[Ubuntu Daily PPA] Transitioning to OCCT7, VTK7...
sgrogan
Re: [Ubuntu Daily PPA] Transitioning to OCCT7, VTK7...
Postby sgrogan » Wed Mar 15, 2017 9:33 pm
NormandC wrote:I suspect that it's because C++11 isn't enabled. I don't know how to enable it in the debian/rules makefile.
I don't see why just appending the additional flags doesn't work.
From here Hardening it seems we could append the flags. See OCCT7-packaging/tree/debian/rules for the base implementation without extra flags. Also see how FreeCAD does it from CMake in the rules file.
gdo35 wrote:As you notice, I deactivate man pages install, due to missing files. It will need to be corrected later.
I think this is because of the missing -DNGLIB_EXPORTS?
gdo35 wrote:I also needed to reorder packages into debian/control file according to inter packages dependencies :
This make a lot of sense.
I'm short on time so I hope this makes sense. Will return ASAP.
Great job NormandC, sorry for the recent lack of participation, I've been fighting the weather in my locale. :(
NormandC
Postby NormandC » Wed Mar 15, 2017 11:14 pm
Hi gdo :D
gdo35 wrote:The sed command I added is to remove libFWOSPlugin.so dependency. I got an error at build telling me the lib cannot be found.
Now that is puzzling, because the /debian/patches/nglib-occt7.patch is already supposed to do that. :?
Odd, I thought they were in /debian/, will check.
Are you saying the order is which the packages are listed in debian/control is important? I never read anything about it...
Thanks for the assist! :)
Why would it be related?
sgrogan wrote:From here Hardening it seems we could append the flags. See OCCT7-packaging/tree/debian/rules for the base implementation without extra flags. Also see how FreeCAD does it from CMake in the rules file.
I repeatedly looked in those files and couldn't make sense of them. As I said, for me a makefile could as well be written in Chinese! Thanks for the "Hardening" link, I have no idea what the term even means. More reading to add to the pile...
sgrogan wrote:sorry for the recent lack of participation, I've been fighting the weather in my locale. :(
Snow?
I just came back from shovelling part of my driveway, and about 24" (60cm) of snow from my 10'x10' (3x3m) patio.
NormandC
Postby NormandC » Wed Mar 15, 2017 11:15 pm
HoWil wrote:Maybe one of the occ guys can have a look at ... https://forum.freecadweb.org/viewtopic. ... 54#p165574
Looks like it is a related Segmentation fault-prob.
Thanks in advance,
I dearly hope that it's an OCC issue rather than a packaging one. :?
gdo35
Postby gdo35 » Thu Mar 16, 2017 9:34 am
It should but it does not since you patch configure file and not configure.ac file. ;)
Check first line of the patch file :
diff --git a/configure b/configure
Autotools generate configure from configure.ac so your patch is overwritten. IMHO generated files should never be in source repository.
I will rebuild the patch and keep you in touch. What I did yesterday was just some quick and dirty tests, I want to make something a bite more serious.
gdo35
Postby gdo35 » Thu Mar 16, 2017 3:43 pm
Why netgen version to use is 5.3.1 ?
What about last release 6.0 or 6.1 ?
sgrogan
Postby sgrogan » Thu Mar 16, 2017 9:08 pm
NormandC wrote:Why would it be related?
I see stl in one of the missing packages so maybe the libs (.so) are not being built so no man pages.
NormandC wrote:Snow?
Yeah, only 16" here, but lots of wind so we've been getting power outages.
gdo35 wrote:Why netgen version to use is 5.3.1 ?
Mainly because we have a working patch, this is what the OSX builds are using. On Win NG 6.x uses C++ features not supported by our current VS2013 compiler. After FreeCAD is ported to Python3 in may make sense to upgrade because NG 6.x python bindings can be built. But that's a whole new can of worms :roll:
gdo35
Postby gdo35 » Thu Mar 16, 2017 10:11 pm
Ok, just asking because netgen 6.X uses cmake. ;)
sgrogan
Postby sgrogan » Thu Mar 16, 2017 10:19 pm
gdo35 wrote:Ok, just asking because netgen 6.X uses cmake. ;)
That is how I found out windows can't support it. I think @looo got this working on his conda builds. There is no reason not to use it if we (read: someone smarter than me) can patch for occt 7.1
blacey
Postby blacey » Thu Mar 16, 2017 10:49 pm
@normandc, @gdo35, in case it helps, I have updated the nglib-occt7.patch to include the patch for configure.ac.
To apply to a clean netgen 5.3.1 source tree, cd into the root of the source tree and issue the following command:
curl -L https://github.com/FreeCAD/homebrew-freecad/releases/download/0/nglib-occt7.patch | patch -p1
Output
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   596    0   596    0     0   1424      0 --:--:-- --:--:-- --:--:--  1425
100 13084  100 13084    0     0  15247      0 --:--:-- --:--:-- --:--:-- 59203
patching file configure
patching file configure.ac
patching file libsrc/meshing/improve2.hpp
patching file libsrc/meshing/meshclass.hpp
patching file libsrc/meshing/meshtype.hpp
patching file libsrc/occ/Partition_Inter2d.hxx
patching file libsrc/occ/Partition_Inter3d.hxx
patching file libsrc/occ/Partition_Loop.hxx
patching file libsrc/occ/Partition_Loop2d.cxx
patching file libsrc/occ/Partition_Loop2d.hxx
patching file libsrc/occ/Partition_Loop3d.hxx
patching file libsrc/occ/Partition_Spliter.hxx
patching file libsrc/occ/occgeom.cpp
patching file libsrc/occ/occgeom.hpp
patching file libsrc/occ/occmeshsurf.hpp
patching file libsrc/occ/vsocc.cpp
patching file ng/Makefile.in
patching file ng/ngpkg.cpp
NormandC
Postby NormandC » Fri Mar 17, 2017 2:44 am
@ gdo35
Just had a look at this again:
Sorry, did you install the docbook-to-man package? It's needed to generate the netgen.1 manpage from the netgen.sgml file. I'm afraid I inadvertently removed it from control's Build Depends. :oops:
@ blacey
Thanks for the updated patch. FYI in debian packaging we are not applying it directly to the source before packaging. It's added in the /debian/patches folder and it's applied at compilation time so the source remains "untainted".
gdo35 wrote:There is no libnglib-*.so but there is several independant libs that were not installed but needed by netgen binaries. I install them all :
I believe the version number appended to libnglib-*.so is done through a patch. In the netgen-4.9.13 package from the Debian/Ubuntu repositories, there are a whole bunch of patches I didn't bother trying to port to 5.3.1. See https://anonscm.debian.org/cgit/debian- ... .13.dfsg-8
I'm thinking nglib-version.patch might be the one that does it. Do you think this is something we should replicate?
As I also mentioned previously, there is a 5.1 branch from 2013 that inexplicably never made it in the repositories.
