library. Thank you for your help and support.
Process: FreeCAD [33895]
Path: /opt/homebrew/*/FreeCAD.app/Contents/MacOS/FreeCAD
Identifier: ???
Version: 0.20.0 (0.20.0)
Code Type: ARM-64 (Native)
Parent Process: ??? [1]
Responsible: FreeCAD [33895]
User ID: 502
Date/Time: 2021-07-31 15:54:38.132 +0200
OS Version: macOS 11.5.1 (20G80)
Report Version: 12
Anonymous UUID: 1955793E-D58F-E2B2-2D26-67FE6BF99EAA
Sleep/Wake UUID: DB3F1465-166E-44B1-82D6-842D0D07ADCE
Time Awake Since Boot: 26000 seconds
Time Since Wake: 4900 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000028
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [33895]
VM Regions Near 0x28:
__TEXT 1008dc000-1008ec000 [ 64K] r-x/r-x SM=COW /opt/homebrew/*/FreeCAD.app/Contents/MacOS/FreeCAD
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libc++.1.dylib 0x000000010629a048 std::__1::istreambuf_iterator<char, std::__1::char_traits<char> > std::__1::num_get<char, std::__1::istreambuf_iterator<char, std::__1::char_traits<char> > >::__do_get_signed<long>(std::__1::istreambuf_iterator<char, std::__1::char_traits<char> >, std::__1::istreambuf_iterator<char, std::__1::char_traits<char> >, std::__1::ios_base&, unsigned int&, long&) const + 68
1 libc++.1.dylib 0x0000000199bd7c3c std::__1::basic_ostream<char, std::__1::char_traits<char> >::operator<<(int) + 348
2 libc++.1.dylib 0x0000000199bd7c3c std::__1::basic_ostream<char, std::__1::char_traits<char> >::operator<<(int) + 348
3 libTKBRep.7.dylib 0x000000014f3e2040 TopTools_ShapeSet::Write(TopoDS_Shape const&, std::__1::basic_ostream<char, std::__1::char_traits<char> >&) const + 120
4 Part.so 0x0000000148eec75c Part::PropertyPartShape::SaveDocFile(Base::Writer&) const + 404
5 libFreeCADBase.dylib 0x0000000100acc838 Base::ZipWriter::writeFiles() + 108
6 libFreeCADApp.dylib 0x0000000101d1bbb4 App::Document::saveToFile(char const*) const + 912
7 libFreeCADApp.dylib 0x0000000101d1b3a0 App::Document::save() + 328
8 libFreeCADApp.dylib 0x0000000101d1b00c App::Document::saveAs(char const*) + 284
9 libFreeCADApp.dylib 0x0000000101daf4a0 App::DocumentPy::saveAs(_object*) + 112
10 libFreeCADApp.dylib 0x0000000101daa3f4 App::DocumentPy::staticCallback_saveAs(_object*, _object*) + 92
11 Python 0x00000001024bbdd4 cfunction_call + 168
12 Python 0x0000000102487388 _PyObject_MakeTpCall + 308
13 Python 0x00000001025343d0 call_function + 512
14 Python 0x0000000102531b80 _PyEval_EvalFrameDefault + 23920
15 Python 0x0000000102534e74 _PyEval_EvalCode + 1944
16 Python 0x000000010252bd48 PyEval_EvalCode + 80
17 Python 0x0000000102564e60 run_eval_code_obj + 116
18 Python 0x00000001025640ec run_mod + 116
19 Python 0x0000000102563028 PyRun_StringFlags + 152
20 libFreeCADBase.dylib 0x0000000100a76fb0 Base::InterpreterSingleton::runString(char const*) + 80
21 libFreeCADGui.dylib 0x0000000100e76450 Gui::Command::_runCommand(char const*, int, Gui::Command::DoCmd_Type, char const*) + 168
22 libFreeCADGui.dylib 0x0000000100e7622c Gui::Command::_doCommand(char const*, int, Gui::Command::DoCmd_Type, char const*, ...) + 96
23 libFreeCADGui.dylib 0x0000000100e21a90 Gui::Document::saveAs() + 1000
24 libFreeCADGui.dylib 0x00000001010d1a30 Gui::View3DInventor::onMsg(char const*, char const**) + 1192
25 libFreeCADGui.dylib 0x0000000100dd4620 Gui::Application::sendMsgToActiveView(char const*, char const**) + 52
26 libFreeCADGui.dylib 0x0000000100df392c Gui::Application::sSendActiveView(_object*, _object*) + 96
