Install FreeCAD-addons-master
tourista
Re: Install FreeCAD-addons-master
Postby tourista » Tue Aug 02, 2016 2:24 am
Hello, same problem here !
Windows 7 64bit
version : 0.16
number : 6704 (git)
>>> import ssl
  File "C:\Program Files\FreeCAD 0.16\bin\lib\ssl.py", line 60, in <module>
    import _ssl             # if we can't import it, let the error propagate
ImportError: DLL load failed: Le module spécifié est introuvable.
Looks like some windows versions have embeded python compiled without SSL support as described in this thread : http://stackoverflow.com/questions/2837 ... type-https
easyw-fc
Postby easyw-fc » Tue Aug 02, 2016 3:22 pm
tourista wrote:Hello, same problem here !
sgrogan wrote: Same FreeCAD, same windows works.
I tried also FC017 32bit ... same problem
it seems to be a python SSL missing bundled with FC zip files
triplus
Postby triplus » Tue Aug 02, 2016 3:43 pm
All this tests should work without issues:
viewtopic.php?f=4&t=16163&start=10#p128850
As nobody reported back i assumed when testing no issues were found. But i guess in reality no testing was done. ;)
Anyway at least now we know where to look for solution. As for example network settings likely aren't the cause.
sgrogan
Postby sgrogan » Tue Aug 02, 2016 4:13 pm
triplus wrote:As nobody reported back i assumed when testing no issues were found. But i guess in reality no testing was done. ;)
See about 5 posts up in this thread
viewtopic.php?f=4&t=16163&start=20#p132140
"fight the good fight"
easyw-fc
Postby easyw-fc » Tue Aug 02, 2016 4:48 pm
sgrogan wrote: I have no system installed python.
triplus wrote:All this tests should work without issues:
sgrogan wrote:See about 5 posts up in this thread
sorry... I missed that
here the result of my tests
FC017-64b
Python 2.7.8 (default, Nov 17 2014, 20:37:05) [MSC v.1800 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> import httplib
>>> import socket
>>> import ssl
  File "C:\FreeCAD_0.17\bin\lib\ssl.py", line 60, in <module>
ImportError: DLL load failed: The specified module could not be found.
>>> hasattr(httplib, 'HTTPS')
False
>>> hasattr(socket, 'ssl')
False
FC016-64b
>>> import httplib
>>> import socket
>>> import ssl
  File "C:\FreeCAD\bin\lib\ssl.py", line 60, in <module>
False
False
sgrogan
Postby sgrogan » Tue Aug 02, 2016 4:51 pm
This is the weird part. I get the same errors on my non-working system but everything works on the working system, both systems are using the 0.16.6704 installer1 version.
easyw-fc
Postby easyw-fc » Tue Aug 02, 2016 5:07 pm
sgrogan wrote:This is the weird part. I get the same errors on my non-working system but everything works on the working system, both systems are using the 0.16.6704 installer1 version.
I found an old release of FC015 that is working on the same system
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
may be that release nbr could help
sgrogan
Postby sgrogan » Tue Aug 02, 2016 5:23 pm
easyw-fc wrote:under FreeCAD folder on your working system?
_ssl.pyd in PathtoFreeCAD/bin/DLLs on both 0.15 and 0.16 exact same file (same SHA)
On this system 0.15 works 0.16 doesn't
Screenshot from the 0.15 working version, note the python console
sgrogan
Postby sgrogan » Tue Aug 02, 2016 6:59 pm
Got it!
libeay32.dll and ssleay32.dll are missing
How they are being found on my working system is TBD. copying these 2 files from 0.15 bin directory fixes the problem.
triplus
Postby triplus » Tue Aug 02, 2016 8:23 pm
sgrogan wrote:Got it!
Great. Therefore there was SSL importing issue involved and that should be fixed now. I still suspect this could be separate issue:
urllib2.URLError: <urlopen error unknown url type: https>
That is replacing : with %3A might be needed in the future. But i guess lets wait to hear if any new reports will be made first.
