some vtk-modules not available in conda-forge vtk
looo
Postby looo » Tue Dec 27, 2016 8:59 am
CMake Error at /home/lo/miniconda3/conda-bld/FreeCAD_1482828307657/_b_env_placehold_placehold_p/lib/cmake/vtk-7.0/vtkModuleAPI.cmake:120 (message):
  Requested modules not available:
    vtkIOMPIParallel
    vtkParallelMPI
  /home/lo/miniconda3/conda-bld/FreeCAD_1482828307657/_b_env_placehold_placehold_p/lib/cmake/vtk-7.0/VTKConfig.cmake:88 (vtk_module_config)
  CMakeLists.txt:619 (find_package)
Is this used anywhere? If not, can we exclude it?
looo
Re: some vtk-modules not available in conda-forge vtk
Postby looo » Tue Dec 27, 2016 9:38 am
maybe switching the search paths here would solve this.
ps.: removing the system-vtk (which in my case was version 6) also solves this issue.
Site Admin
Postby wmayer » Tue Dec 27, 2016 12:53 pm
The cmake handling of vtk is weird.
At the beginning we only checked for the vtk library as a whole without checking for specific components. This caused problems (on Debian) when the vtk component for the GUI binding is linked against Qt5 while FreeCAD is built against Qt4.
To solve this issue we started to check for only certain components. This however lead to build errors of smesh because the include path didn't include the hdf5 stuff any more. The problem is that on some platforms vtkIOMPIParallel, vtkParallelMPI or vtkhdf5 is required while on other platform these components do not even exist.
So, to solve this problem it is checked if a corresponding cmake file exists and if yes the module is appended.
Now the new problem is that you had installed vtk6 and 7. FreeCAD is supposed to link against vtk7 but the above mechanism finds the cmake files of vtk6 which don't exist for vtk7 any more.
Site Admin
Postby wmayer » Tue Dec 27, 2016 1:49 pm
In this file https://www.apt-browse.org/browse/ubunt ... nfig.cmake I found the variable VTK_MODULES_ENABLED that lists all available vtk modules.
Now it's possible to check this list if a module is available instead of directly checking path names. Can you try if you replace the corresponding block in the cmake file with:
        # check which modules are available
        if(UNIX AND NOT APPLE)
            find_package(VTK COMPONENTS vtkCommonCore REQUIRED NO_MODULE)
            list(APPEND VTK_COMPONENTS vtkIOMPIParallel vtkParallelMPI vtkhdf5)
            foreach(_module ${VTK_COMPONENTS})
                list (FIND VTK_MODULES_ENABLED ${_module} _index)
                if (${_index} GREATER -1)
                    list(APPEND AVAILABLE_VTK_COMPONENTS ${_module})
                endif()
            endforeach()
        endif()
ulrich1a
Postby ulrich1a » Wed Dec 28, 2016 7:43 pm
I am now getting the following error on Debian with a self compiled VTK 7:
CMakeFiles/FemGui.dir/TaskPostBoxes.cpp.o: In function `vtkRenderingCore_AutoInit::~vtkRenderingCore_AutoInit()':
/usr/local/include/vtk-7.0/vtkRenderingCoreModule.h:41: undefined reference to `vtkInteractionStyle_AutoInit_Destruct()'
/usr/local/include/vtk-7.0/vtkRenderingCoreModule.h:41: undefined reference to `vtkRenderingFreeType_AutoInit_Destruct()'
/usr/local/include/vtk-7.0/vtkRenderingCoreModule.h:41: undefined reference to `vtkRenderingOpenGL_AutoInit_Destruct()'
/usr/local/include/vtk-7.0/vtkRenderingCoreModule.h:41: undefined reference to `vtkRenderingOpenGL2_AutoInit_Destruct()'
CMakeFiles/FemGui.dir/TaskPostBoxes.cpp.o: In function `vtkRenderingCore_AutoInit':
/usr/local/include/vtk-7.0/vtkRenderingCoreModule.h:41: undefined reference to `vtkInteractionStyle_AutoInit_Construct()'
/usr/local/include/vtk-7.0/vtkRenderingCoreModule.h:41: undefined reference to `vtkRenderingFreeType_AutoInit_Construct()'
/usr/local/include/vtk-7.0/vtkRenderingCoreModule.h:41: undefined reference to `vtkRenderingOpenGL_AutoInit_Construct()'
/usr/local/include/vtk-7.0/vtkRenderingCoreModule.h:41: undefined reference to `vtkRenderingOpenGL2_AutoInit_Construct()'
CMakeFiles/FemGui.dir/AppFemGui.cpp.o: In function `vtkRenderingCore_AutoInit':
CMakeFiles/FemGui.dir/ViewProviderFemPostObject.cpp.o: In function `vtkRenderingCore_AutoInit':
CMakeFiles/FemGui.dir/ViewProviderFemPostPipeline.cpp.o: In function `vtkRenderingCore_AutoInit':
CMakeFiles/FemGui.dir/ViewProviderFemPostFilter.cpp.o: In function `vtkRenderingCore_AutoInit':
src/Mod/Fem/Gui/CMakeFiles/FemGui.dir/build.make:2317: recipe for target 'Mod/Fem/FemGui.so' failed
make[2]: *** [Mod/Fem/FemGui.so] Error 1
CMakeFiles/Makefile2:3631: recipe for target 'src/Mod/Fem/Gui/CMakeFiles/FemGui.dir/all' failed
make[1]: *** [src/Mod/Fem/Gui/CMakeFiles/FemGui.dir/all] Error 2
Ulrich
