If I set:
-DFREECAD_USE_EXTERNAL_SMESH="1"
make
[ 0%] Generating moc_Debugger.cpp
[ 0%] Generating moc_FutureWatcherProgress.cpp
Scanning dependencies of target FreeCADBase
[ 0%] Building C object src/Base/CMakeFiles/FreeCADBase.dir/__/CXX/cxxextensions.c.o
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/__/CXX/cxx_extensions.cxx.o
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/__/CXX/cxxsupport.cxx.o
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/__/CXX/IndirectPythonInterface.cxx.o
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/Axis.cpp.o
[ 0%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/AxisPyImp.cpp.o
In file included from /Users/nyholku/FreeCAD/FreeCAD-git/src/Base/AxisPyImp.cpp:30:
In file included from /Users/nyholku/FreeCAD/build/src/Base/AxisPy.cpp:6:
/usr/local/include/boost/filesystem/path.hpp:157:55: error: no member named 'move' in namespace 'std'
path(path&& p) BOOST_NOEXCEPT { m_pathname = std::move(p.m_pathname); }
/usr/local/include/boost/filesystem/path.hpp:159:27: error: no member named 'move' in namespace 'std'
{ m_pathname = std::move(p.m_pathname); return *this; }
In file included from /Users/nyholku/FreeCAD/build/src/Base/AxisPy.cpp:7:
/usr/local/include/boost/filesystem/operations.hpp:281:22: error: no member named 'move' in namespace 'std'
m_value = std::move(rhs.m_value);
