compile errors on win7
I am trying to compile the FC from scratch for the first time.
I have setup everything as described in wiki and unloaded the majority of the components, see here:viewtopic.php?f=4&t=1884.
Now I get the following errors:
1>------ Build started: Project: ZERO_CHECK, Configuration: Debug Win32 ------
2>------ Build started: Project: FreeCADBase, Configuration: Debug Win32 ------
2> dircoll.cpp
2>C:\FreeCADbuild\free-cad\trunk\src\zipios++\dircoll.cpp(137): error C2872: 'get' : ambiguous symbol
2> could be 'c:\freecadbuild\free-cad\trunk\src\zipios++\directory.h(70) : boost::filesystem::get'
2> or 'get'
2> or 'get'
2>C:\FreeCADbuild\free-cad\trunk\src\zipios++\dircoll.cpp(141): error C2872: 'get' : ambiguous symbol
2> or 'get'
2> or 'get'
3>------ Build started: Project: FreeCADApp, Configuration: Debug Win32 ------
3> Application.cpp
3>C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\include\Shfolder.h(14): fatal error C1189: #error : shfolder.h/shfolder.lib provide platform independence with versions prior to Windows 2000. Use shlobj.h/shell32.lib if targetting Windows 2000 or higher.
4>------ Build started: Project: FreeCADGui, Configuration: Debug Win32 ------
5>------ Build started: Project: Start, Configuration: Debug Win32 ------
5>LINK : fatal error LNK1104: cannot open file '..\..\..\App\Debug\FreeCADAppD.lib'
4>LINK : fatal error LNK1104: cannot open file '..\App\Debug\FreeCADAppD.lib'
6>------ Build started: Project: Sketcher, Configuration: Debug Win32 ------
7>------ Build started: Project: PartGui, Configuration: Debug Win32 ------
6> SubSystem.cpp
7>LINK : fatal error LNK1104: cannot open file '..\App\Debug\Part_d.lib'
8>------ Build started: Project: PartDesign, Configuration: Debug Win32 ------
8>LINK : fatal error LNK1104: cannot open file '..\..\Part\App\Debug\Part_d.lib'
9>------ Build started: Project: QtUnitGui, Configuration: Debug Win32 ------
6>C:\FreeCADbuild\free-cad\trunk\src\Mod\Sketcher\App\freegcs\SubSystem.cpp(65): error C2039: 'back_inserter' : is not a member of 'std'
6>C:\FreeCADbuild\free-cad\trunk\src\Mod\Sketcher\App\freegcs\SubSystem.cpp(65): error C3861: 'back_inserter': identifier not found
9>LINK : fatal error LNK1104: cannot open file '..\..\..\Gui\Debug\FreeCADGuiD.lib'
10>------ Build started: Project: FreeCADMainPy, Configuration: Debug Win32 ------
11>------ Build started: Project: FreeCADMainCmd, Configuration: Debug Win32 ------
10>LINK : fatal error LNK1104: cannot open file '..\App\Debug\FreeCADAppD.lib'
11>LINK : fatal error LNK1104: cannot open file '..\App\Debug\FreeCADAppD.lib'
12>------ Build started: Project: FreeCADMain, Configuration: Debug Win32 ------
13>------ Build started: Project: FreeCADGuiPy, Configuration: Debug Win32 ------
12>LINK : fatal error LNK1104: cannot open file '..\Gui\Debug\FreeCADGuiD.lib'
13>LINK : fatal error LNK1104: cannot open file '..\Gui\Debug\FreeCADGuiD.lib'
14>------ Build started: Project: SketcherGui, Configuration: Debug Win32 ------
15>------ Build started: Project: StartGui, Configuration: Debug Win32 ------
15>LINK : fatal error LNK1104: cannot open file '..\App\Debug\Start_d.lib'
16>------ Build started: Project: PartDesignGui, Configuration: Debug Win32 ------
14>LINK : fatal error LNK1104: cannot open file '..\App\Debug\Sketcher_d.lib'
16>LINK : fatal error LNK1104: cannot open file '..\App\Debug\PartDesign_d.lib'
17>------ Build started: Project: ALL_BUILD, Configuration: Debug Win32 ------
17> Build all projects
========== Build: 2 succeeded, 15 failed, 1 up-to-date, 0 skipped ==========
Either I have unloaded too much, or there is some other problem... Can anybody assist?
