That's what it looks like. although the package dependency for libshiboke2-dev does list python3-dev with version 3.10.
FYI: Debian Testing build broken (due to debian packaging)
Re: FYI: Debian Testing build broken (due to debian packaging)
I set everything back to default, installed libshiboken2-dev and disable the minor version check in the package's cmake helper script. Starting the UI results in the following error:
I also noticed that there are 2 libraries installed:
however, in the package config it clearly wants python3.9:
FreeCAD 0.20, Libs: 0.20R28873 +14 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2022
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
XXX lineno: 110, opcode: 48
File "signature_bootstrap.py", line 110, in bootstrap
SystemError: unknown opcode
Fatal Python error: init_phase_2: could not initialize part 2
Python runtime state: initialized
Current thread 0x00007f364262da80 (most recent call first):
File "/usr/lib/python3/dist-packages/shiboken2/__init__.py", line 30 in <module>
File "<frozen importlib._bootstrap>", line 241 in _call_with_frames_removed
File "<frozen importlib._bootstrap_external>", line 883 in exec_module
File "<frozen importlib._bootstrap>", line 688 in _load_unlocked
File "<frozen importlib._bootstrap>", line 1006 in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1027 in _find_and_load
File "/usr/lib/python3/dist-packages/PySide2/__init__.py", line 58 in _setupQtDirectories
File "/usr/lib/python3/dist-packages/PySide2/__init__.py", line 107 in <module>
File "/media/sdb/projects/FreeCAD/dev/build/Ext/PySide/__init__.py", line 2 in <module>
File "<frozen importlib._bootstrap>", line 992 in _find_and_load_unlocked
File "/media/sdb/projects/FreeCAD/dev/build/Mod/machinekit/machinekit.py", line 22 in <module>
File "<string>", line 3 in MachinekitWorkbench
File "<string>", line 1 in <module>
File "<string>", line 140 in RunInitGuiPy
File "<string>", line 191 in InitApplications
File "<string>", line 276 in <module>
Extension modules: FreeCAD, FreeCADGui, pivy._coin, google.protobuf.pyext._message, shiboken2.shiboken2 (total: 5)
Aborted
/usr/lib/x86_64-linux-gnu/libshiboken2.cpython-310-x86_64-linux-gnu.so
/usr/lib/x86_64-linux-gnu/libshiboken2.cpython-39-x86_64-linux-gnu.so
markus@yolanda:/usr/lib/x86_64-linux-gnu/pkgconfig$ cat /usr/lib/x86_64-linux-gnu/pkgconfig/shiboken2.pc
prefix=/usr
exec_prefix=/usr
libdir=lib
includedir=/usr/include/shiboken2
generator_location=/usr/bin/shiboken2
python_interpreter=/usr/bin/python3
python_include_dir=/usr/include/python3.9
Description: Support library for Python bindings created with the Shiboken2 generator.
Version: 5.15.2
Libs: -L${libdir} -lshiboken2.cpython-39-x86_64-linux-gnu
Cflags: -I/usr/include/python3.9 -I${includedir}/
If change in Debian:
/usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/Shiboken2Config.cmake
To:
FC will build with Shiboken v3.10
if (NOT PYTHON_CONFIG_SUFFIX)
message(STATUS "Shiboken2Config: Using default python: .cpython-39-x86_64-linux-gnu")
SET(PYTHON_CONFIG_SUFFIX .cpython-39-x86_64-linux-gnu)
endif()
include("${CMAKE_CURRENT_LIST_DIR}/Shiboken2Config${PYTHON_CONFIG_SUFFIX}.cmake")
To:
message(STATUS "Shiboken2Config: Using default python: .cpython-310-x86_64-linux-gnu")
SET(PYTHON_CONFIG_SUFFIX .cpython-310-x86_64-linux-gnu)
endif()
- adrianinsaval
have you reported the packaging error to it's maintainers in debian?
I think it's not Debian error.
Set PYTHON_CONFIG_SUFFIX for cmake also works:
cmake -DPYTHON_CONFIG_SUFFIX=.cpython-310-x86_64-linux-gnu ../FreeCAD
- adrianinsaval
Both versions are provided. v3.9 is default. But user can select v3.10
https://packages.debian.org/testing/amd ... v/filelist
https://packages.debian.org/testing/amd ... 5/filelist
For correct works with Python-3.10, also required Pivy-0.6.7
https://github.com/coin3d/pivy/releases
/usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/Shiboken2Config.cpython-310-x86_64-linux-gnu.cmake
/usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/Shiboken2Config.cpython-39-x86_64-linux-gnu.cmake
/usr/lib/python3/dist-packages/shiboken2/shiboken2.cpython-310-x86_64-linux-gnu.so
/usr/lib/python3/dist-packages/shiboken2/shiboken2.cpython-39-x86_64-linux-gnu.so
/usr/lib/x86_64-linux-gnu/libshiboken2.cpython-310-x86_64-linux-gnu.so.5.15
/usr/lib/x86_64-linux-gnu/libshiboken2.cpython-310-x86_64-linux-gnu.so.5.15.2
/usr/lib/x86_64-linux-gnu/libshiboken2.cpython-39-x86_64-linux-gnu.so.5.15
/usr/lib/x86_64-linux-gnu/libshiboken2.cpython-39-x86_64-linux-gnu.so.5.15.2
Did you try starting the resulting binary? It crashes miserably.
Also note that FC is currently not part of Debian Testing - there is however a version in Unstable, so there's hope.
Yes, it works for me on Debian sid.
I build Pivy-0.6.7 (for Python-3.10 support)
Directory /usr/lib/python3/dist-packages/pivy need to be cleaned before run make install.
OS: Debian GNU/Linux bookworm/sid
Version: 0.20.14555 (Git shallow)
Build type: Unknown
Hash: a865e4f8344eed3562bc33e0973b4616e31a6529 ( 28,923 commits )
Python 3.10.4, Qt 5.15.2, Coin 4.0.0, OCC 7.6.2
Hi I am on Ubuntu 20.04. Would you know how I can get my hands on a libshiboken2-dev package with libshiboken2.cpython-39-x86_64-linux-gnu.so ? So far all the package managers I have tried give me libshiboken2.cpython-38-x86_64-linux-gnu.so.vm4dim wrote: ↑Tue May 24, 2022 5:03 pm Both versions are provided. v3.9 is default. But user can select v3.10
https://packages.debian.org/testing/amd ... v/filelisthttps://packages.debian.org/testing/amd ... 5/filelistCode: Select all
/usr/lib/x86_64-linux-gnu/libshiboken2.cpython-310-x86_64-linux-gnu.so /usr/lib/x86_64-linux-gnu/libshiboken2.cpython-39-x86_64-linux-gnu.so
/usr/lib/python3/dist-packages/shiboken2/shiboken2.cpython-310-x86_64-linux-gnu.so /usr/lib/python3/dist-packages/shiboken2/shiboken2.cpython-39-x86_64-linux-gnu.so /usr/lib/x86_64-linux-gnu/libshiboken2.cpython-310-x86_64-linux-gnu.so.5.15 /usr/lib/x86_64-linux-gnu/libshiboken2.cpython-310-x86_64-linux-gnu.so.5.15.2 /usr/lib/x86_64-linux-gnu/libshiboken2.cpython-39-x86_64-linux-gnu.so.5.15 /usr/lib/x86_64-linux-gnu/libshiboken2.cpython-39-x86_64-linux-gnu.so.5.15.2
I also tried to build from the relevant repo, but this goes way beyond what I am capable of.
Thanks
