hello,
When i try to build the svn version I get this error :
12133 libtool: link: warning:
`/opt/opencascade-6.3/ros/Linux/lib/libTKXSBase.la' seems to be moved
12134 libtool: link: warning: `/opt/opencascade-6.3/ros/Linux/lib/libTKBool.la'
seems to be moved
12135 libtool: link: warning: `/opt/opencascade-6.3/ros/Linux/lib/libTKBO.la'
seems to be moved
12136 libtool: link: warning: `/opt/opencascade-6.3/ros/Linux/lib/libTKBRep.la'
seems to be moved
12137 libtool: link: warning:
`/opt/opencascade-6.3/ros/Linux/lib/libTKTopAlgo.la' seems to be moved
12138 libtool: link: warning:
`/opt/opencascade-6.3/ros/Linux/lib/libTKGeomAlgo.la' seems to be moved
12139 libtool: link: warning:
`/opt/opencascade-6.3/ros/Linux/lib/libTKGeomBase.la' seems to be moved
12140 libtool: link: warning:
`/opt/opencascade-6.3/ros/Linux/lib/libTKOffset.la' seems to be moved
12141 libtool: link: warning: `/opt/opencascade-6.3/ros/Linux/lib/libTKPrim.la'
seems to be moved
12142 libtool: link: x86_64-pc-linux-gnu-g++ -shared -nostdlib
/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2/../../../../lib64/crti.o
/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2/crtbeginS.o .libs/PartDesign_la-
|AppPartDesign.o -Wl,-rpath
-Wl,/usr/portage/distfiles/svn-src/trunk/src/Mod/Part/App/.libs -Wl,-rpath
-Wl,/usr/portage/distfiles/svn-src/trunk/src/App/.libs -Wl,-rpath
-Wl,/usr/portage/distfiles/svn- |src/trunk/src/Base/.libs -Wl,-rpath
-Wl,/opt/opencascade-6.3/ros/lin/lib64 -Wl,-rpath -Wl,/usr/Mod/Part -Wl,-rpath
-L/usr/portage/distfiles/svn-src/trunk/src/App/. |libs
-L/usr/portage/distfiles/svn-src/trunk/src/Base/.libs
-L/usr/portage/distfiles/svn-src/trunk/src/Mod/ |Part/App -L/usr/lib64
-L/usr/lib -L/opt/opencascade-6.3/ros/Linux/lib -lboost_regex-mt
/usr/portage/distfiles/svn-src/trunk/src/Mod/Part/App/.libs/libPart.so
-L/usr/X11R6/lib -L/opt/opencascade-6.3/ros/ |lin/lib64
/usr/portage/distfiles/svn-src/trunk/src/App/.libs/libFreeCADApp.so
-lboost_program_options-mt -lboost_signals-mt
/usr/portage/distfiles/svn-src/trunk/src/Base/.libs/libFreeCADBase.so -
|lboost_filesystem-mt -lboost_system-mt -lpython2.6
/usr/lib64/libxerces-c.so -lnsl /usr/lib64/libcurl.so /usr/lib64/libidn.so
/usr/lib64/libldap.so /usr/lib64/liblber.so /usr/lib64/libsasl2.so -lcrypt -
|lrt -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lresolv -ldl
/usr/lib64/libgnutls.so /usr/lib64/libtasn1.so -lz /usr/lib64/libgcrypt.so
/usr/lib64/libgpg-error.so -licuuc -licudata /opt/opencascade-6.3/
|ros/lin/lib64/libTKSTEP.so /opt/opencascade-6.3/ros/lin/lib64/libTKSTEPAttr.so
/opt/opencascade-6.3/ros/lin/lib64/libTKSTEP209.so
/opt/opencascade-6.3/ros/lin/lib64/libTKSTEPBase.so /opt/opencascade-6.3/
|ros/lin/lib64/libTKIGES.so /opt/opencascade-6.3/ros/lin/lib64/libTKSTL.so
/opt/opencascade-6.3/ros/lin/lib64/libTKMesh.so
/opt/opencascade-6.3/ros/lin/lib64/libTKXSBase.so /opt/opencascade-6.3/ros/lin/
|lib64/libTKOffset.so
/opt/opencascade-6.3/ros/lin/lib64/libTKFillet.so
/opt/opencascade-6.3/ros/lin/lib64/libTKShHealing.so
/opt/opencascade-6.3/ros/lin/lib64/libTKBool.so /opt/opencascade-6.3/ros/lin/
|lib64/libTKPrim.so /opt/opencascade-6.3/ros/lin/lib64/libTKBO.so
/opt/opencascade-6.3/ros/lin/lib64/libTKTopAlgo.so
/opt/opencascade-6.3/ros/lin/lib64/libTKGeomAlgo.so
/opt/opencascade-6.3/ros/lin/lib64/ |libTKBRep.so
/opt/opencascade-6.3/ros/lin/lib64/libTKGeomBase.so
/opt/opencascade-6.3/ros/lin/lib64/libTKG3d.so
/opt/opencascade-6.3/ros/lin/lib64/libTKG2d.so
/opt/opencascade-6.3/ros/lin/lib64/libTKMath. |so
/opt/opencascade-6.3/ros/lin/lib64/libTKernel.so -lpthread -lPartDesign
-L/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2
-L/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2/../../../../lib64 -L/lib/../lib64
-L/usr/ |lib/../lib64
-L/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2/../../../../x86_64-pc-linux-gnu/lib
-L/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2/../../.. -lstdc++ -lm -lc -lgcc_s
/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2/ |crtendS.o
/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2/../../../../lib64/crtn.o -march=core2
-Wl,-O1 -Wl,-soname -Wl,PartDesign.so -o .libs/PartDesign.so
12143
/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2/../../../../x86_64-pc-linux-gnu/bin/ld:
cannot find -lPartDesign
12144 collect2: ld returned 1 exit status
12145 make[5]: *** [PartDesign.la] Error 1
12146 make[5]: *** Waiting for unfinished jobs....
