I downoaded and un7zip https://github.com/FreeCAD/FreeCAD/rele ... dev_win.7z
OS: Windows Vista
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.7461 (Git)
Hash: a38a78f6d6bd319a916ca8de87527e6d62137ec3
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
profiled with Dependency Walker I got :
LoadLibraryExA("e:\temp\freecad_0.17.7461_x86_dev_win\freecad_0.17.7461_x86_dev_win\Mod\Part\PartGui.pyd", 0x00000000, LOAD_WITH_ALTERED_SEARCH_PATH) returned NULL. Error: No se encontró el proceso especificado (127).
No se encontró el proceso especificado -->> Specified process not found
Dep Walker also reports
CGGL
LIBCGGL
LIBCGGL.DYLIB
LIBCGGL.SO
as "file not found"
It is worth mentioning this was not happening at all with 0.17.6726
0.17.7461_x86 LoadLibraryExA ... PartGui.pyd not found on Vista
Re: 0.17.7461_x86 LoadLibraryExA ... PartGui.pyd not found on Vista
http://freecadweb.org/tracker/view.php?id=2214Mike Feature wrote:Error: No se encontró el proceso especificado (127).
Can you look at the comments here? It sounds similar to your problems.
"fight the good fight"
Thank you for your attention.
I have carefully checked the comments and although my issue may fall into the general category of "binary incompatible" ... i do not think it could be labelled as "same problem"
It was not happenning with 0.17.6726 and I do not have any TK* in windows/system or windows/system32.
Thanks for checking. The key here is that the last working build for you was compiled with VS2009/VC8. The non-working builds are compiled with VS2013/VC12 which should support Vista. I'll look into a custom installer for x86 VC12 from current FreeCAD master. No promises here, I don't see what it would changeMike Feature wrote:It was not happenning with 0.17.6726
This wouldn't be limited to TK*, any c++ .dll could cause the problem.
Thank you sgrogan I think you found the key
What tests could I do ?
I will, of course, make sure vs2013/vc12 is rightfully installed then I will report what happens
Slightly changing subject I'd mention that although there is no error or issue that I could trace from Freecad not finding CGGL LIBCGGL LIBCGGL.DYLIB and LIBCGGL.SO ... the fact that a windows app tries to load a LIBCGGL.SO file would make me have a quick look at the code
