Ubuntu PPA Maintenance Coordination
NormandC
Re: Ubuntu PPA Maintenance Coordination
Postby NormandC » Sun May 01, 2016 8:08 pm
Great. When you get the chance, would it be possible for you to post the git commands you use to update the branches. I want to be sure I'm doing it the right way (since I didn't get prompted to git pull when checking out a branch it may not be the case)... Did you create remotes?
One reason for me wanting to link lp:freecad to the freecad-maintainers repos is to reduce the length of the git urls. I'm not sure it's doable though.
Soon we could start thinking about how to write this all down on the wiki. I'm thinking a "FreeCAD packaging portal" that links to subpages for Ubuntu packaging, Windows packaging and OS X packaging...
sgrogan
Postby sgrogan » Sun May 01, 2016 8:18 pm
NormandC wrote:Soon we could start thinking about how to write this all down on the wiki. I'm thinking a "FreeCAD packaging portal" that links to subpages for Ubuntu packaging, Windows packaging and OS X packaging...
I'm still using the long url's but I will work on this soon. I'll try write something up, for this part at least, tomorrow. I want to try a couple of things first that may simplify things. You're right though documenting this is paramount! We may finish just in time for Python3, QT5, OCCT 7, VTK .... :o It's starting to smell like a win Libpack ;)
Again Thanks for all your work on this. It's definitely a great accomplishment.
NormandC
Postby NormandC » Sun May 01, 2016 9:25 pm
No problem, thanks to you too for your dedication.
And with the git repositories the way we've set them up, I think we'll be in better shape for the future, even if upstream freecad will have to be pushed manually to LP from now on. Maybe we can write and share a script to automate, so if you're not available I can update the whole thing on my own. :)
Over the past few days I tried a few times to delete obsolete bzr recipes for freecad-maintainers (full list is here) and I always get a timeout. I had no problem deleting my own test recipes on my own LP account so there seems to be a problem specific to freecad-maintainers. We'll have to ask Launchpad support.
NormandC
Postby NormandC » Sun May 01, 2016 9:30 pm
sgrogan wrote:We may finish just in time for Python3, QT5, OCCT 7, VTK .... :o
Oh man, now you're opening a whole new can of worms.
Thinking about packaging OCCT 7 makes my head hurt. :? But we may have no choice if we want FreeCAD to go forward. OCE seems to be in a ditch, with no sign of it being put on track again. :(
sgrogan
Postby sgrogan » Mon May 02, 2016 1:40 pm
- Find out how to get the SHA the source package has been created from.
$ git ls-remote -h https://git.launchpad.net/~freecad-maintainers/+git/gitmaster
5edeb99828be571ff2a21e6bd4661df00a526839        refs/heads/master
2ce5c8d2e3020d05005ed71f710e09e9aa561f40        refs/heads/releases/FreeCAD-0-16
sgrogan
Postby sgrogan » Mon May 02, 2016 9:27 pm
NormandC wrote:Great. When you get the chance, would it be possible for you to post the git commands you use to update the branches. I want to be sure I'm doing it the right way (since I didn't get prompted to git pull when checking out a branch it may not be the case)... Did you create remotes?
Can you post the output of
git remote -v
for each of the local version of the Launchpad repo's. The gitmaster code branch probably is just your clone of Github FreeCAD unless you've cloned from launchpad.
NormandC wrote:Over the past few days I tried a few times to delete obsolete bzr recipes for freecad-maintainers (full list is here) and I always get a timeout.
I'm getting the same thing????
f3nix
Postby f3nix » Tue May 03, 2016 4:12 am
sgrogan wrote:- Find out how to get the SHA the source package has been created from.
Hi sgrogan,
great idea! :) Thanks.
Cheers,
Mateusz
sgrogan
Postby sgrogan » Tue May 03, 2016 8:55 pm
NormandC wrote:3. Build package for trusty in personal PPA
In the cue https://code.launchpad.net/~clhclh/+rec ... ster-daily
For those following along, if you are not an experienced PPA user PLEASE DO NOT TEST. This is still experimental and we do not know the full consequences yet.
@NormandC
Do you have more thoughts on the LaunchPad versioning of the FreeCAD-daily package? Maybe appending the git hash. I think this is safe with the date first, to make the version more identifiable. But the normal user probably will never notice and we want to avoid any epoch stuff. I'm OK either way and will defer to your opinion.
EDIT: Added my personal PPA as software source and installed FreeCAD-daily. Got this
Processing triggers for shared-mime-info (1.2-0ubuntu3) ...
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Unknown media type in type 'uri/mms'
Unknown media type in type 'uri/mmst'
Unknown media type in type 'uri/mmsu'
Unknown media type in type 'uri/pnm'
Unknown media type in type 'uri/rtspt'
Unknown media type in type 'uri/rtspu'
I have freecad stable installed, freecad-daily installed, and an an uninstalled self-compiled build. They all seem to be peacefully coexisting.
EDIT: ppa:freecad-community/ppa packages are only available from FreeCAD stable. This could be re-worked.
sgrogan
Postby sgrogan » Thu May 05, 2016 10:09 pm
Updates to freecad-daily seems to work :)
I'm having issue with the freecad-daily-doc package, just starting to investigate
sgrogan@sgrogan-HP-ZBook-17:~$ sudo apt-get install freecad-daily-doc
[sudo] password for sgrogan:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
  linux-headers-3.13.0-77 linux-headers-3.13.0-77-generic
  linux-headers-3.13.0-79 linux-headers-3.13.0-79-generic
  linux-image-3.13.0-77-generic linux-image-3.13.0-79-generic
  linux-image-extra-3.13.0-77-generic linux-image-extra-3.13.0-79-generic
Use 'apt-get autoremove' to remove them.
The following NEW packages will be installed:
  freecad-daily-doc
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 81.4 MB of archives.
After this operation, 82.2 MB of additional disk space will be used.
Get:1 http://ppa.launchpad.net/clhclh/sgrogan/ubuntu/ [^] trusty/main freecad-daily-doc all 0.17~alpha1+git201605032021~ubuntu14.04.1 [81.4 MB]
Fetched 81.4 MB in 8min 51s (153 kB/s)
Selecting previously unselected package freecad-daily-doc.
(Reading database ... 289057 files and directories currently installed.)
Preparing to unpack .../freecad-daily-doc_0.17~alpha1+git201605032021~ubuntu14.04.1_all.deb ...
Unpacking freecad-daily-doc (0.17~alpha1+git201605032021~ubuntu14.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/freecad-daily-doc_0.17~alpha1+git201605032021~ubuntu14.04.1_all.deb (--unpack):
 trying to overwrite '/usr/share/doc-base/freecad-development-documentation', which is also in package freecad-doc 1:0.16.6703-1ppa1~ubuntu14.04.1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
sgrogan
Postby sgrogan » Fri May 06, 2016 6:23 pm
sgrogan wrote:Code: Select all
OK this seems to be a KDE problem.
http://askubuntu.com/questions/39852/ho ... media-type
