ana(conda) windows packaging
UR_
Re: ana(conda) windows packaging
Postby UR_ » Sun Aug 19, 2018 2:21 pm
While configuring with cmake-gui, I got this:
Compiler: MSVC, version: 19.0.24234.1
prefix: C:/Users/aio/Miniconda3/envs/freecad_py3/Library
datadir: data
docdir: doc
includedir: include
libdir: lib
Boost version: 1.67.0
Found the following Boost libraries:
  filesystem
  program_options
  regex
  signals
  system
  thread
  chrono
  date_time
  atomic
Found Xerces-C: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/lib/xerces-c_3.lib
PyCXX found:
  Headers:  C:/Users/aio/FreeCADcode/src
  Sources:  C:/Users/aio/FreeCADcode/src/CXX
  Version:  6.2.8
-- Found OCE/OpenCASCADE version: 7.3.0
-- OCE/OpenCASCADE include directory: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/include/opencascade
-- OCE/OpenCASCADE shared libraries directory: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/lib
VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
Found Netgen: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/cmake
Shiboken2Config: Using default python: .cp36-win_amd64
libshiboken built for Release
-- matplotlib-2.2.2 has been found.
Platform is 64-bit, set -D_OCC64
git
C:/Users/aio/Miniconda3/envs/freecad_py3/Library/src/Build/Version.h written
CMake Warning (dev) at src/Base/CMakeLists.txt:382 (target_link_libraries):
  Link library type specifier "debug" is followed by specifier "optimized"
  instead of a library name.  The first specifier will be ignored.
This warning is for project developers.  Use -Wno-dev to suppress it.
area module (for Path Workbench) will be installed to: lib
Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
Configuring done
Generating done
There is a CMake warning. Should this be ignored?
zbigg
Postby zbigg » Tue Aug 21, 2018 4:10 pm
As far as I remember its enough to install Doxygen windows binary/distribution/ to libpack dir.
If still not found-run cmak-gui in that folder and point to Doxygen's folder 'by hand'.
Ive overcome it anyway so should not be a problem to you )).
cheers,
looo
Postby looo » Tue Aug 21, 2018 8:25 pm
I never cared about docs, but doxygen is also available as conda packag
UR_
Postby UR_ » Tue Aug 21, 2018 9:03 pm
actually, I'm asking about this warning:
sgrogan
Postby sgrogan » Tue Aug 21, 2018 10:31 pm
I've been ignoring it. The fact that "optimized" is being used I think makes it OK. I'll check if this warning exists with a VS2013/Libpack build.
@UR_ thanks for the continued support!
"fight the good fight"
zbigg
Postby zbigg » Wed Aug 22, 2018 9:31 am
Of coz ))
I should have suggested that solution FIRST.
BTW. Could anybody help: how to build properly FC with CONDA installed on drive other than 'C'?
I mean, the build itself succeeds but -as I run FC from CONDA's env-it calls python modules from 'C' anyway..
cheers,
sgrogan
Postby sgrogan » Thu Aug 23, 2018 8:17 pm
What is the path to your source repo?
Can you post your modified .bat file?
zbigg
Postby zbigg » Sat Aug 25, 2018 12:33 pm
Source repo: D:\Programowanie\Anaconda3\envs\freecad_py3
cmake_conda.bat:
Btw Cant refer to error screenshot because error message appears only for a second on bottom line of FC but could be seen
Traceback seeks for python module on 'C' drive. So it looks like: C:\Programowanie\Anaconda3 etc etc - and the rest as source repo address above.
set ENV_PREFIX=D:\Programowanie\Anaconda3\envs\freecad_py3
set LIBRARY_PREFIX=%ENV_PREFIX%\Library
cmake -G "Visual Studio 15 2017 Win64" ^
      -DBUILD_QT5=TRUE ^
      -DCMAKE_BUILD_TYPE=Release ^
      -DFREECAD_LIBPACK_USE=FALSE ^
      -DCMAKE_INSTALL_PREFIX=%LIBRARY_PREFIX% ^
      -DCMAKE_PREFIX_PATH=%LIBRARY_PREFIX% ^
      -DCMAKE_INCLUDE_PATH=%LIBRARY_PREFIX%/include ^
      -DCMAKE_LIBRARY_PATH=%LIBRARY_PREFIX%/lib ^
      -DCMAKE_INSTALL_PREFIX=%ENV_PREFIX%\Library ^
      -DBUILD_FEM_NETGEN=TRUE ^
      -DOCC_INCLUDE_DIR=%LIBRARY_PREFIX%/include/opencascade ^
      -DOCC_LIBRARY_DIR=%LIBRARY_PREFIX%/lib ^
      -DOCC_LIBRARIES=%LIBRARY_PREFIX%/lib CACHE ^
      -DFREECAD_USE_OCC_VARIANT="Official Version" ^
	  -DFREECAD_USE_EXTERNAL_SMESH=TRUE ^
	  -DFREECAD_USE_PYBIND11=TRUE^
	  -Dpybind11_DIR=%ENV_PREFIX%/share/cmake/pybind11 ^
      -DOCC_OCAF_LIBRARIES=%LIBRARY_PREFIX%/lib ^
      -DSWIG_EXECUTABLE=%LIBRARY_PREFIX%/bin/swig.exe ^
      -DPYTHON_EXECUTABLE=%ENV_PREFIX%\python.exe ^
      -DBUILD_REVERSEENGINEERING=NO ^
      D:\Programowanie\FreeCAD
cheers,
sgrogan
Postby sgrogan » Sat Aug 25, 2018 3:27 pm
This is weird.
