On Macos after successful CMake the compile chokes on first link with
nyholku
Postby nyholku » Fri Dec 30, 2016 5:09 pm
After successfully running the CMake
cmake -DBUILD_ROBOT="0" -DFREECAD_USE_EXTERNAL_PIVY="1" -DBUILD_FEM_NETGEN="1" -DFREECAD_CREATE_MAC_APP="1" ../FreeCAD-git
the compile process chokes on the first link step:
make
Scanning dependencies of target Driver
[  0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_Document.cpp.o
[  0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_Mesh.cpp.o
[  0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_SMDS_Mesh.cpp.o
[  0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_SMESHDS_Mesh.cpp.o
[  0%] Linking CXX shared library ../../../lib/libDriver.dylib
ld: file not found: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[2]: *** [lib/libDriver.dylib] Error 1
make[1]: *** [src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/all] Error 2
make: *** [all] Error 2
Obviously the file SharedFileList is missing but how do I get there?
I'm on Macos 10.10.5 (Yosemite) with newly installed XCode 7.2.1 (the last one to support Yosemite) and I've manually copied the MacOSX10.10.sdk into the /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/ as indicated is necessary in some posts about similar issues.
I've done a clean CMake to an empty build directory everytime I changed something but one of the last steps I did after I managed to get CMake to complete was install XCode 7.2.1 (I had 6.2.1 previously), could that have done something to invalidate some of the homebrew installed prerequisites?
Help would be greatly appreciated, I've put several days into this now and this is the furthest I've ever gotten to get FreeCAD compile and would hate start again from scratch.
wrb Kusti
nyholku
Re: On Macos after successful CMake the compile chokes on first link with
Postby nyholku » Sun Jan 01, 2017 12:46 pm
For the full story and happy ending see:
viewtopic.php?f=4&t=19471
