[Ubuntu Daily PPA] How to install debug symbols package
NormandC
Postby NormandC » Sun Jan 29, 2017 9:59 pm
@sgrogan wrote recently that he activated the debug symbols packages on the Daily Builds PPA. (Thanks! :) )
From what I understand, this may allow to generate a more useful backtrace log, but AFAIK nobody has tested this so far.
The problem is that there is no easy way to install these debug symbols packages.
From what I was able to gather, here's what you need to do to install debug symbols packages.
Please note that you cannot use GUI tools! I tried using the Software sources GUI tool and it messed up my sources!
Note: on Kubuntu and other KDE-based desktops, please replace gksudo gedit with kdesudo kate.
First, the PPA needs one more deb line, and the file in sources.list.d needs to be edited.
On Ubuntu 14.04 LTS:
gksudo gedit /etc/apt/sources.list.d/freecad-maintainers-freecad-daily-trusty.list
On Ubuntu 16.04 LTS:
gksudo gedit /etc/apt/sources.list.d/freecad-maintainers-freecad-daily-xenial.list
On Ubuntu 16.10:
gksudo gedit /etc/apt/sources.list.d/freecad-maintainers-freecad-daily-yakkety.list
On Ubuntu 17.04:
gksudo gedit /etc/apt/sources.list.d/freecad-maintainers-freecad-daily-zesty.list
Next, we copy the first line starting with deb and ending with main, and we append /debug to the copied line.
For trusty, the new line will look like this:
deb http://ppa.launchpad.net/freecad-maintainers/freecad-daily/ubuntu trusty main/debug
For other versions, "trusty" will be replaced by the proper distro name.
Save the changes and close the file.
Next, the sources list needs to be updated:
sudo apt-get update
And finally we can install the debug symbols package:
sudo apt-get install freecad-daily-dbgsym
The package was not listed in the Synaptic package manager even after refreshing the sources, I was only able to install it from the terminal.
Now to test! :geek:
Source: How to install debug symbols for installed packages?
Re: [Ubuntu Daily PPA] How to install debug symbols package
Postby Kunda1 » Sun Jan 29, 2017 10:13 pm
NormandC wrote: Now to test! :geek:
Nice!
Linking https://forum.freecadweb.org/viewtopic.php?t=20007
When we get this working we should mention it in the Wiki FreeCAD Debugging page
sgrogan
Postby sgrogan » Sun Jan 29, 2017 11:50 pm
NormandC wrote:@sgrogan wrote recently that he activated the debug symbols packages on the Daily Builds PPA. (Thanks! :) )
I haven't tried yet, but why wouldn't
work?
Thanks for the link, it's good to know that gdb can find the libs automatically.
"fight the good fight"
NormandC
Postby NormandC » Sun Jan 29, 2017 11:53 pm
sgrogan wrote: I haven't tried yet, but why wouldn't
work?
Because that's one of the first things I tried and it didn't work, the package wasn't found. You really need to edit the freecad-maintainers-freecad-daily-<version>.list file and add the main/debug line. Only then is the package found.
sgrogan wrote:it's good to know that gdb can find the libs automatically.
It's untested :D
sgrogan
Postby sgrogan » Mon Jan 30, 2017 12:01 am
NormandC wrote:Because that's one of the first things I tried and it didn't work, the package wasn't found. You really need to edit the freecad-maintainers-freecad-daily-<version>.list file and add the main/debug line. Only then is the package found.
My question was more rhetorical, I assumed that you had tried it already. The broken link at the end of your link probably explained it.
I googled around before I activated this and the debug symbols should not effect performance. This seems distinct from a debug build. Thanks for testing this NormandC! Have you crashed FreeCAD on purpose yet?
NormandC
Postby NormandC » Mon Jan 30, 2017 12:05 am
sgrogan wrote:The broken link at the end of your link probably explained it.
Broken link? :?:
I read that by default, Canonical didn't want the package software (like Synaptic) to be polluted with debug packages, since most end users will never use them.
sgrogan wrote:Have you crashed FreeCAD on purpose yet?
I can't seem to leave the forum and try! :D
sgrogan
Postby sgrogan » Mon Jan 30, 2017 12:23 am
NormandC wrote: Broken link? :?:
EDIT:
from the comments ppa.launchpad.net/USER/PPA/ubuntu but it's not a real link :oops:
NormandC wrote:I can't seem to leave the forum and try! :D
FreeCAD doesn't crash easily anyway, you must work at it ;)
kkremitzki
Postby kkremitzki » Mon Jan 30, 2017 1:07 am
Rather than doing gksudo gedit etc, it's also easy to just use sudo -e FILENAME which will open up FILENAME with whatever editor the environment variable EDITOR is set to, e.g. for me I have:
$ echo $EDITOR
/usr/bin/nvim
NormandC
Postby NormandC » Mon Jan 30, 2017 1:22 am
$ echo $EDITOR
Returns an empty line for me. I've never set this variable and wouldn't know how, which I'm pretty sure is the case for most Ubuntu users.
sudo -e FILENAME opens the file in nano Image
I'm a GUI guy, I use the terminal only when I *have* to. A terminal-based text editor is a no-go for me.
kkremitzki
Postby kkremitzki » Mon Jan 30, 2017 1:37 am
NormandC wrote:
$ echo $EDITOR
By default Ubuntu uses nano, yeah; it's vi(m) in Centos and Arch, I believe. You can set it by, for example,
echo "export EDITOR=vim" >> ~/.bashrc
But if you're a GUI guy and not a fan of nano I doubt vim would be any preferable :D this is more of an aside for people who prefer to do things in the command line.