2> dircoll.cpp
2> or 'get'
2> or 'get'
2> or 'get'
2> or 'get'
3> Application.cpp
6> SubSystem.cpp
Re: compile errors on win7
I have replaced the 'get' with 'boost::filesystem::get'
and commented out the
in the Aplication.cpp. Now I get the following:
2>------ Build started: Project: FreeCADApp, Configuration: Debug Win32 ------
2> Application.cpp
2>c:\freecadbuild\free-cad\trunk\src\zipios++\ziphead.h(182): warning C4244: 'return' : conversion from 'std::streamoff' to 'int', possible loss of data
2> Creating library C:/FreeCADbuild/FreeCAD/src/App/Debug/FreeCADAppD.lib and object C:/FreeCADbuild/FreeCAD/src/App/Debug/FreeCADAppD.exp
2>Application.obj : error LNK2001: unresolved external symbol "class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > boost::program_options::arg" (?arg@program_options@boost@@3V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@A)
2>C:\FreeCADbuild\FreeCAD\bin\Debug\FreeCADAppD.dll : fatal error LNK1120: 1 unresolved externals
3>------ Build started: Project: FreeCADGui, Configuration: Debug Win32 ------
4>------ Build started: Project: Start, Configuration: Debug Win32 ------
4> Creating library C:/FreeCADbuild/FreeCAD/src/Mod/Start/App/Debug/Start_d.lib and object C:/FreeCADbuild/FreeCAD/src/Mod/Start/App/Debug/Start_d.exp
4> Start.vcxproj -> C:\FreeCADbuild\FreeCAD\Mod\Start\Debug\Start_d.pyd
3> Creating library C:/FreeCADbuild/FreeCAD/src/Gui/Debug/FreeCADGuiD.lib and object C:/FreeCADbuild/FreeCAD/src/Gui/Debug/FreeCADGuiD.exp
3> FreeCADGui.vcxproj -> C:\FreeCADbuild\FreeCAD\bin\Debug\FreeCADGuiD.dll
5>------ Build started: Project: Sketcher, Configuration: Debug Win32 ------
6>------ Build started: Project: PartGui, Configuration: Debug Win32 ------
5> SubSystem.cpp
6>LINK : fatal error LNK1104: cannot open file '..\App\Debug\Part_d.lib'
7>------ Build started: Project: PartDesign, Configuration: Debug Win32 ------
7>LINK : fatal error LNK1104: cannot open file '..\..\Part\App\Debug\Part_d.lib'
8>------ Build started: Project: QtUnitGui, Configuration: Debug Win32 ------
8> Creating library C:/FreeCADbuild/FreeCAD/src/Mod/Test/Gui/Debug/QtUnitGui_d.lib and object C:/FreeCADbuild/FreeCAD/src/Mod/Test/Gui/Debug/QtUnitGui_d.exp
5>C:\FreeCADbuild\free-cad\trunk\src\Mod\Sketcher\App\freegcs\SubSystem.cpp(65): error C2039: 'back_inserter' : is not a member of 'std'
5>C:\FreeCADbuild\free-cad\trunk\src\Mod\Sketcher\App\freegcs\SubSystem.cpp(65): error C3861: 'back_inserter': identifier not found
8> QtUnitGui.vcxproj -> C:\FreeCADbuild\FreeCAD\Mod\Test\Debug\QtUnitGui_d.pyd
9>------ Build started: Project: FreeCADMainPy, Configuration: Debug Win32 ------
9> Creating library C:/FreeCADbuild/FreeCAD/src/Main/Debug/FreeCAD_d.lib and object C:/FreeCADbuild/FreeCAD/src/Main/Debug/FreeCAD_d.exp
10>------ Build started: Project: FreeCADMainCmd, Configuration: Debug Win32 ------
9> FreeCADMainPy.vcxproj -> C:\FreeCADbuild\FreeCAD\bin\Debug\FreeCAD_d.pyd
10> FreeCADMainCmd.vcxproj -> C:\FreeCADbuild\FreeCAD\bin\Debug\FreeCADCmdD.exe
11>------ Build started: Project: FreeCADMain, Configuration: Debug Win32 ------
12>------ Build started: Project: FreeCADGuiPy, Configuration: Debug Win32 ------
11>qtmaind.lib(qtmain_win.obj) : warning LNK4099: PDB 'vc90.pdb' was not found with 'qtmaind.lib(qtmain_win.obj)' or at 'C:\FreeCADbuild\FreeCAD\bin\Debug\vc90.pdb'; linking object as if no debug info
12> Creating library C:/FreeCADbuild/FreeCAD/src/Main/Debug/FreeCADGui_d.lib and object C:/FreeCADbuild/FreeCAD/src/Main/Debug/FreeCADGui_d.exp
11> FreeCADMain.vcxproj -> C:\FreeCADbuild\FreeCAD\bin\Debug\FreeCADD.exe
13>------ Build started: Project: SketcherGui, Configuration: Debug Win32 ------
12> FreeCADGuiPy.vcxproj -> C:\FreeCADbuild\FreeCAD\bin\Debug\FreeCADGui_d.pyd
14>------ Build started: Project: StartGui, Configuration: Debug Win32 ------
14> Creating library C:/FreeCADbuild/FreeCAD/src/Mod/Start/Gui/Debug/StartGui_d.lib and object C:/FreeCADbuild/FreeCAD/src/Mod/Start/Gui/Debug/StartGui_d.exp
14> StartGui.vcxproj -> C:\FreeCADbuild\FreeCAD\Mod\Start\Debug\StartGui_d.pyd
15>------ Build started: Project: PartDesignGui, Configuration: Debug Win32 ------
13>LINK : fatal error LNK1104: cannot open file '..\App\Debug\Sketcher_d.lib'
