OpenCamLib compile on Linux
Re: OpenCamLib compile on Linux
All systems are GO. See below!
Thanks for the response sgrog. Those tiny tid bits of VITAL information sure helped out! I have been waiting a very long time to get ocl installed.
I am surely not alone. Previous installation details were just simply incomplete. Cant assume others have a dev-ready environ.
Anywho, CHEERS!
Anywho, CHEERS!
After trying an unsuccessful OS upgrade, freecad now throws an error when switching to PATH workbench; No module named PathCommands.
Additionally, Path Workbench never loads. HELP!!!!!!!
Think Ill just stick with Ubuntu 15.10 awhile longer OFF-NET!!!!!
After trying Posting -- Re: Error selecting Path WB: No module named PathCommands --,
workbench loads but still has issues.
Can I deinstall the workbench with a apt-get or similar command?
That's got nothing to do with camlib, I have a solution until the new daily is out. viewtopic.php?f=4&t=18069
Path is an integral Part of FreeCAD so apt can't be used to remove it selectively. As chrisb has pointed out the PathCommands error is unrelated to the ocl stuff (probably). There were several workarounds suggested in the related thread, what exactly did you do? Version info is useful here.geant wrote:After trying Posting -- Re: Error selecting Path WB: No module named PathCommands --,
Remember 0.17 is the dev branch. There will be bugs. Try to do only one change at a time yourself, nothing says there isn't two unrelated bugs.
Specifics are important here.geant wrote: workbench loads but still has issues.
Thanks for testing!
PS: Maybe wait for the next update and see what happens. Wily is still activated on Launchpad, but it won't be forever.
Edit: fixed typo in blue
"fight the good fight"
Seems to have a typo there, should have been "can't".sgrogan wrote:Path is an integral Part of FreeCAD so apt can be used to remove it selectively.
Indeed, and a counter productive one at that. I've edited my previous post.NormandC wrote: Seems to have a typo there, should have been "can't".
Hi, just continuing this thread, as it is related and others have not too long ago...
I am trying to install opencamlib into the flatpak version of FreeCAD (Ubuntu 22.04).
From the opencam github readme, it mentions "If you don't know where Python is, but you have access to it's interpreter (FreeCAD and Blender both have a Python console), you can simply enter this command in there to install OpenCAMLib:"
Great I thought... that should do it
The command was:
But this seems to try and run the command against Freecad itself (which doesn't know what -m is)... it does not seem to run against Freecad's python.
Would anyone know how to install opencamlib into the Flatpak version of FreeCAD? Using the console seemed like a good idea... but???
The command was:
import sys; import subprocess; subprocess.check_call([sys.executable, '-m', 'pip', 'install', 'opencamlib'])
You replied to a very old topic. Meanwhile openCamLib is included in FreeCAD. Did you try the AppImage?
Apologies for continuing this thread, I knew it was an old thread, but thought I saw some continuation in late 2022, but that must have been another post I was also reviewing...
And thank-you for your suggestion to try the AppImage version, I tend to use Flatpak's if they are available and of the same version.
The AppImage does seem to be a bit different despite being the same version, a couple of little graphical things is better, and it also has the Path workbrench pre-installed and the 3D operations are indeed there already, unlike the Flatpak version.
So all good.
Shall I delete these posts?
So all good.