27 Python 0x00000001024bbdd4 cfunction_call + 168
28 Python 0x0000000102487388 _PyObject_MakeTpCall + 308
29 Python 0x00000001025343d0 call_function + 512
30 Python 0x0000000102531b80 _PyEval_EvalFrameDefault + 23920
31 Python 0x0000000102534e74 _PyEval_EvalCode + 1944
32 Python 0x000000010252bd48 PyEval_EvalCode + 80
33 Python 0x0000000102564e60 run_eval_code_obj + 116
34 Python 0x00000001025640ec run_mod + 116
35 Python 0x0000000102563028 PyRun_StringFlags + 152
36 libFreeCADBase.dylib 0x0000000100a76fb0 Base::InterpreterSingleton::runString(char const*) + 80
37 libFreeCADGui.dylib 0x0000000100e76450 Gui::Command::_runCommand(char const*, int, Gui::Command::DoCmd_Type, char const*) + 168
38 libFreeCADGui.dylib 0x0000000100e7622c Gui::Command::_doCommand(char const*, int, Gui::Command::DoCmd_Type, char const*, ...) + 96
39 libFreeCADGui.dylib 0x0000000100e754e8 Gui::Command::_invoke(int, bool) + 504
40 libFreeCADGui.dylib 0x0000000100e752b0 Gui::Command::invoke(int, Gui::Command::TriggerSource) + 328
41 QtCore 0x0000000105e586d8 0x105c54000 + 2115288
42 QtWidgets 0x000000010514ac6c QAction::activate(QAction::ActionEvent) + 308
43 QtCore 0x0000000105e509e0 QObject::event(QEvent*) + 620
44 QtWidgets 0x0000000105153e24 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 292
45 QtWidgets 0x00000001051551ac QApplication::notify(QObject*, QEvent*) + 548
46 libFreeCADGui.dylib 0x0000000100e5445c Gui::GUIApplication::notify(QObject*, QEvent*) + 164
47 QtCore 0x0000000105e28454 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 208
48 QtCore 0x0000000105e296d0 QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 764
49 libqcocoa.dylib 0x0000000108ee7f1c 0x108eb0000 + 229148
50 libqcocoa.dylib 0x0000000108ee85ec 0x108eb0000 + 230892
51 com.apple.CoreFoundation 0x0000000199d72a84 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 28
52 com.apple.CoreFoundation 0x0000000199d729d0 __CFRunLoopDoSource0 + 208
53 com.apple.CoreFoundation 0x0000000199d72728 __CFRunLoopDoSources0 + 376
54 com.apple.CoreFoundation 0x0000000199d71044 __CFRunLoopRun + 820
55 com.apple.CoreFoundation 0x0000000199d70598 CFRunLoopRunSpecific + 600
56 com.apple.HIToolbox 0x00000001a1c93280 RunCurrentEventLoopInMode + 292
57 com.apple.HIToolbox 0x00000001a1c92f0c ReceiveNextEventCommon + 320
58 com.apple.HIToolbox 0x00000001a1c92db4 _BlockUntilNextEventMatchingListInModeWithFilter + 72
59 com.apple.AppKit 0x000000019c561a64 _DPSNextEvent + 836
60 com.apple.AppKit 0x000000019c560404 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1292
61 com.apple.AppKit 0x000000019c552290 -[NSApplication run] + 596
62 libqcocoa.dylib 0x0000000108ee7374 0x108eb0000 + 226164
63 QtCore 0x0000000105e245b8 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 524
64 QtCore 0x0000000105e28a84 QCoreApplication::exec() + 132
65 libFreeCADGui.dylib 0x0000000100dd9fc8 Gui::Application::runApplication() + 7256
66 0x00000001008e92f8 main + 2416
67 libdyld.dylib 0x0000000199c91430 start + 4
Thread 1:
0 libsystem_pthread.dylib 0x0000000199c6e5cc start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x0000000199c431ec __select + 8
1 com.apple.CoreFoundation 0x0000000199d9c280 __CFSocketManager + 624
2 libsystem_pthread.dylib 0x0000000199c73878 _pthread_start + 320
3 libsystem_pthread.dylib 0x0000000199c6e5e0 thread_start + 8
Thread 5:
0 libsystem_kernel.dylib 0x0000000199c3c548 __psynch_cvwait + 8
1 libsystem_pthread.dylib 0x0000000199c73dac _pthread_cond_wait + 1248