You can use
freecad -l
and a log file will be created in %appdata%/freecad
You may also inspect the contents of D:\Programowanie\Anaconda3\envs\freecad_py3\Library\CMakeCache.txt for some clues?
zbigg
Postby zbigg » Sat Aug 25, 2018 5:09 pm
Msg: FreeCAD 0.18, Libs: 0.18R14442 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
Log: Time = Sat Aug 25 19:08:20 2018
Log: AppDataSkipVendor = true
Log: AppHomePath = D:/Programowanie/Anaconda3/envs/freecad_py3/Library/
Log: AppIcon = freecad
Log: AppTempPath = D:\Temp\
Log: BinPath = D:/Programowanie/Anaconda3/envs/freecad_py3/Library/bin\
Log: BuildRepositoryURL = https://github.com/FreeCAD/FreeCAD master
Log: BuildRevision = 14442 (Git)
Log: BuildRevisionBranch = master
Log: BuildRevisionDate = 2018/08/25 11:26:14
Log: BuildRevisionHash = bb9d737ba1158fdba5d06df45ab3e213065139cd
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 18
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
Log: Debug = 0
Log: DocPath = D:/Programowanie/Anaconda3/envs/freecad_py3/Library/doc\
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.18
Log: LoggingFile = 1
Log: LoggingFileName = C:\Users\bluec\AppData\Roaming\FreeCAD\FreeCAD.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page
Log: PATH = D:\Programowanie\Anaconda3\envs\freecad_py3\Library\bin;D:\Programowanie\Anaconda3\envs\freecad_py3;D:\Programowanie\Anaconda3\envs\freecad_py3\Library\mingw-w64\bin;D:\Programowanie\Anaconda3\envs\freecad_py3\Library\usr\bin;D:\Programowanie\Anaconda3\envs\freecad_py3\Library\bin;D:\Programowanie\Anaconda3\envs\freecad_py3\Scripts;D:\Programowanie\Anaconda3\envs\freecad_py3\bin;D:\Programowanie\Anaconda3;D:\Programowanie\Anaconda3\Library\mingw-w64\bin;D:\Programowanie\Anaconda3\Library\usr\bin;D:\Programowanie\Anaconda3\Library\bin;D:\Programowanie\Anaconda3\Scripts;D:\Programowanie\Anaconda3\bin;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Programowanie\IntelSWTools\compilers_and_libraries_2018.3.210\windows\mpi\intel64\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler;D:\Program Files\CudaToolkit\bin;D:\Program Files\CudaToolkit\libnvvp;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\AMD APP SDK\3.0\bin\x86_64;C:\Program Files (x86)\AMD APP SDK\3.0\bin\x86;D:\Program Files\Microsoft VS Code Insiders\bin;C:\Program Files\Git\cmd;D:\Program Files\SlikSvn\bin;D:\Programowanie\free-cad-code\FreeCADLibs_11.5.3_x64_VC12\doxygen\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;D:\Program Files\CMake\bin;D:\Programowanie\doxygen_binary\bin;D:\Programowanie\nodejs\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Users\bluec\AppData\Local\Microsoft\WindowsApps;D:\Program Files\CMake\bin;D:\Program Files\Microsoft VS Code Insiders\bin;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.14.26428\bin\Hostx64\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE;C:\Users\bluec\AppData\Roaming\npm;";D:\Programowanie\opencv\build\bin;
Log: PythonSearchPath = D:\Programowanie\Anaconda3\envs\freecad_py3\python36.zip;D:\Programowanie\Anaconda3\envs\freecad_py3\DLLs;D:\Programowanie\Anaconda3\envs\freecad_py3\lib;D:\Programowanie\Anaconda3\envs\freecad_py3\Library\bin
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = C:\Users\bluec\AppData\Roaming\FreeCAD\system.cfg
Log: UserAppData = C:\Users\bluec\AppData\Roaming\FreeCAD\
Log: UserHomePath = C:\Users\bluec\Documents
Log: UserParameter = C:\Users\bluec\AppData\Roaming\FreeCAD\user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init:   Searching for modules...
