Bug #2843 crash on loading file
Postby Kunda1 » Fri Jan 13, 2017 1:22 pm
issue #2843
OP is running:
OS: "openSUSE Leap 42.2"
Version: 0.17.9591 (Git)
Build type: Unknown
Hash: 675bcc251060d2c597bcea761be5fb672b4ea2bd
Python version: 2.7.12
Qt version: 4.8.6
OCC version: 6.9.1.oce-0.18-dev
According to OP:
* The file attached to the ticket contains a fcstd drawing that was generated and saved without problem.
* FreeCAD crashes upon loading the file.
* The same problem occurs with other files. What they have in common is that they have TechDraw WB's with views and dimensions..
Example file and Backtrace are attached to the ticket.
sgrogan
Re: Bug #2843 crash on loading file
Postby sgrogan » Fri Jan 13, 2017 4:31 pm
I can replicate on Win with softcrash.
Anyfile that has a TechDraw Projection Group fails with
TIMING - ProjItem GO spent: 0.000 millisecs in HLRBRep_Algo & co
TechDraw::GeometryObject::addGeomFromCompound edgeCompound is NULL
Gui::Command::activated(0): Unknown C++ exception thrown
Default Part Cube
Default TechDraw Template
Insert Projection Group (default front view is enough)
Save, Close, and Re-open
OS: Windows 7
Version: 0.17.9613 (Git)
Hash: 0c34f1b749fbb116058caa54754961c6dcb4f92a
Python version: 2.7.8
OCC version: 7.0.0
Site Admin
Postby wmayer » Fri Jan 13, 2017 4:43 pm
See my comments in the bug tracker.
