compile FreeCAD 0.17 with occt 7.1.0 and netgen, script for Xenial and Jessie
luvres
Re: compile FreeCAD 0.17 with occt 7.1.0 and netgen, script for Xenial and Jessie
Postby luvres » Thu Aug 10, 2017 10:52 pm
jacquesclouseau,
Could you post your script here?
There are differences between Debian Jessie and Stretch. It seems to me that Deepin is based on the Stretch.
I have built FreeCAD on Jessie and Xenial but with Stretch there is still something missing.
Actually I can compile and run FreeCAD in the start module, but when I change shape (part for example or any other) it gives an error like:
libTKCAF.so.7: can not open shared object file: No such file or directory
gdo35
Postby gdo35 » Sat Aug 26, 2017 7:14 pm
sgrogan wrote:
Wed Aug 02, 2017 10:39 pm
Sorry for not following up on this. Does nglib build on LP? Should I try to build FreeCAD against this package?
@gdo35, good to see you back! I can certainly use your help.
Dont worry, I did not test it on LP, I need to make sure it builds with pbuilder first. I will surely do that in coming days.
I keep you in touch on the previous thread to avoid double discussions in this one. ;)
Do not hesitate to contact me if you need.
hhassey
Postby hhassey » Wed Sep 06, 2017 6:57 pm
bernd wrote:
Tue Dec 06, 2016 6:15 pm
Debian Jessie:
https://gist.github.com/berndhahnebach/ ... 967e6cdd36
Will this work on Debian Stretch?
Would be fantastic!
gdo35
Postby gdo35 » Thu Sep 07, 2017 11:56 am
Would be fantastic!
Just test it ;)
Postby bernd » Tue May 08, 2018 8:58 pm
jacquesclouseau,
yes on stretch there are some problems. This solved it for me https://forum.freecadweb.org/viewtopic. ... 76#p232676