12147 libtool: link: x86_64-pc-linux-gnu-g++ -shared -nostdlib
/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2/crtbeginS.o .libs/libPartDesign_la-
|AppPartDesignPy.o .libs/libPartDesign_la-FeatureFillet.o
.libs/libPartDesign_la-FeaturePad.o .libs/libPartDesign_la-PreCompiled.o
-Wl,-rpath -Wl,/usr/portage/distfiles/svn-src/trunk/src/Mod/Part/App/.
|libs -Wl,-rpath -Wl,/usr/portage/distfiles/svn-src/trunk/src/App/.libs
-Wl,-rpath -Wl,/usr/portage/distfiles/svn-src/trunk/src/Base/.libs -Wl,-rpath
-Wl,/opt/opencascade-6.3/ros/lin/lib64 -Wl,-rpath -Wl,/ |usr/Mod/Part
-Wl,-rpath -Wl,/opt/opencascade-6.3/ros/lin/lib64
-L/usr/portage/distfiles/svn-src/trunk/src/App/.libs
-L/usr/portage/distfiles/svn-src/ |trunk/src/Base
-L/usr/portage/distfiles/svn-src/trunk/src/Mod/Part/App -L/usr/lib64 -L/usr/lib
-L/opt/opencascade-6.3/ros/Linux/lib -lboost_regex-mt /usr/
-L/usr/X11R6/lib -L/opt/opencascade-6.3/ros/lin/lib64
/usr/portage/distfiles/svn-src/trunk/src/App/.libs/libFreeCADApp.so -
-lboost_filesystem-mt -lboost_system-mt -lpython2.6 /usr/lib64/libxerces-c.so
-lnsl /usr/ |lib64/libcurl.so /usr/lib64/libidn.so /usr/lib64/libldap.so
/usr/lib64/liblber.so /usr/lib64/libsasl2.so -lcrypt -lrt -lgssapi_krb5 -lkrb5
-lk5crypto -lcom_err -lresolv -ldl /usr/lib64/libgnutls.so /usr/
|lib64/libtasn1.so -lz /usr/lib64/libgcrypt.so /usr/lib64/libgpg-error.so
-licuuc -licudata /opt/opencascade-6.3/ros/lin/lib64/libTKSTEP.so
/opt/opencascade-6.3/ros/lin/lib64/libTKSTEPAttr.so /opt/
/opt/opencascade-6.3/ros/lin/lib64/libTKIGES.so
/opt/opencascade-6.3/ros/lin/lib64/libTKSTL.so /opt/
/opt/opencascade-6.3/ros/lin/lib64/libTKOffset.so
/opt/opencascade-6.3/ros/lin/lib64/libTKFillet.so /opt/
/opt/opencascade-6.3/ros/lin/lib64/libTKPrim.so
/opt/opencascade-6.3/ros/lin/lib64/libTKBO.so /opt/
/opt/opencascade-6.3/ros/lin/lib64/libTKBRep.so
/opt/opencascade-6.3/ros/lin/lib64/libTKGeomBase.so /opt/
/opt/opencascade-6.3/ros/lin/lib64/libTKMath.so
/opt/opencascade-6.3/ros/lin/lib64/libTKernel.so -lpthread -L/usr/
-L/usr/lib/../lib64
|lib -L/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2/../../.. -lstdc++ -lm -lc
-lgcc_s /usr/lib/gcc/x86_64-pc-linux-gnu/4.4.2/crtendS.o
|march=core2 -Wl,-O1 -Wl,-soname -Wl,libPartDesign.so.2 -o
.libs/libPartDesign.so.2.0.0
12148 libtool: link: (cd ".libs" && rm -f "libPartDesign.so.2" && ln -s
"libPartDesign.so.2.0.0" "libPartDesign.so.2")
12149 libtool: link: (cd ".libs" && rm -f "libPartDesign.so" && ln -s
"libPartDesign.so.2.0.0" "libPartDesign.so")
12150 libtool: link: ( cd ".libs" && rm -f "libPartDesign.la" && ln -s
"../libPartDesign.la" "libPartDesign.la" )
12151 make[5]: Leaving directory
`/usr/portage/distfiles/svn-src/trunk/src/Mod/PartDesign/App'
12152 make[4]: *** [all-recursive] Error 1
12153 make[4]: Leaving directory
`/usr/portage/distfiles/svn-src/trunk/src/Mod/PartDesign'
12154 make[3]: *** [all-recursive] Error 1
12155 make[3]: Leaving directory `/usr/portage/distfiles/svn-src/trunk/src/Mod'
12156 make[2]: *** [all-recursive] Error 1
12157 make[2]: Leaving directory `/usr/portage/distfiles/svn-src/trunk/src'
12158 make[1]: *** [all-recursive] Error 1
12159 make[1]: Leaving directory `/usr/portage/distfiles/svn-src/trunk'
12160 make: *** [all] Error 2
How can this be solved.
Roelof
compile problems voor svn version on Gentoo
Re: compile problems voor svn version on Gentoo
Werner
did you run make with the option "-j"? Don't do that because this seems to cause some race conditions at compile time. I still didn't come behind the magic how to do a proper parallel build with automake.12146 make[5]: *** Waiting for unfinished jobs....
Werner