2 libgomp.1.dylib 0x00000001233ae754 gomp_sem_wait + 52
3 libgomp.1.dylib 0x00000001233ae988 gomp_barrier_wait_end + 104
4 libgomp.1.dylib 0x00000001233ac950 gomp_thread_start + 272
5 libsystem_pthread.dylib 0x0000000199c73878 _pthread_start + 320
6 libsystem_pthread.dylib 0x0000000199c6e5e0 thread_start + 8
Thread 6:
Thread 7:
Thread 8:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x0000000199c38dd4 mach_msg_trap + 8
1 libsystem_kernel.dylib 0x0000000199c39184 mach_msg + 76
2 com.apple.CoreFoundation 0x0000000199d72d00 __CFRunLoopServiceMachPort + 372
3 com.apple.CoreFoundation 0x0000000199d711cc __CFRunLoopRun + 1212
4 com.apple.CoreFoundation 0x0000000199d70598 CFRunLoopRunSpecific + 600
5 com.apple.AppKit 0x000000019c6e0738 _NSEventThread + 196
6 libsystem_pthread.dylib 0x0000000199c73878 _pthread_start + 320
7 libsystem_pthread.dylib 0x0000000199c6e5e0 thread_start + 8
Thread 9:
Thread 10:
Thread 11:
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000020 x1: 0x000000014ffe1410 x2: 0x000000016f51fe38 x3: 0x0000000000000020
x4: 0x0000000000000001 x5: 0x0000000000000020 x6: 0x000000000000002b x7: 0x0000000199c336b0
x8: 0x1f1fee1f2d3b009c x9: 0x000000010629a000 x10: 0x000000014f3e12fc x11: 0x0000000000000000
x12: 0x0000000000000010 x13: 0x0000000000000000 x14: 0x0000000000000010 x15: 0x000000000000001e
x16: 0x0000000199bf31a4 x17: 0x000000000000d3ed x18: 0x0000000150d8b940 x19: 0x000000014ffe1410
x20: 0x0000000000000001 x21: 0x000000016f51fe38 x22: 0x000000016f51fe38 x23: 0x000000014ffe1410
x24: 0x0000000000000020 x25: 0x0000000000001006 x26: 0x000000014fec2690 x27: 0x000000014fec4610
x28: 0x0000000000000001 fp: 0x000000016f51f320 lr: 0x0000000199bd7c3c
sp: 0x000000016f51f190 pc: 0x000000010629a048 cpsr: 0x80000000
far: 0x0000000000000028 esr: 0x92000006
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=919.5M resident=0K(0%) swapped_out_or_unallocated=919.5M(100%)
Writable regions: Total=2.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.0G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 768K 6
Activity Tracing 256K 1
CG backing stores 3264K 6
CG image 1904K 13
CG raster data 1648K 1
CoreAnimation 10.0M 28
CoreGraphics 32K 2
CoreUI image data 2816K 21
Foundation 16K 1
Kernel Alloc Once 32K 1
MALLOC 344.4M 64
MALLOC guard page 192K 10
MALLOC_MEDIUM (reserved) 936.0M 8 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
OpenGL GLSL 256K 3
STACK GUARD 56.2M 12
Stack 16.8M 12
VM_ALLOCATE 133.5M 164
VM_ALLOCATE (reserved) 192.0M 3 reserved VM address space (unallocated)
__AUTH 695K 168
__AUTH_CONST 10.5M 328
__DATA 12.0M 476
__DATA_CONST 14.8M 459
__DATA_DIRTY 896K 119
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 538.2M 146
__OBJC_CONST 1656K 142
__OBJC_RO 75.1M 1
__OBJC_RW 2576K 1
__TEXT 381.3M 482
__UNICODE 588K 1
mapped file 553.0M 39
shared memory 848K 12
TOTAL 3.6G 2733
TOTAL, minus reserved VM space 2.1G 2733
Model: MacBookPro17,1, BootROM 6723.140.2, proc 8:4:4 processors, 16 GB, SMC
Graphics: kHW_AppleM1Item, Apple M1, spdisplays_builtin
Memory Module: LPDDR4
AirPort: spairport_wireless_card_type_airport_extreme, wl0: Jul 7 2021 00:48:27 version 18.50.40.10.7.8.121 FWID 01-f5ad2691
Bluetooth: Version 8.0.5d7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.1 Bus
Thunderbolt Bus: MacBook Pro, Apple Inc.
OS: macOS 11.5
Version: 0.20.25351 (Git)
Hash: a03eb6b9625ba88d41e876699e9352206887d6fb
Python version: 3.9.0
Qt version: 5.15.2
Coin version: 4.0.0
OCC version: 7.5.0
