Compile fails on Manjaro due to undefined reference
denisebryson
Post by denisebryson »
Hello everybody,
unfortunately I can not compile the current FreeCad Master due to the following issue:
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_global_cleanup@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_easy_getinfo@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_cleanup@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_perform@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_global_init@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_easy_init@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_add_handle@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_remove_handle@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_info_read@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_slist_free_all@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_easy_setopt@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_fdset@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_slist_append@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_easy_cleanup@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_init@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_timeout@CURL_OPENSSL_4'
collect2: error: ld returned 1 exit status
make[2]: *** [src/Main/CMakeFiles/FreeCADMainCmd.dir/build.make:126: bin/FreeCADCmd] Error 1
make[1]: *** [CMakeFiles/Makefile2:2476: src/Main/CMakeFiles/FreeCADMainCmd.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 56%] Built target FreeCADGui
make: *** [Makefile:136: all] Error 2
I am not so familiar with compiling and could not find any related topics or issues across the net. Do you have an idea what might be the problem?
My system information is:
Operating System: Manjaro Linux
KDE Plasma Version: 5.23.3
KDE Frameworks Version: 5.88.0
Qt Version: 5.15.2
Kernel Version: 5.10.79-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 4 × Intel® Core™ i5-5300U CPU @ 2.30GHz
Memory: 7,5 GiB of RAM
Graphics Processor: Mesa Intel® HD Graphics 5500
Python 3.7.6
FreeCad
Hash: e4ca3d29719600238171c15959a629813bf5e194
Re: Compile fails on Manjaro due to undefined reference
Post by wmayer »
What's the output of?
ldd /usr/lib/libxerces-c.so