15>LINK : fatal error LNK1104: cannot open file '..\App\Debug\PartDesign_d.lib'
16>------ Build started: Project: ALL_BUILD, Configuration: Debug Win32 ------
16> Build all projects
========== Build: 10 succeeded, 6 failed, 2 up-to-date, 0 skipped ==========
# ifdef _MSC_VER
# include <Shfolder.h>
# endif
2> Application.cpp
5> SubSystem.cpp
Which version of VS d you use? Try using VS2008.
I use VC++ 2010 express (SP1).
OK, I have removed the BUILD_ALL and ZERO_CHECK and reloaded the Part, PartDesign and their GUIs. Still won't compile. Same errors as before. Do you think it could be VS2010 vs VS2008?
Are these all error messages you get? For the back_inserter error try #include <iterator>.
and what about this one?
tilas wrote:2>Application.obj : error LNK2001: unresolved external symbol "class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > boost::program_options::arg" (?arg@program_options@boost@@3V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@A)
Well, I have installed the VC++2008 express and tried to run the Cmake again. here is what I get:
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
COIN3D_INCLUDE_DIR
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/3rdParty/Pivy
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Main
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Points/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Complete/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Image/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Mesh/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Part/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/PartDesign/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Raytracing/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Drawing/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Sketcher/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Robot/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/ReverseEngineering/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/MeshPart/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Web/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Start/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Import/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Inspection/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Mod/Fem/Gui
used as include directory in directory C:/FreeCADbuild/free-cad/trunk/src/Gui
COIN3D_LIBRARY_DEBUG
linked by target "coin" in directory C:/FreeCADbuild/free-cad/trunk/src/3rdParty/Pivy
linked by target "soqt" in directory C:/FreeCADbuild/free-cad/trunk/src/3rdParty/Pivy
linked by target "FreeCADGui" in directory C:/FreeCADbuild/free-cad/trunk/src/Gui
COIN3D_LIBRARY_RELEASE
When I ran the Cmake against the VC2010 it marked the Coin3 as "not found", but did not issue these errors.
COIN3D_INCLUDE_DIR
In App/Application.cpp line 1282:
Maybe you have to increase to 1800, i.e:
#if (defined(_MSC_VER) && (_MSC_VER < 1600))
#if (defined(_MSC_VER) && (_MSC_VER < 1800))
Werner, thank a lot. these two changes (the #include and the 1800) have made the VC2010 setup compile with only one warning:
1> Application.cpp
1>c:\freecadbuild\free-cad\trunk\src\zipios++\ziphead.h(182): warning C4244: 'return' : conversion from 'std::streamoff' to 'int', possible loss of data
To summarize the setup and changes needed till now:
Win7x64, VC++2010 SP1 Express, setup as per wiki with libpack and Cmake.
Changes:
1. in the ...\src\zipios++\dircoll.cpp lines 137 and 14:1 substitute 'get' with 'boost::filesystem::get'
2. in the ...\FreeCADApp\Aplication.cpp: comment the
3. in the ...\Mod\Sketcher\App\freegcs\SubSystem.cpp: #include <iterator>
4. in the ...\FreeCADApp\/Application.cpp line 1282: increase the value from 1600 to 1800
Update: compile successful, but can't start/debug the application.. Getting an Error: "Unable to start Program: ...\bin\debug\FreeCADAppD.dll"
Any thoughts?
1> Application.cpp
Changes:
# ifdef _MSC_VER
# endif
Any thoughts?
In the context-menu of the active project go to the Debugging section and set the path to the FreeCADD.exe file. If it still doesn't work make sure that Libpack/bin is in your system path, so that Windows can load the DLLs.