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\AddonManager... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Arch... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Complete... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Draft... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Drawing... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Fem... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Idf... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Image... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Import... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Inspection... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Material... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Measure... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Mesh... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\MeshPart... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\OpenSCAD... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Part... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\PartDesign... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Path... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Plot(Init.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Points... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Raytracing... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Robot... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Ship(Init.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Show(Init.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Sketcher... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Spreadsheet... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Start... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Surface... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\TechDraw... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Test... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Tux(Init.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Web... done
Log: Using D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod as module path!
Log: System path after init:
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\bin
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\AddonManager
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Arch
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Complete
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Draft
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Drawing
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Fem
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Idf
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Image
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Import
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Inspection
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Material
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Measure
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Mesh
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\MeshPart
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\OpenSCAD
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Part
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\PartDesign
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Path
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Plot
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Points
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Raytracing
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Robot
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Ship
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Show
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Sketcher
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Spreadsheet
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Start
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Surface
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\TechDraw
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Test
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Tux
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Web
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\mingw-w64\bin
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Library\usr\bin
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\Scripts
Log:    D:\Programowanie\Anaconda3\envs\freecad_py3\bin
Log:    D:\Programowanie\Anaconda3\Library\mingw-w64\bin
Log:    D:\Programowanie\Anaconda3\Library\usr\bin
Log:    D:\Programowanie\Anaconda3\Library\bin
Log:    D:\Programowanie\Anaconda3\Scripts
Log:    D:\Programowanie\Anaconda3\bin
Log:    C:\Program Files (x86)\Common Files\Oracle\Java\javapath
Log:    D:\Programowanie\IntelSWTools\compilers_and_libraries_2018.3.210\windows\mpi\intel64\bin
Log:    C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt
Log:    C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt
Log:    C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler
Log:    C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler
Log:    D:\Program Files\CudaToolkit\bin
Log:    D:\Program Files\CudaToolkit\libnvvp
Log:    C:\WINDOWS\system32
Log:    C:\WINDOWS
Log:    C:\WINDOWS\System32\Wbem
Log:    C:\WINDOWS\System32\WindowsPowerShell\v1.0\
Log:    C:\WINDOWS\System32\OpenSSH\
Log:    C:\Program Files (x86)\AMD APP SDK\3.0\bin\x86_64
Log:    D:\Program Files\Microsoft VS Code Insiders\bin
Log:    C:\Program Files\Git\cmd
Log:    D:\Program Files\SlikSvn\bin
Log:    D:\Programowanie\free-cad-code\FreeCADLibs_11.5.3_x64_VC12\doxygen\bin
Log:    C:\WINDOWS
Log:    D:\Program Files\CMake\bin
Log:    D:\Programowanie\doxygen_binary\bin
Log:    D:\Programowanie\nodejs\
Log:    C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
Log:    C:\Users\bluec\AppData\Local\Microsoft\WindowsApps
Log:    C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.14.26428\bin\Hostx64\x64
Log:    C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE
Log:    C:\Users\bluec\AppData\Roaming\npm
Log:    "
Log:    D:\Programowanie\opencv\build\bin
Log:
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Local server 'FreeCAD' started
Log: OpenGL version is: 4.6 (4.6.0 NVIDIA 398.98)
Log: Run Gui init script
Log: Init: Running FreeCADGuiInit.py start script...
Log: Init:   Searching modules...
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Idf(InitGui.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Measure(InitGui.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Plot... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Ship... done
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Show(InitGui.py not found)... ignore
Log: Init:      Initializing D:\Programowanie\Anaconda3\envs\freecad_py3\Library\Mod\Tux... done
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: Init: Showing main window
Log: Main window restored
Log: Show main window
Log: Toolbars restored
Log: 3Dconnexion device not attached.
Log: Init: Entering event loop
Log: Init: Processing command line files
Log: Hide main window
Log: Finish: Event loop left
Log: Destruct Gui::Application
Log: FreeCAD terminating...
Log: Saving system parameter...
Log: Saving system parameter...done
Log: Saving user parameter...
Log: Saving user parameter...done
cheers,
