[Ubuntu Daily PPA] Transitioning to OCCT7, VTK7...
sgrogan
Re: [Ubuntu Daily PPA] Transitioning to OCCT7, VTK7...
Postby sgrogan » Tue Apr 04, 2017 10:18 pm
gdo35 wrote:I'll try to test with git-builder this week ;)
Thanks gdo35! I really appreciate all the effort! We have a Path guy, a MCAD guy, and a windows guy, advancing the PPA, pretty cool :geek:
"fight the good fight"
gdo35
Postby gdo35 » Wed Apr 05, 2017 3:01 pm
sgrogan wrote:Thanks gdo35! I really appreciate all the effort! We have a Path guy, a MCAD guy, and a windows guy, advancing the PPA, pretty cool :geek:
I cannot find myself it that list !!! :lol: :lol: :lol:
I'm more a Linux guy and happy FreeCAD user. ;)
It is just a pleasure to help a little. :)
abdullah
Postby abdullah » Sat May 06, 2017 9:07 pm
Hi there!
A user in the spanish forum is asking about how to activate OCCT multithreading in Ubuntu. I found the topic interesting.
I thought OCCT 7.1 from the daily PPA was built with TBB enabled.
1. Does anybody have any information about this?
2. Is there anything one should do to "enable" the multithread support?
3. BTW has anybody benchmarked the effect of OCCT multithread in FC?
Postby Kunda1 » Sat May 06, 2017 9:21 pm
@Abdullah check out viewtopic.php?f=10&t=18179&p=142585#p142585 and its partner issue #2750
triplus
Postby triplus » Sat May 06, 2017 10:03 pm
As @Kunda1 mentioned this is the relevant bench:
https://forum.freecadweb.org/viewtopic. ... 30#p154815
Best to create 2 macros and after run each once. Look in the report view for the time that was needed for each bench to complete and compare the results. Use Top or System Monitor to observe multi-threading. Note that in both tests some multi-threading will be detected (detected at the end). It is meshing related:
Part.show(result)
If hardware is fast increase the value of:
cols = 20
rows = 20
Postby NormandC » Sat May 06, 2017 10:19 pm
The libopencascade packages used by the freecad-daily PPA are built with libtbb-dev as a dependency and the rules build script enables TBB. But I haven't tested this.
abdullah
Postby abdullah » Sun May 07, 2017 1:41 pm
Thank you for your answers.
Ok, so I repeated triplus test, the 100x100 version with 8 cores using Ubuntu's daily build:
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10993 (Git)
Build type: None
Hash: bf5f3484f6f5506795b6e9b86288c75ab7357291
Python version: 2.7.12
OCC version: 7.1.0
You can see multitask:
However:
1. Multi-thread is not used during the whole time.
2. Not everytime that multi-thread is used the 8 cores are running
Results:
314.795207024s - 100x100
222.212337971s - 100x100
So you need about the 70% of the time for the same operation.
abdullah
Postby abdullah » Sun May 07, 2017 1:52 pm
So, if understood it correctly, when you use operations that are optimized in OCCT for multithread, you get the boost in performance.
I have some follow-up questions:
1. Which operations are generally optimized?
2. What needs to be done in FreeCAD so that in the general workflow (e.g. Part Design) we get this boost?
damian
Postby damian » Sun May 07, 2017 2:44 pm
hello @abdullah:
abdullah wrote:1. Which operations are generally optimized?
I think all the operations based on the GeneralFuse algorithm.
shape=Part.Shape()
shape.cut.__doc__
'Difference of this and a given (list of) topo shape\ncut(tool) -> Shape\n  or\ncut((tool1,tool2,...),[tolerance=0.0]) -> Shape\n\nSubstraction of this and a given list of topo shapes.\n\nSupports:\n- Fuzzy Boolean operations (global tolerance for a Boolean operation)\n- Support of multiple arguments for a single Boolean operation\n- Parallelization of Boolean Operations algorithm\n\nOCC 6.9.0 or later is required.'
The complete explanation in the OCCT documentation, chapter User Guides
https://www.opencascade.com/doc/occt-7. ... gorithms_1
The Boolean Component contains:
General Fuse Operator (GFA),
Boolean Operator (BOA),
Section Operator (SA),
Partition Operator (PA).
GFA is the base algorithm for BOA, PA, SA.
Uhf! What's Partition Operator (PA)?
EDIT: fix typos
triplus
Postby triplus » Mon May 08, 2017 12:11 am
abdullah wrote:So, if understood it correctly, when you use operations that are optimized in OCCT for multithread, you get the boost in performance.
For some operations you don't need to do anything as the support is there by default. For example:
Part.show(shape)
Latest OCC/OCE should use algorithms that do this in parallel. As for boolean operations here is a list of the current situation in FreeCAD:
https://forum.freecadweb.org/viewtopic. ... 30#p143338
And some more info:
https://forum.freecadweb.org/viewtopic. ... 10#p151947
